Rca tv d52w14
We shut the tv off three days ago and it will not turn on. The green light comes on to indicate there is power, will stay on for 5 seconds then goes off. It will repeat this process on its own 3 times in a row. Then we have to wait 10 seconds before we can press the power button again only to begin the on /off cycle all over. We have tried unplugging it for 10 seconds. 1/2 hour, and finally all night long.. Still the tv will not turn on. Have checked the wall outlet and the surge protector we have it plugged in..and they work just fine. It doesn't work with the remote either...and we changed the batteries in that. Is there a reset button somewhere on this thing, or something we can do to fix it ourselves. If so please share info. along with any diagrams that might be useful.... We have a RCA HDTV 52" rear projection type. the model # is D52W14 yx1 I have the same problem with mine. The only way I have found to get use out of it, and it works only about half the time, is to keep trying to turn it on with the remote every 15 seconds or so. Maybe someone can find a better solution?
  • mj2theones Feb 02, 2009
    I am having the same problem however slightly different. The picture went out one day and we had the same probles as j gaines. However over time we forgot about the problem and let the tv sit. We checked the tv last week and the picture worked for about a half hour and then went out again and we couldn't get the picture back once it went out. Is this the same sort of problem? Is it a different problem?
  • 8,617 Answers
Replace the flyback 25296 and the CP150 and CP114 capacitor. You can get the flyback and the capacitors at the following link and they provide free installation instructions with pics so you can easially do the repair yourself. heres the link.
http://servicemanuals.vstore.ca/
Posted on Jan 18, 2009
3 Suggested Answers
premtech
  • 934 Answers
SOURCE: RCA tv model D52W14
That is an ITC222 chassis and likely the HOT has shorted, 2sc5588 Rca Part # 259899
You might also check Cp150 2200uf/16v in the 6 volt line, a common failure. Always replace Cp120 330uf/35v & Cp150 2200uf/16v and always resolder Cl031 & Cl032...
There is also a tech bulletin Tv-06003 Dated 12/8/2006 which states:
Replace deformed ribbon cable plastic connector BP005 on the flyback board. This connector is warping or bowing (May Not Even Look Like It) and causing poor connections to the ribbon cable. Replace Rca P/N # 258686.
Try putting pressure on the BP005 connector and turn the set on, you may find the set will now work fine. Replace connector and you may wish to replace the ribbon as well while you are doing the repair!
This set is notorious for failures like this and it is not uncommon to find multiple problems.
Hope this helps!
Bill
Posted on Aug 09, 2008
likha
  • 790 Answers
SOURCE: my rca d52w14 52 inch will not come on
Hi
did you notice the standby light? if no standby light maybe the unregulated power supply is dead as dead set, please check first the unregulated section..
Thanks!
Posted on Jul 08, 2009
What's your problem?i have a rca tv model number d52w14 and it will not turn on just the power button comes on and goes off three times?
The set actually has a "3 strikes and you are out design".
It will try three times and if fails shut the set down.
This model is prone to bad solder connections at and near the high voltage transformer---also to bad parts in that same area which include: the transformer, the sweep transistor near it, and the high voltage splitter block it feeds.
6_12_2012_3_08_16_pm.jpgTypical high voltage transformer that is also called a FLYBACK.
Jun 12, 2012 | Televison & Video
Rca d52w14 hit power green light blinks three times wont come on
could be power supply problem or high voltage problem. check caps in main power supply first.look for caps that have tops puffed up ususlly three or four.....
Feb 24, 2009 | RCA D52W20 52" Rear Projection HDTV-Ready...
RCA Model D52W14. tv wo'nt turn on.
i think your flyback may be bad and wont allow the tv to come on anymore....better to replace than repair
Dec 28, 2008 | Televison & Video
Rca will not turn on
16v 2200uf capacitor on the 6v power supply bad top of capacitor usually domed
Aug 17, 2008 | RCA HD52W58 52" TV
Help
The Rca itc222 chasis ia a problem child/ i see them all the time here at the shop. You have encountered a microprocessor saftey shutdown. THe processor has detected a problem with on of about 30 different conditions that will shut the unit down. The top reasons are the high voltage cuirits. the horizontal output transistor, flyback or even one of the projection tubes.. YOu can incur from the green light that it is NOT a Main fuse problem. TO RESet this set you have done what a tech wound do shut it down for an hour then plug it up. Technicians have special computer interface equipment that they use...much like a car computer to read errors from the processor. The main question is it worth to fix... something like this runs 300 to 500 to fix... The set is 800 new at your local walmart. if the unit is under warrenty ...get it fix ..if not THink about it
Jun 13, 2008 | RCA D52W135D 52 in. TV/DVD Combo
RCA D52W14
That model is famous for bad flybacks that shut the set down and there is no warning they just quit working. If you need further info please let me know.
May 03, 2008 | RCA D52W20 52" Rear Projection HDTV-Ready...
Televison & Video Logo
274 people viewed this question
Top Televison & Video Experts
