Question about ViewSonic NextVision N4060w 40 in. LCD Television
TV wont turn on with remote or the power button
Have a ViewSonic N4060w TV and it wont turn on with the remote or the power button. The Green lite will blink but nothing.
  • canipeds Jan 28, 2009
    Like she said. I've the same problem.
  • bakaboiz Apr 01, 2009
    i have the same prob, cept mine turned off after a while and now the led doesn't even light up.
  • 11,896 Answers
ONE: The protection circuit has taken over the power managment of the set. When you unplug it for a couple of hours or so and plug it back in it will start up because the circuits have all been reset (unplugging the power cord is a reset operation.)
TWO: The protection circuit goes into action whenever it detects an excessive amount of current being drawn from one of the 10 sections of the tv circuitry.
THREE: When it won't turn on it is because the protection circuit has captured the ON function and holds the power relay OFF until it is reset.
FOUR: So, the problem area could be any one of the 10 or so sections of the tv. The most common of which is the high voltage section because it uses the greatest amount of power. If so, this could be very expensive.
FIVE: On the other hand, it could be one of the other sections and a small part such as a resistor or capacitor shorting down. In which case the cost of repair may be only a few dollars.
SIX: However, you will need a tv tech to come to the home and diagnose the set because we cannot tell where the failure is without a hands-on diagnosis by one who knows how to test the circuit sections.
SEVEN: Usually a shop will send out a tech who will do a quick check and tell you what is wrong with the set and how much the repair cost is going to be. A house call such as this will cost from $40 to $80 depending on the distance and the price they set. I suggest you call a few shops and get their best response before deciding which one to employ.
Let me know if you will need further assistance
Posted on Jan 17, 2009
View Sonic TV wont power on
If the problem is same with different input devices and you have ensured there are no loose contacts in power outlet, RC jack, cable and sockets, the TV needs servicing.
Aug 25, 2012 | ViewSonic N4060w 40 in. LCD TV
Viewsonic N4060w tv
Ur tv the LCD inverter board is dead.Replaced the LCD inverter board u will get ur picture back.Tries websites like Shopjimmy.com,Ebay.com to buy an refurbish LCD inverter board for the replacement.It a long board in shape.
May 31, 2010 | ViewSonic N4060w 40 in. LCD TV
When i turn on tv the green power light blinks and i have to hold the power button in on the tv for it to turn on?
The power supply board is dead.That the board where the power a/c cord go into it.Replaced the
power supply board ur tv will work again.Tries websites like Shopjimmy.com,Ebay.com to buy a refurbish power supply board for the replacement.
Mar 24, 2010 | ViewSonic N4060w 40 in. LCD TV
My Viewsonic N4060W 40" LCD TV will not come on, i get a steady green light when power button is pushed but the screen is blank and no sound. My TV is 3 years old and just last year i had a somewhat...
Look at the power supply first since it is easier to get to, look for burnt parts, bad capacitors, etc.
http://en.wikipedia.org/wiki/Capacitor_plague
Please post back what you find. If the tech installed a used power supply, it may be bad also. 3 years are typical for capacitors to go bad.
Nov 15, 2009 | ViewSonic NextVision N4060w 40 in. LCD...
Tv wont turn on but green power lite flashes 3 times if i use the remote or press power button on front of tv i have unplugged tv replaced the batteries in remote trouble started 2 weeks ago if i hold...
it sounds like youre describing a RCA HDTV which needs the CP150, CP120 and CP114 repair kit. You can get that repair kit at www.tvrepairworld.com the kit contains the capacitors and the CD with instructions.
Sep 22, 2009 | Televison & Video
Viewsonic model vs10846-1m aka N4060W won't turn on.
I found if you hold the power button down on the remote or the tv , hold it down for anywhere from 2-5 minutes the green light will blink and blink and blink, all of the sudden it will stay on. then shut off, but if you turn it back on on the light will again stay on , do this 3-4 times and then the tv will turn on. Once you turn it off for over 10 minutes you will have to go through the whole rigamaroo again. This will only work for a while, mine has quit completely now. The Veiwsonic guy gave me a part number for a power board he said was most liley the issue. It ran about $71. I've got a repairman coming tomorrow to see what the dealio is. I'll let you know what he tells me, good luck!
Jan 28, 2009 | Televison & Video
Viewsonic N4060w will not come on.
replace the c21 and c22 capacitors on the power supply. they are both 1500uf, 16 v. When you pull the back of the set, youll notice that they will be slightly bulging. be sure to order quality ones (105 degree, and reputable brand). Radio shack won't have them, so you'll need to probably go online. The caps are around $1 each. order a couple extra just in case. Digikey.com sells them. I recommend you use a low watt soldering iron (15 watt), desoldering braid and take your time.
Jan 04, 2009 | ViewSonic NextVision N4060w 40 in. LCD...
LCD TV N4060w can not power on
I had the same problem...first it would take two or more power button presses to get the tv to turn on. Finally it would not turn on. It was the power supply and was easy to replace.
Dec 16, 2008 | ViewSonic NextVision N4060w 40 in. LCD...
ViewSonic NextVision N4060w 40 in. LCD TV, will not turn on.
While this isnt an exact fix at work, you will at least be able to view your tv. We have one at work that would do nothing when you hit the power on button, just the usual geen led flashing. We pulled the cover off and found the bulging caps, more than likely from brown outs. But we also found that none were holding a charge. So we held the power button on for at least five min, after the led would stay on for about 30 sec and then turn off. We kept hitting the power button and the screen would try to come on. It finally did. After it did come one we can power on and power off aslong as we dont turn it off for more than 10 min. After 10 min of it being off we have hold down power button again and start the whole process again. So the main problem i believe is the caps arent holding a charge, to be able to kick the high voltage circuit on. We did not replace any caps but if we do end up changing parts will post what was changed and cost. Hope this helps
Nov 04, 2008 | ViewSonic NextVision N4060w 40 in. LCD...
Viewsonic n4060w does not turn on
Welcome to our world... http://www.fixya.com/support/t285490-viewsonic_n4060w
This thing needs to go to a state attorney general if Viewsonic isn't even will to provide parts for these pathetic LCD TVs.
May 21, 2008 | ViewSonic NextVision N4060w 40 in. LCD...
Open Questions:
Viewsonic n4060w I was changing my chanel from the console, then the screen went blank. I can hear sound. I try to view the menu or sources but nothing. I can turn the tv on and it lights up a little but still cannot see anything. First, I had trouble with turning the TV on/off -- I could turn it on from the unit, but had to turn it off on the remote. Then, the on-screen menus started going haywire in that, as soon as you pressed the menu button, the TV would automatically quickly go through all menus on its own -- so fast, that you couldn't stop it. I had a local TV repairman come and he said that it was either the board for the TV's control buttons, and/or the main board -- which I guess is the inverter board(?). He ordered both from Viewsonic (apparently, anyway), and voila! TV started working again... but only for a week. The new problem was that it wouldn't turn on at all now. So they ordered a replacement for the two boards AND a new power supply. Lo-and-behold, he got a garbled mess to display with the new boards before he put in a new power supply, and deduced that the power supply was not the problem (and returned it). So, he said the new main board that was sent was defective, and ordered another. Today they came and attempted to put in the newly arrived main board, and it was missing capacitors (and, obviously, the TV is not working still). So, they are ordering another. I just sent him a link to an on-line store www.discount-merchant.com who had some parts available, one of which it claims is video board for an N4060W. Holding my breath now, I guess. Viewsonic is a nightmare!
May 27, 2009 | ViewSonic NextVision N4060w 40 in. LCD...
ViewSonic NextVision N4060w 40 in. LCD Television Logo
722 people viewed this question
Top ViewSonic Televison & Video Experts
Are you a ViewSonic Televison and Video Expert? Answer questions, earn points and help others
