Question about Sony KP-46WT510 46" Rear Projection HDTV
Strange colors and shadowing and then went black.
I have a 6-year old Sony KP 46WT510 projection tv. This morning upon turning it on the picture was very strange colors and shadows, then after about and hour the screen went black. The standby light is flashing 6 times. What is the cause and what part would you suggest replacing?
  • gamamark Jan 17, 2009
    I noticed that upon immediately turning the tv on now it blinks 4 times at the same time it is powering down and then blinks 6 times repeatedly until I turn the tv off. Don't know if that changes your diagnosis. Any way we can fix it ourselves or is a repairman the only solution.
    Since I am not an expert in tv repair I think the solution of replacing the whole mainboard instead of pieces of it was a good idea. Thanks.
    Genius:
  • 2,920 Answers
I would replace the main board as it would be cheaper to replace the whole board than to go piece by piece. the whole board should barely run 100.00 maybe 150.00 and would solve the problem
Posted on Jan 17, 2009
    President:
  • 2,110 Answers
    President:
  • 1,990 Answers
Welcome to Fixya! This is a Power Supply Board issue. This can be Replaired, But, If you are Uncomfortable Repairing this Kind of Thing, I would Locate an Authorized Service Center.
    Brigadier General:
  • 8,619 Answers
Hi
Check to see it TV/VIDEO setting is correct .
Also you can refer to the following link :
http://dl.owneriq.net/4/4f84e921-80a3-4654-9221-089e0d0507e4.pdf
Thanks
Rylee
  • 10,594 Answers
6 times blink shows problem of Low B Over Current and/or over volt protection.
Problem can be few parts in A and B boards.
I need bit more detail of strange shadows in picture.
  • Shahid Electronics
    Shahid Electronics Jan 17, 2009
    4 time blink and then 6 times blink.
    4 time blink shows problem in vertical deflection area of TV.
    6 times blink has been already described.
    If you are familiar with TV repair and have necessary experience, basic electronics knowledge and tools then its good to do it yourself. OR local TV repair shop is better choice to avoid further damage in TV.
    Good Luck.
    Sergeant:
  • 378 Answers
Its the problem of ic on the main board that gone faulty and that needs to be replaced .will cost you near to $50 plus the service charge of the technician.
My television is only 6 years old. Red lines have appeared in the form of a wave pattern on the screen. What does this mean?
Tv have a problems known as a convergence problems,it dead.The tv have colors lines R,G,B mis alignments,have a colors shadows or 3D pictures look alike?Ur tv convergence board have dead 2 STK convergence ICS and some or all it resistors too.These parts on the tv convergence board,must be replaced to solved the tv picture convergence problems.The shop,will cost u like $300-350 for parts and labors.
Nov 27, 2010 | Sony KP-46WT510 46" Rear Projection HDTV
All the lettering on my screen as well as images have a red shadow
Tv have a problems known as a convergence problems,it dead.Tv have colors lines R,G,B mis alignments,have colors shadows pictures or 3D pictures look alike?The tv convergence board have dead 2 STK convergence ICS and some or all it resistors too.These parts on the tv convergence board,must have to be replaced to solved the tv pictures convergence problems.The shop,will cost u like $300-350 for parts and labors.
Nov 21, 2010 | Sony KP-46WT510 46" Rear Projection HDTV
Top left area of screen turning green
The tv have a problems known as a convergence problems,it dead.Colors R,G,B lines mis alignment,have colors shadows,and 3D picture.The tv convergence board the 2 STK convergence ICS and some or all it resistors are dead.These parts are dead,must be replaced to solved convergence problems.The shop will cost u $300-350 for parts and labors.
Sep 04, 2010 | Sony KP-46WT510 46" Rear Projection HDTV
Our Sony KP-46WT510 rear projection screen TV just
Convergence ICs, they are big black ICs will have part# on them if they are STK392-110s use 180s better ICs also CK pico fuses in front and behind ICs
they will look like resistors but will be Yellow or Green 5amps/6amp fuses
Mar 18, 2010 | Sony KP-46WT510 46" Rear Projection HDTV
I have a red shadow in 3d on sony KP-46WT510 TV.
Ur convergence is dead.Problems:Are 3D colors,colors misaligns,and colors out of focus.Know how to solders?Must change 2 convergence ICS,and some or all the resistors.Tries Websites Tv repair World.com,Tvrepairkits.com to buy a convergence kit to repair it ur self.The shop will cost u $300 for parts and labors.
Feb 17, 2010 | Sony KP-46WT510 46" Rear Projection HDTV
Sony 51" Rear Projection TV is blurry with colored ghost images
Thats caused by a convergence failure. The Sony type 1 convergence repair kit from www.tvrepairworld.com will usually correct that issue the kit contains the components and the CD with repair instructions so you can repair yourself.
Dec 20, 2009 | Sony KP-46WT510 46" Rear Projection HDTV
Sony KP-46WT510 Picture went out (completely
Your Sony TV needs Screen (G2) volts adjustment and I'm not sure that you can do that or not by yourself.
If you are confident and know electronic stuff repair, then let me know to guide you OR call local TV tech to perform adjustment.
Thanks.
Oct 30, 2009 | Televison & Video
6 bliks on sony kp-46wt510
KP46WT510 Shutdown 6 Blinks. 6 Blinks = Low B+ OCP/OVP
SOLUTION: Replaced Flyback transformer. It had no rings on the ringer test.
HQ
Comments: Any load on the B+ line can cause 6 Blinks.
Example: If the 200v line is loaded down will cause a drop in B+ due to bright picture current demand.
Click Here! to download the Sony Kp-46wt510 full service manual.
Nov 11, 2008 | Sony KP-46WT510 46" Rear Projection HDTV
Sony KP-46wt510 Convergence issue
convergence ic's replace all 3 be carefull make sure to reapply the thermal compound to the heat sinks after cleaning the old stuff off stk's can be had from global
Oct 06, 2008 | Sony KP-46WT510 46" Rear Projection HDTV
Sony KP-46WT510 46" Rear Projection HDTV Logo
16 people viewed this question
Top Sony Televison & Video Experts
Are you a Sony Televison and Video Expert? Answer questions, earn points and help others
