Question about Insignia IS-LCDTV32 32 in. Television
No control either by remote or manual.
Lovely picture and sound except volume slide bar stuck on 63 and cannot turn down eiter by remote or manually.slide bar remains "on" picture
Cannot mute.
Cannot enter menu except for milliseconds.
All settings are set to maximum on slide bar when I get to peek at them through menu.
Can turn TV on and off with remote or manually
  • ken7342 Jan 18, 2009
    Left off overnight.
    now no volume (aux works with other speakers)
    No contol by remote.
    Volume slide bar will not leave screen. Shows 0
    When I press menu button on side volume increases and becomes audible however immediately slides back to 0 when menu button released and slidebar stays on screen.
    Picture normal except for slidebar
  • 11,896 Answers
Unplug your tv for at LEAST 4 hours. By doing this you are doing what we call a "master reset", the processor and memory inside are reset.
Let me know what has changed so I can further assist you from there.
Posted on Jan 17, 2009
  • Nate Stansfield
    Nate Stansfield Jan 24, 2009
    PRESS YOUR MENU BUTTON ON TV AND THEN PRESS EXIT AND IT SHOULD GO AWAY
How do i set up a new remote control for a samsung ht ws1 sound bar
2-Function Remote Stopped Controlling my Sound Bar - Verizon Forums
https://forums.verizon.com/t5/Fios...Remote...Sound-Bar/td.../559715
Apr 6, 2013 - It won't even control volume through the TV (Samsung). ... Did theremote ever turn on the sound bar, or have you been controlling ... Does the sound bar or TV have sound (sound but not volume control)? ... NO, UNFORTUNATELY THE FIOS REMOTE NEVER POWERED ON/OFF THE SOUNDBAR - I HAD ...
Your remote reprogramming woes solved - Rogers RedBoard
redboard.rogers.com/.../your-remote-reprogram...
Rogers CommunicationsJun 18, 2014 - Once the TV turns off, press the SETUP button once to lock the code.... the Rogers remote to turn TV on/off but can't get the remote to control volume. ...New Samsung smart TV and I have entered all the proper codes but the ..... Doesanyone have a code for volume control of Samsung Soundbar HW-J250.
Wireless Genie remote Doesn't turn on/off the soundbar - AT&T ..
Jan 08, 2016 | Samsung HT-WS1 Speaker System
Volume will not turn up and will automatclly turn it self down when tv is turned on the volume bar is also pink
Take the battery/s out of the remote and operate the TV manually, if this works then its the remote itself causing the problem. Sometimes the buttons get stuck down and you need `flick` them with yor finger nail to release them. If the remote is quite well used then it needs taking apart and cleaning the contacts with a cotton bud and a non solvent cleaning fluid, this takes about 20 mins.
Also to test if the remote is transmitting, face the remote at a digital camera, if you can see a light or flickering in the viewer then you know its working everytime you press a button. If its flickering without touching it, at least one button is stuck down.
May 28, 2014 | Televison & Video
Volume control
Poltergeist in volume circuit is the diagnosis. Try a hard reset of the receiver to see if that does the trick with the electronics.
Sep 01, 2017 | Mitsubishi WD-82737 82" DLP TV
Have an Hitachi 60sx12b. the sound meter bar stays on. can manually adjust the sound up but will go back down to 0. tv remote or sat. remote doesn't work at all. Please help
It sounds either volume down button is bad that turns volume down on its own or system control chip got defective and decreasing volume level.
Press volume down button on tv front and check is it working properly.
Let me know to find out further info to solve the issue.
Thanks.
Jun 05, 2010 | Hitachi Televison & Video
We have a RCA tv. We've had issues with this set before where it wouldn't come on at all, which we've found out is a common problem for it and got it fixed. Now the volume won't go up and it won't even...
It sounds like you have a control panel problem. Switches go bad in these a lot. Try removing the top control panel and changing the switches. To remove the control panel, take the back off and look at the panel from the inside. You will see a tab that keeps the panel from sliding out of the front. push down on the tab slightly and slide the control panel out of the front. Take it to a repair shop and ask them if they have the individual switches as the whole board is no longer available. If not, remove the switches all together and leave the remote sensor. This will disable the control panel but the remote will still work. Good luck
Oct 19, 2009 | RCA F32650 32" TV
Cannot hear the sond on Sylvannia TV 6615LCT
This will sound strange, but some DVD players and cable boxes have separate volume controls. I would check the settings for both of those to make sure that the volume has not been turned down and also check the connections from the dvd player and cable box to the tv. Make sure all connections are solid.
Apr 25, 2009 | Sylvania 6615LCT 15 in. EDTV-Ready LCD...
Volume won't turn down
Try the setup program. When you get to the main setup screen, look for a reset all to standard setting. That may solve the problem. If it doesn't then the sound module may need to be replaced inside the TV.
Apr 11, 2009 | iLO 3200 32 in. LCD Television
Hitachi volume bar always on, remote doesn't work
you can start by opening the front panel and check if the control board (with channel ,volume ) is correctly fixed or need to be solded.
the service manual is here in 6 parts and for free...:
http://www.eserviceinfo.com/downloadsm/31328/Hitachi_43FDX10B.html
cheers
Dec 21, 2008 | Hitachi FDX Series 43FDX10B 43" Rear...
Volume up then pic gone
Good Day;
The TV's front panel may be bad, manual buttons. TEMPT FIX; remove speaker, cloth covered, cover, disconnect cables. TV will work but only with remote.
Good Luck!
Jun 12, 2008 | Mitsubishi WD-52525 52" Rear Projection...
Insignia IS-LCDTV32 32 in. Television Logo
308 people viewed this question
Top Insignia Televison & Video Experts
Jaime Hernandez
Are you an Insignia Televison and Video Expert? Answer questions, earn points and help others
