Question about Whirlpool LSR6332K Top Load Washer
GE model WWA5600GBLAD water wont shut off
Did a load of wash yesterday I found my kitchen flooded. The washer goes through the cycles but the water is continually running. Doesnt matter if the water is hot or cold. Also, once the wash was done the dial just moved on to the next wash type. If I turn the water line off the washer spins then shuts off HELP
catriver
  • 878 Answers
SOURCE: Flooding
La Trisha, There could be many reasons for the leak, however usually all leaks are visable. Your model is a direct drive pump and motor and I have seen a lot of these pumps go bad and leak. You will have to remove the front panel. There should be 2 clips, one on each side of the washer top. Push a putty knife in these clips and the front panel should pop out from the top. Now you will be looking right at the pump on the bottom. It is held on with 2 clips and 2 clamps, a real easy fix. When you remove the front panel, let the washer fill a little again and see if the water is pouring from the pump. You will also be able to get a look at all the other hose attachments. The part number for the pump is 3363394. Good luck..
Posted on Jun 18, 2006
faggly
  • 74 Answers
SOURCE: Maytag performa washer hot water runs continuously
Littleone.. please check your instructions.. some washers now dont need Hot water connection to them...they heat their own as part of the efficiency settings on the wash programmes themselves!
Regards Faggly
Posted on Mar 19, 2008
IrishDruid
  • 2712 Answers
SOURCE: Washer will won't run cold water cycle
Some washing machines allow cold water to enter only during certain cycles. Others intermittently allow hot and cold to enter, to temper the temperature of the water. Consult your owner's manual if you are unsure about whether the machine is acting abnormally.
If you're sure the machine is not working the way it used to--or should--check the following.
  • Is the cold water turned on? If not, turn it on.
  • Is the washer getting hot water but no cold water? If so, check to see if the control panel settings are correct.
  • Is there cold water coming through the proper hose? If not, check to see if the screen inside the water-inlet valve is clean. (The water-inlet valve is the device on the washing machine that the fill hoses are attached to.) If it's clean, you probably have a defective water-inlet valve. If so, you need to replace the valve.
  • Hope that helps! Should you have any further questions, please feel free to post them here.
    P.S. – I would greatly appreciate a FixYa! rating if the solution I provided fixed or helped you fix your problem.
    Thank you for using FIXYA!
    Cheers!
    IrishDruid
    Posted on Oct 12, 2008
    • 109 Answers
    SOURCE: I have a GE top load washer model G157. When I
    timer is bad
    Posted on Aug 23, 2009
    blueextc3221
    • 15935 Answers
    SOURCE: washer will not drain, just hums then shuts down
    If you put it on wash - does it agitate?
    If not - Most likely the coupling is failed.
    Any way you look at it - you will need to empty as much water out as you can - because to replace the coupling - the pump must be disconnected.
    CLICK HERE to see the coupling.
    Another telltale sign of a failed coupling are black rubber bits, and plastic pieces under the washer when you tip it up.
    Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question.
    Posted on Oct 01, 2009
    What is the purpose of the flood hose? we have a ge wjsr2080t2ww washer. when we use the power wash cycle in super capacity mode as a minute after it starts agitating the water comes flooding out from...
    the purpose of that tube so it anywater that comes out of it goes through it and directs the water down the back and away from the motor. Now the bigger issue is why is water coming through that tube.What i suspect the reason of that is that the transmission is defective and the break is that internal to the transmission is slipping so the inner tub turns during the wash cycle force water up the side of the tub into that tube.during the agitate cycle the tub is not suppose to move at all and stay locked into place,but instead its moving where the water is forced up by centrifical force too and out the top of the tub cover,if it leaks with only a small water load it will leak worse with a large water load. if this is what is happening and the tub is rotating on agaitate cycle teh fix for that is to replace transmission which in most cases cost as much as replacing the washer would be
    Aug 04, 2011 | GE WDSR2080D Top Load Washer
    Water will not shut off in washing machine
    Check to load size selector switch, sounds like tube came off of it. The tube goes from switch to bottom of tube, tells machine what size load and when to turn off water.
    Jul 19, 2009 | GE WBSR3140DW Top Load Washer
    Water not shutting off to begin wash cycle flooded room
    Probably one of the water cut off solenoids not shutting off.
    Do you use both hot AND cold water?
    Try using only cold water first. If that works, maybe hot water solenoid is faulty.
    Next, connect cold water to the HOT inlet, and try it again. This means you have now tried each of the solenoids, and maybe identified which one is faulty (assuming thats the problem!). If water wont cut off after trying this, the problem will be with whatever level sensing device it has, but I am not familiar with the model you have, so cant help there. Good luck.
    Jun 01, 2009 | Washing Machines
    Water will not stop filling for the wash or rinse cycles
    OMG! Dude, what up cuz, down here in Mobile trying to solve my own washer problem!!! Tina Wow, talk about coincidence!!!
    May 30, 2009 | Kenmore Washing Machines
    The water wont shut off
    Hi, It sounds like the mixer inlet valve has gone bad.
    Did you try and shut the power off to the waser first with no results?
    Please let me know so I can assist you.
    Thanks
    Vic
    May 27, 2009 | Kenmore 24032\24036 Top Load Washer
    Water will not stop filling wash basket, even when off
    Your water fill (mixer) valve is failed in the open position.
    CLICK HERE for the part.
    Thanks for using FixYa - a FixYa rating is appreciated for answering your FREE question.
    May 20, 2009 | GE WBSE2090A Top Load Washer
    GE Washer top-load WLDSR416FOWC
    Actually, I think I do remember having one do this before, and I believe on these GE models the spin cycle goes through the water level switch, so if your water level switch is sticking, then it won't spin, thinking its still full of water.
    Here's the water level pressure switch for your model:
    Manufacturer part#WH12X10065 is RepairClinic item#2205
    don't forget to rate me in main page,it is the only way i get paid for my works..
    Jul 23, 2008 | GE WDSR2080D Top Load Washer
    Water overflow
    Are you on a well? Often people with a lot of sediment in water get sick of the screens in water valve plugging up so they remove them. NEVER remove these screens. If any sediment gets into valve it can hold it open causing flooding. If you unplug unit and water still comes in you must replace valve.
    Oct 08, 2007 | Maytag LSE7806A Top Load Stacked...
    Power Surge and WD16BA
    Door not shut Check that the door is properly shut.Faulty interlock A faulty interlock might not allow the door to shut properly. Find your door interlock here and replace, or contact a qualified repairer.
    No power Check the flex, plug wiring, fuse and mains supply for faults.
    Faulty on/off switch Check the power light if fitted. Replace your on/off switch.
    Water supply disconnected or off If a washer dryer cannot load water it cannot start a wash cycle. Check water supply.
    Sep 18, 2006 | Smeg WD16BA Front Load Washer / Dryer
    Whirlpool LSR6332K Top Load Washer Logo
    53 people viewed this question
    Dan Webster
    Dan Webster
    Sal De
