Question about LG DLE2514 Electric Dryer
LE code My washer TROOM WL1814CW just show an EL code, stopped working and began doind a weird sound. What is happening with it? I will really appreciate your answer !!!!!! jacki
  • 1,543 Answers
LE codes are extensively covered in past Fix-Ya solutions, but are generally caused by only a handful of things. 1. the " Load Error " can be a very off balanced load. 2. excessive use of soap leads to too much suds, and thus drag on the inner tub. (use 1 tablespoon of HE soap max. per load) or 3. the Hall sensor (part number 6501KW2001A) has failed. The hall sensor is rather easy to replace, and is covered by a seven year part warranty. Take the back cover off. Take the big nut off and remove the motor rotor. Remove the bolts holding the motor windings. Remove the electric plug on the sensor and unclip it from the motor winding. Snap new sensor on and reassemble. Usually takes under a half hour. On a difficulty scale of 1 - 10, it might rate a 4. This should be a Fix-Ya for your machine, and at basically no cost!
Posted on Jan 17, 2009
Error code LE
I am sorry the code is hp
Mar 08, 2014 | Maytag MAH8700A Front Load Washer
Washer stops cycleing
First are you sure the error code is 'LE' and not 'tE' which looks very similar. The LE is usually the motor position sensor. Common on older washers. Easy fix. Under $20 part. The tE error is usually the thermistor. Inexpensive part about $6, but can be more complicated to get to. Ad a comment to your question and my answer with error code and I'll reply with more info if needed.
Jun 24, 2017 | LG WT4870CW 4.5 Cu. Ft. Top Load White...
Yukon XL was first showing Reduced Engine Power, then Oil Gauge quit working, now car is running hot
Might help, disconnect negative terminal from battery for 10 minutes, if the compute is getting weird readings this will reset it and maybe help.
Dec 09, 2013 | 2005 GMC Yukon XL
Matshita DVD-RAM UJ8A2AS Fails to Read CDs/DVDs After 4 Attempts
You didn't mention about inserting a different CD in your computer. Try using different CD's. Make sure all CD's work great or are known good.
It might be just your CD.
David
Mar 19, 2013 | Sony VAIO Computers & Internet
Nesecito el puk de mi celular
El hallazgo un PUK (Desatascar Personal Llave) número no es tarea duro. Para encontrar que un PUK codifica todo usted tiene que hacer es llama el cuidado de cliente y pide que ellos ayuden usted con el asunto. Antes que ellos le proporcionen el código de PUK, ellos le preguntarán varias preguntas. Usted necesita para darles la información apropiada. El cuidado del cliente es la única fuente de que le puede dar el código de PUK.
En aquel momento cuando usted entra un número equivocado de alfiler tres veces. El teléfono le pregunta para un número de PUK. El código de PUK es número generalmente de ocho cifras que Este número de PUK es un código que desatranca que lo ayuda a desatrancar el teléfono celular y utilizarlo. Si usted entra un número equivocado de PUK 10 veces que usted simcard consigue rechazado. Entonces usted tendrá que conseguir un nuevo simcard. Esto quizás suceda que su teléfono le quizás pregunte para PUK2 después de que usted entre su número de PUK.
Finding a PUK (Personal Unblocking Key) number is not tough task. To find a PUK code all you have to do is call up customer care and ask them to help you with the issue. Before they provide you the PUK code, they will ask you several questions. You need to give them the appropriate information. Customer care are the only source from which can give you the PUK code.
At the time when you enter a wrong pin number three times. The phone asks you for a PUK number. The PUK code is generally eight digit number This PUK number is an unlocking code which helps you to unlock the cell phone and use it. If you enter a wrong PUK number 10 times than you simcard gets rejected. Then you will have to get a new simcard. This might happen that your phone might ask you for PUK2 after you enter your PUK number.
Sep 02, 2009 | Sony Ericsson TM506 Cell Phone
LE error code on LG WM0642 FL washer
LE is a locked motor error code.
It is usually associated with a loose motor connector wire or a defective Hall Sensor.
Mar 08, 2009 | LG WM-2277HW Front Load Washer
LG WM1812CW PROBLEM
Just had this same problem on my LG wm1832CW machine. Sensor assembly was replaced and all is well..
Simple and fairly inexpensive to replace.
Oct 28, 2007 | LG WM1812C Front Load Washer
LE code flashing
Try replacing the sensor assembly. Part number 6501KW2002A. It is on the stator itself where the 4 wire connector clips to. Only costs $17 + change & shipping. Mine works fine now!
May 07, 2007 | LG WM-1832C Front Load Washer
LG DLE2514 Electric Dryer Logo
238 people viewed this question
Top LG Dryers Experts
Tim Whalen
Dan Webster
Dan Webster
Mike
Mike
Are you a LG Dryer Expert? Answer questions, earn points and help others
