Question about SanDisk Sansa m240 MP3 Player
Auto Detect or MSC
Is there a better one to choose bc before I had the problem of not being able to view some of the songs that were in my mp3 player which initially was on MSC. Then I switched to Auto Detect and was able to delete the songs I decided not to put on the player. Whats the difference between the two
I'm not sure what the REAL difference is, but I have some info that might help "Auto Detect" can also be called MTP which stands for MEDIA TRANSPORT PROTOCOL. Also, MSC stands for MEDIA STORAGE CLASS. Hope you can figure out something from this :)
Posted on Sep 29, 2007
I really dont know. Im only able to delete songs with MTC Auto detect doesnt work atall >
Posted on Aug 03, 2007
SOURCE:
I got a problem with my mp3
Transfers onto the m240 can be done in 2 USB connection modes:
MTP mode: Media Transfer Protocol using software, e.g. Windows Media Player 10 or higher.
MSC mode: Mass Storage Class using Windows Explorer, looking in "My Computer" viewing the player as a removable disk.
Typically, songs put onto the player in MSC mode can not be viewed in MTP mode and the other way around.
Switching to MSC mode in the player's menu:
Look in the player under Settings Menus > USB > select MSC for using the "copy and paste" or "drag and drop" method for transfers in "My Computer".
When Auto Detect is selected, it depends on the configuration of the computer, what setup for priority has been installed.
Forcing the player into MSC mode:
1. Turn device OFF.
2. Facing the hold switch slide it to the right so an orange color would show putting the device on Hold.
3. Connect the device to the PC.
Information for the USB connection mode and how to make hidden files in XP and Vista visible, on the support site:
http://kb.sandisk.com/app/answers/detail/a_id/447
Manual for the m200 series players (readable with Adobe Reader):
http://mp3support.sandisk.com/downloads/um/sansa-m200-um.pdf
Need more help ? Don't hesitate to add a comment.
Apr 15, 2010 | SanDisk Sansa m240 MP3 Player
Sync songs don't show on my player
It says in the user manual for C-100 sansa player that "various software packages are available to syncrhonize your songs on your device. Please refer to the specific software package instructions. "
I used Windows Media Player 9 and when you use these older Media Players you must remember to change your USB setting on your Sansa player to MSC. Turn on your Sansa Player, Choose the Main Menu and select settings. Don't choose auto-detect, but select MSC. If you choose auto-detect it will default to a setting called "MTP", and MTP wants Windows Media Player 10 to download your stuff.
I'm not familiar with how ITunes works, but perhaps AUTODETECT will work to synchronize your files.
Good luck.
Jun 22, 2009 | SanDisk Sansa m200 SDMX3-512 MP3 Player
My computer and sansa mp3 player
The older C-100 required you to change your settings on your main menu.
Main Menu
Settings
Auto Detect or MSC comes up
If you have Windows Media Player 10, choose auto-detect.
If yo uhave Window Media Player 9 or earlier, choose MSC. Happy listening.
(You probably just forget about that little settings change on your old one).
I'm not sure if the M-200 has the same settings thing, but hopefully it does, cause that's the only solution I have for today!
Feb 02, 2009 | SanDisk Sansa m200 SDMX3-512 MP3 Player
It won't let me delete songs
  1. We Too had a hard time deleting a song but found the solution..... Put the mp3 play in the MSC mode through the settings do not put in auto.....when your computer prompts that the music player is connected it will have a screen that asks play music, open folder to veiw files..... or take no action... you neew to click on the open folder to veiw files..... when this screen loads find the song or songs that you want to delete right click and then delete it will only delete from the mp3 player.....took me two days of pissing with this mp3 player to figure it out......
Dec 15, 2008 | SanDisk Sansa m250 MP3 Player
I can't delete songs from my Mp3.
I had the same problem.
On the MP3, go setting and then to USB.
There are two options: Auto Detect or MSC. One will be checked showing the current connection type. Select the other one and connect the Sansa to your computer.
For some reason, the Sansa doesn't recognize files loaded in MSC if you're connected in Auto mode and vis versa.
In MSC mode, it will show up as a devise with a drive letter. In Auto mode, there's no drive letter; it shows up as a removable devise.
Also note, you can only add Playlists in the Auto mode. MSC mode does not recognize Playlists or if it does, I haven't figured out how to do it
Dec 08, 2008 | SanDisk Sansa m230 MP3 Player
I have a new sansa mp-3 can't put CD on
Copy your cd into your Media Player first.
Once it is in your library, you should be able to send it to your player by right clicking on the songs in your libary (using Windows Media Player 9).
Make sure you choose correct USB settings.
On my C-100, I have to go to Main Menu of my sansa player, choose Settings.
You might see auto detect or MSC.
Choose MSC for Windows Media Player 9.
Choose Auto detect for Windows Media Player 10.
You can also go to www.sandisk.com and download a manual for your player.
Dec 06, 2008 | SanDisk Sansa m200 SDMX3-512 MP3 Player
Where are my songs?
Your USB settings are wrong. In the menu, select MSC, not auto detect. xlthim
Jul 07, 2008 | SanDisk Sansa m230 MP3 Player
Sandisk M240
Go into the menu, into settings, then in, usb which should have the options of auto detect or MSC, try picking the other option and connecting it to the computer and then see if there are more songs that can be deleted. Let me know how this works out
Jun 12, 2008 | SanDisk Sansa m240 MP3 Player
Sansa c 240... how do i download media converter?
You don't need to Get the Sansa Media Converter to Transfer song on your player. the Sansa Media Converter is used to transfer photos and videos on the Sansa.and to transfer song on the Player this is what you need to know.
the Sansa has two modes wherein it may connect to the computer, the MSC (Mass Storage Class) mode and the MTP (Media Transfer Protocol) mode. If you are transferring un-licensed, non-protected songs, you may transfer them using the MSC mode by simply copying them on to the Sansa. This mode also allows you to use the player with Audible files. If you are transferring music that you have purchased or music that are licensed and/or proctected, you would need to use the MTP mode. To transfer these files, you would need to use Windows Media Player 10 or some other Music Softwares such as Rhapsody and Napster.
If you add songs to the player in one mode, then switch to the other mode, you will not be able to see the songs from the previous mode, though the space used on the player will still reflect their presence. If you cannot see your songs on your PC in one mode, please try viewing them in the other. In order to change the USB mode of the player, you must power the player on and go to "Settings." Under "Settings," there should be a "USB" option. It would then give you the choice to change it from "Auto Detect" (MTP which is also known as Playforsure in other Sansa) to "MSC (Also known as Rhapsody in other Sansa)."
To add songs using the MSC mode, follow these steps:
1. Organize your songs into folders and place it into one directory.
2. Open "My Computer" and open the "Sansa C240" drive for your Sansa.
3. If you see 3-4 Folder there, click on Tools choose File Opdtion, there will be a Pop-up screen and choose View Tab
4. Select on Show Hidden files and Folder Option, so you can see all the files
5. Choose MUSIC Folder, double click and Drag and drop all the songs on that folder, and It will go automatically on your player. OR highlight a songs, right click select COPY, go to MUSIC folder right click then PASTE and it will be save on your Player
If you still need the media converter...go to utorrent.com to download there software and go to this website...
http://search.utorrent.com/search.php?q=sansa%20media%20converter&e=http%3a%2f%2fwww.mininova.org%2fsearch%2f%3futorrent%26search%3d&u=1
Dec 13, 2007 | SanDisk Sansa c240 MP3 Player
Need help
If you change USB protocols to MSC, it won't let you view the songs you put on using the Auto-Detect protocol, in my experience, and you can't switch back protocols. Reformatting by going into my computer, right clicking your sansa device, and then going to format seems to be the only way to get rid of these invisible songs, and you won't be able to select which ones. It gets rid of all of them, but at least they're gone.
Aug 11, 2006 | SanDisk Sansa e250 MP3 Player
SanDisk Sansa m240 MP3 Player Logo
192 people viewed this question
Top SanDisk Audio Players & Recorders Experts
Joe Negus
Joe Negus
Ekse
 Ben
Ben
Level 1 Expert
Are you a SanDisk Audio Player and Recorder Expert? Answer questions, earn points and help others
