Question about Epson Aculaser C1100 Printer
I have a service req E527 error on my Epson printer. how to fix?
  • Abbie Normal May 11, 2010
    Good job on cutting and pasting someone else's post, leroyal.
    Genius:
  • 2,120 Answers
To fix the E527 error, close the front panel (cover A) and open the top cover (cover B). With the photoconductor unit removed, the toner carousel will rotate. It only rotates if cover A is closed all the way. You can easily rotate the carousel to a position where you can remove/reinstall the stuck toner cartrdige. report_dis_text_13954 = 'We\'re sorry but you must be signed in to report inappropriate material. Click the button below to sign in or register.
  • Sign In / Register »
  • Cancel »
Posted on Jan 17, 2009
Epson Acculaser CX11NF Error 'Service Req E527'
Hi.. To fix the E527 error, close the front panel (cover A) and open the top cover (cover B). With the photoconductor unit removed, the toner carousel will rotate. It only rotates if cover A is closed all the way. You can easily rotate the carousel to a position where you can remove/reinstall the toner cartridge if stuck.
Thanks
jim report_dis_text_13954 = 'We\'re sorry but you must be signed in to report inappropriate material. Click the button below to sign in or register.
  • Cancel »
Feb 18, 2009 | Epson ACULASER CX11NF All-In-One Printer
Epson cx1100 e527 error
Please provide the model and the make
Apr 16, 2008 | Epson Aculaser C1100 Printer
Message error E527
What firmware version have you updated to? Check the sensor for the carousel. It could be that the sensor has got a nudged and knocked out of alignment. Remove the PCU and you will see the sensor on the left side above the carousel. Adjust it so it lines up better with the carousel. If it's still bad, check the sensor behind the LV/HV power supply. To do this you will need to remove the two power supply's. If you want a service manual with full details and error code translation get in touch with http://www.TheServiceManualShop.com (cheap as chips!)
Aug 14, 2007 | Epson Aculaser C1100 Printer
C1100 service req e527
Hi-
Try reseating the Photoconductor unit, or for step-by-step instruction to resolve this call 562-276-1300.
Hope this helps
Oct 29, 2008 | Epson ACULASER CX11NF All-In-One Printer
SERVICE REQ. C0082
C0082= CPU error ( TLB miss exception {Load/Fetch}), requires service personell to fix.
Jun 09, 2008 | Epson Aculaser C1100 Printer
Service req E527 error thank you it helped - the cartridges are still difficult to manouver - do you know if the plastic strips (with sticky tape) are meant to be there or not?
I imagine not. Usually, those sticky plastic strips are there for shipping purposes. Where exactly are the strips? Knowing that will help me advise you further.
May 24, 2008 | Epson ACULASER CX11NF All-In-One Printer
Try this (as per Epson Tech Support): To fix the E527 error, close the front panel (cover A) and open the top cover (cover B). With the photoconductor unit removed (as you have already), the toner carousel will rotate. It only rotates if cover A is closed all the way. You can easily rotate the carousel to a position where you can remove/reinstall a stuck toner cartrdige.
I hope this works for you. Let me know please!
May 24, 2008 | Epson Aculaser C1100 Printer
Epson C1100 aculaser
E527 Dev home position sensor error:
Possible causes:
MOTOR ASSY MAG
SENSOR ROTARY HOME POSITION
HARNESS ASSY MAIN
PWBA MCU
LV/HVPS
Apr 11, 2008 | Epson Aculaser C1100 Printer
xfa podria decirme k parte de sensores o motor esta para cambiarlo en mi impresora epson aculaser C1100 el service req E527, y no se puede hacer nada, ayudame xfa mi correo es dayeralb3@hotmail.com, de antemano le agradesco su gentil ayuda
dayer...
Mar 05, 2008 | Epson Aculaser C1100 Printer
E547
The E547 error relates to the feed motor: Service Req E547 Feed Motor Failure DRIVE ASSY FEED (Feed Motor) of the Feeder is not rotating at the specified speed. This is error is most often caused by electronic part failures rand is not easily rectified by the non professional user. Continuity needs to be checked on several parts of the harness as well as voltage and resistance tests to determine which part has failed. If the machine has warranty on it, you need to call Epson. Check my previous post on this item: http://www.fixya.com/support/t154259-paper_jam_e547
Jun 15, 2007 | Epson Aculaser C1100 Printer
Epson Aculaser C1100 Printer Logo
1,243 people viewed this question
Top Epson Office Equipment & Supplies Experts
Alun Cox
Are you an Epson Office Equipment and Supply Expert? Answer questions, earn points and help others
