Question about Cisco 7906G IP Phone
7906G Home VOIP installation Problem
I am trying to install the Cisco 7906G at home on my new AT&T VOIP Internet-TV-Phone service. Will not work if I connect directly to one of the RJ45 ports on the main Router. Will not work if I do the same but going through an ethernet hub. How can I make it work??? And, do I also need the external power supply??? Or will the power come through the ethernet connection???
Ike
  • 1 more comment
  • puchicas Mar 19, 2009
    Response to Clarification Request posted by Dubravko:
    I do not have a Cisco Switch, just an AT&T VOIP / DSL Router Model 3800HGV-B, for Internet, Voice and TV, .
    Response for Dubravko, I have the power adapter (PWR-CUBE-3) from Cisco and it is 48V. That allows the phone to come on but it still does not recognize the AT&T Router. There is supposed to be some kind of configuration that has to be done to the 7906G phone itself, but I have no way to connect to a Cisco Router in order to change the setup for this phone. I downloaded the configuration software from Cisco but it will not work standalone. I was hoping to find a way to do it.
  • Dubravko May 11, 2010
    It power itself either by external power supply or by power supplied over ethernet by power-over-ethernet (PoE) enabled switch (sure solution is Cisco PoE switch, others check first for compatibility).
    Power adaptor is hard to find because is -40V DC (exactly), and is not so common.
    Which switch do you have ??
    Problem Solver:
  • 10 Answers
Then you need power adapter for Cisco 7960 IP phone ( -40V DC).
Cisco phones work best with Cisco, and sometimes ONLY Cisco switches.
One question which voice gateway you will use for your 7960 VoIP phone calls to go through ?
(AT&T probably supports only their IP Phones with special and usually hidden settings from end user)
Posted on Mar 19, 2009
Cisco 7960 turns it self off
Do you have a power block for the phone or are you getting power from a POE switch via cat5 cable?
How do you know you purchased a working phone? When was the last time the phone worked properly?
Any other information you can supply about your VoIp setup would help us troubleshoot the power issue with your phone.
Jul 17, 2012 | Cisco 7960 IP Phone
How can I clear / reset a Cisco IP Phone 7910
How to set a Cisco IP phone to factory default Reset configuration of Cisco IP Phone (7910, 1911, 7940, 7941, 7960, 7961)
To set the Cisco IP phone to factory default completes the following steps: should be completed:
For 7940, 7941, 7960, 7961 phones:
1. Power up the phone (unplug power cable and plug in again and hold the # key.
2. Release # when lights start flashing.
3. Press 123456789*0#.
4. Press 1 to keep network configuration or 2 to lose the network configuration.
For 7906G and 7911G phones:
2. Release # when MWI starts flashing.
3. Press 3491672850*#.
Oct 28, 2010 | Cisco 7910 IP Phone
The Cisco 7940 Phone...if you work from home and use this phone can your Corp office be able to monitor your calls?
It is possible for them to monitor voip calls, if your call passes through their network, or they do remote monitoring on network traffic. The voip traffic is only data that needs to be 'reassembled' to hear the voice stream. However, this is more difficult if the traffic is encrypted between the phone and the call manager or whatever they are using.
I am no legal person, but I am sure that you would have to have agreed to have your calls monitored for them to be able to do this.
Oct 11, 2010 | Cisco 7940 IP Phone
No dial tone on cisco 504G phone
to use an Ethernet phone you will need a VOIP supplier ( You will need to Google this for the country you are in ) . You will not be able to use it until you have these set up. Ethernet phones are not like a standard home phone which use your local exchange to route your calls they use servers on the internet to do that and route your call to landlines.
I hope this helps if so please give me a thumbs up
Jul 23, 2010 | Cisco SPA504G IP Phone
Can I use a CISCO IP 7941 phone, that has been on a company network, in my home? Should it just work by plugging in a telephone connection and using the appropriate power supply? Is there programming that...
Yes, there is programming which would need to be removed. However, you would need a cisco call manager($800) at home. Unless of course you have voip in your home. then you could just set it to DHCP I'm assuming and then it should just work!
Jan 14, 2010 | Cisco 7940 IP Phone
Cisco IP Phone 7940 and 3com nbx as 3rd party SIP phones
Here are the instructions for configuring these units for 3cx
http://www.3cx.com/sip-phones/cisco-7940.html
http://www.3cx.com/sip-phones/polycom-soundpoint.html
Since the 3cx softphone worked well, I don't see why you couldn't configure each as for 3cx and make them work as well.
Dec 09, 2009 | 3Com NBX 2102PE IP Phone
Button is yellow. Error msg Failed/No Response
I don't know about linksys but in Cisco you can use a TFTP Server Program, put the firmware that server, and boot up the phone. In Cisco it goest to the server and it uploads the new firmware.
Jun 18, 2009 | Linksys SPA942 IP Phone
Phone not connecting to pc
how to connect my wap/mobile phone to the internet
Mar 29, 2009 | Linksys VOIP Skype Cordless Phone Kit.
CISCO 7912 Ip Phone,Red lights are continuously on.
Well, in most Cisco VoIP phones those lights are used to tell you if you have a voicemail. Have you checked your vm and cleared any new ones? This might be your issue ;)
Oct 14, 2008 | Cisco 7912G IP Phone
Cisco 7906G IP Phone Logo
310 people viewed this question
Top Cisco Computers & Internet Experts
Prashant M
Prashant M
brian soufane
Are you a Cisco Computer and Internet Expert? Answer questions, earn points and help others
