Question about Yukon 24021 Monocular
Yukon spartan my pic is not clear light works but cannot get focu
Cannot get a clear pic
  • 4 Answers
Yukon spartanPut the batteries out for sometime and insert again,if did not work....try to read the user manual for it, you must have done something wrong
Posted on Mar 07, 2012
  • 571 Answers
Define 'clear'.
Is it blurry? Focus the scope or clean the lenses.
Is it distorted? Don't know how to fix. Especially if the lens is cracked/scratched etc.
Is it dark/snowy? Put fresh batteries in.
Do you see black spots in the tube? Don't worry, certain amount of these are quite acceptable.
Anyway: It's a night vision for pete's sake. The picture won't ever be like the one on normal binoculars.
Posted on Oct 24, 2009
Catalyst not ready on 2003 yukon
keep driving it.
it takes time once the codes are cleared for all the system checks to take place. This was done by the auto manufacturers to help eliminate the check engine light cheaters for emissions testing. Now the vehicle needs to be driven for enough drive cycles to satisfy the engines computer that everything is working properly.
Mar 07, 2015 | 2003 GMC Yukon
2000 gmc yukon no rear tail lights but brake light works
I had the same problem with my 2000 Yukon. I disassembled the tail light and pulled the bulb contact strip out. The dielectric grease on the sockets were dried up and hard. It had caused a loose connection and overheated the plastic. I managed to clear the old grease out with a pick tool and brake cleaner. I put in new grease and it still works. I noticed later that Advance Auto has the contact strip for sale. I hope this helps.
Nov 17, 2012 | 2000 GMC Yukon Denali
Engine light on 2005 yukon
{: ) An engine light indicates a fault has been detected on your emission systems. If the fault is current, it will stay on, or even flash. There are times when it will stay on even if the fault is not there anymore. That's why cycling the ignition on and then off helps in clearing the engine light. If it clears, that means the the fault has been corrected and cleared. However, if the engine light comes back again, then there's really a problem. It can be caused by several things, that's why a scan tool is recommended to determine the codes that have been set by a module. These codes aid in quicker diagnosis and repairs.
Aug 01, 2011 | 2005 GMC Yukon
We have a Spartan American Design bathroom exaust fan & the motor is shot. Spartan is no longer in business; is there somewhere that we can purchase a motor?
Honestly with the cost of motors it might just be cheaper to replace the whole unit. We have a Spartan model 760 that's working on dying on us now - we are going to replace the entire unit.
Dec 29, 2010 | Home
I cant view the picture clearly while shooting and playback too.i was on a picnic 2wks back,and was taking pictures with my canon SD550 POWERSHOT CAMERA.. all of a sudden the display in the screen blurred...
There is a focuing ring with electromagnets on it, and it swivels to focus. When sand, dirt, lint, or dust works its way into the lens assembly, it can get stuck, failing to focus.
Spray some compressed air into the lens area to try to dislodge it. Then bump it gently if the compressed air doesn't work. Here is a list of things you can try for a jammed lens:
http://camerarepair.blogspot.com/2007/12/fixing-lens-error-on-digital-camera.html
If these don't work, your focus ring is jammed and you will have to fix it or have it serviced. Get an estimate first, since the cost of repair often justifies buying a new camera.
Good luck, these tips might help you.
Aug 27, 2010 | Canon Cameras
How do you reset the check engine light on a 2003 gmc yukon xl
the check engine light means you have a trouble code in your vehicles computer. After fixing the problem with the yukon the check engine light can be reset sometimes by disconnecting the battery and disconnecting the ECM fuse. Although some parts stores are known to check your codes for free they might also clear them with a scan tool.
Feb 26, 2010 | 2003 GMC Yukon XL
Spartan 12v solenoid terminal polarity
There are about 3 dozen series of the Spartan solenoid, can you be more specific to the model or series please?
Feb 22, 2009 | Electrical Supplies
2002 Yukon XL - No Headlights
Check the headlight fuses in the engine fuse box compartment. Not sure if the lights have relays, but they will be clearly mark in the inside of the top cover for location.
Aug 23, 2008 | 2002 GMC Yukon XL
Yukon 24021 Monocular Logo
277 people viewed this question
Top Yukon Optics Experts
John Porter
Wally Jackson
Wally Jackson
Are you a Yukon Optic Expert? Answer questions, earn points and help others
