Question about Sanyo BC-1206 Commercial Beverage Dispenser
Compressor Does Not Seem to Start
My Sanyo BC-1206 is plugged into a normal wall socket and I can hear a periodic click (which I assume means electricity is flowing to the machine), but I never hear the compressor kick on. The fridge stays kind of warm as well. Is there something I can do to see why the compressor never kicks on?
  • rtcolo Feb 20, 2009
    chack for light to confirm power.... It sounds like your compressor relay.....
    President:
  • 1,462 Answers
Feel the compressor. if warm then it is being powered up and symptoms point to a compressor fault. it is also possible that the compressor start device is faulty. remove cover over compressor electrics and check for any distressed componants
Posted on Jun 22, 2007
Sanyo repairs built-in transformer
Most refrigerators draw up to 12 amps on a lock-rotor.. meaning it reached temperature, and turned "off" there needs to be 5 or 10 mins, before the compressor can restart due to hi-pressure inside the condenser . usually you will hear the fan(s) come on, it makes a "click" sound trying to start- that's called a Lock rotor. when People seem to have problems asking about how many Amps. it's because they trip their house breaker. I will assume and respond under that pretext - 1) 15 amps minimum on a dedicated line, means only that item. 2) house breakers weaken over time and will trip - here's how you can tell the difference If your breaker trips the instant you plug in your refrigerator.. 90% probable problem with refrigerator, a short somewhere is causing the breaker to open the circuit . if you plug in, and Refrigs runs for any length of time, and then the breaker trips. The refrigerator is combing it's consumption of Amps, contributing them with something else so together they exceed the rated voltage or you need a new breaker.
Nov 29, 2013 | Refrigerators
Whirlpool eet171pk relay switch
do you mean the compressor won't start and you hear a clicking sound every few minutes?if so most likely the start device on the compressor is bad,you have to send the model number off of the machine,if it's a bottom mount or side by side,open the fridge door and look on the right side wall up near cieling and you'll see a tag with model and serial numbers,if the freezer is a top mount open the fridge door and look on the left side wall up near cieling and send model number so someone can look up your machine.have you vacuumed out the coil,if the coil is filled with dust the machine will run hotter than normal and can damage the start device and the compressor.
Sep 30, 2017 | Whirlpool Refrigerators
Kitchenaid KSCS23IN Burning Hot Divider Wall then No Compressor, No Fan, No Cold Can Hear Clicking
The clicking is caused by the clixon turning off power to over heated motor that is not starting. Check the condition of the starter cap or relay and change. If a good cap or relay does not start your compressor then the rotor is frozen and you need a new compressor. (ouch)
Mar 12, 2017 | KitchenAid Superba KSCS23IN Side by Side...
WILL NOT COOL OR MAKE ICE. COMPRESSOR DOES NOT SEEM TO COME ON.
next time send the model number off of the fridge,side by side or bottom freezer model number is in fresh food section,right hand wall up near ceiling or on ceiling,top freezer look on left side wall.if the compressor isn't running most likely you have a bad start device located on the side of compressor,pull out the fridge,unplug it,remove the back outside bottom panel and you'll see the compressor,pop off the metal clip,remove the cover and slide off the start device or overload and relay same thing,then shake the device,if you hear pieces rattling around inside it it's bad,easiest way to check it,if you open the freezer door and you hear the fan blowing around most likely this will be your problem,you might hear the compressor clicking trying to start and it will be hot,also vac out the condenser coil and make sure the condenser fan motor is running good,over heating can take out the start device.good luck.
Jul 05, 2012 | Frigidaire Refrigerators
Does not get cold enough.compressor is running ,coil is clean.
Sounda like you have a slight freon leak and need to give that thing a shot of juice to jack it up...
heatman101
Aug 17, 2010 | Sanyo BC-1206 Commercial Beverage...
Older Amana upright freezer, I think that is 18 cu ft in size. It started making a clicking noise....I assume when the compressor is trying to start, it sounds like it is trying to start, but cannot
Hi, the clicking you are hearing is the compressor overload/external overload. When your compressor is a burn out or you have a locked rotor which means the compressor has died on you, it gets very hot from trying to start and this relay which is tied into the common side of the common terminal on the compressor, will click on and off as the unit tries to start. I have repaired these units for years and know exactly what is going on and the unit is older as you say. I would suggest pricing a new box as changing out the compressor, you are looking at around $1800.00 and up. I hate to tell you this but this is the problem. If you want to confirm this, just pull the unit out from the wall and try to leave it plugged in. Remove the lower panel to excess the compressor, condenser fan motor, and coil. Just be careful as this compressor should be very, very hot when you put your hand on it. Then you will know that is the problem. It should be warm and running. Please keep me posted and I hope I have been of help to you. Didn't want to give you the bad news though.
Good Luck, and Sincerely,
Shastalaker7
Mar 20, 2010 | Freezers
It appears the freezer is not keeping the food cold enough and there is an occasional clicking noise underneath where I'm assuming the compressor is. Could this be some type of relay problem? This is a...
The clicking sound your hearing is the compressor trying to start but is not completing the start cycle or achieving run speed so the KliXon thermal overload is tripping trying to protect the compressor.
This can be caused by a bad start relay / Klixon,
A bad run capacitor or...
The bad news a bad compressor.
Letting it just click click click is not a good thing and will cause more damage. Unplug the unit for about 30 mins and then plug it in see if it starts normally.
There can be yet other issues like a defrosting timer contact problem that got weak / hot and isn't allowing enough amperage through to start the compressor.
Jan 28, 2010 | Kenmore 57029 Side by Side Refrigerator
Dont have a plug for my sanyo eceltric rice cooker
try going to there web site and ordering it,, or go to the store where it was purchased,
May 30, 2009 | Sanyo Kitchen Appliances - Others
Sanyo sr-1013w not cooling
sounds like it has a refrigerant leak somewhere in the unit.
Feb 20, 2009 | Sanyo BC-1206 Commercial Beverage...
Does not cool. Compressor Hot
Sounds like the compressor starting relay. This should be available from from most appliance parts retailers that carry refrigeration parts. It is probably a plug-in relay which is easy to replace. PULL THE PLUG UNTIL YOU GET IT! Constant cycling on the thermal protector will damage the unit.
Ray
Oct 19, 2008 | GE PWR04FANBB Wine Cooler
Sanyo BC-1206 Commercial Beverage Dispenser Logo
176 people viewed this question
Top Sanyo Refrigerators Experts
John Tripp
John Tripp
Marvin
Marvin
Charles T Nevin
Charles T Nevin
Are you a Sanyo Refrigerator Expert? Answer questions, earn points and help others
