Question about GE Spectra JGBP35 Gas Kitchen Range
GE XL44 oven and broiler do not work
I have replaced gas valve once before and took two gas valves before I
found one that worked. The replaced valve worked for about 6 months
and has now failed again along with the electric igniter.
  • 1,543 Answers
It is very rare for gas valves to fail. Most non-ignition problems are due to old igniters which no longer draw enough amperage to allow the gas safety valve to open. You might also consider testing your voltage with a digital meter, as lower voltage will cause ignition problems also. (say 110 volts instead of 120) Replace the igniter.
Posted on Jan 17, 2009
My GE xl44 gas range broiler won't work,
The ignitor is not working right and is going bad....
have the repair man replace the ignitor, or DIY....
Check out this tip about your problem...
Oven not Working or Oven not Heating
Oven Problems Replacing the Igniter
heatman101
Jun 02, 2011 | GE Profile JGB900 Gas Kitchen Range
GE XL44 gas oven we replaced the ignitor and the oven does not work the broiler does
Hi, this could still be a defective igniter, to verify you need a volt meter. The voltage being delivered to the oven gas valve must be at least 3.1 volts ac. Anything less and the valve operation is unreliable. If you have 3.1 to 3.3 volts to the valve when the thermostat is calling for heat and no gas, the valve needs to be replaced, If the voltage is lower, change the igniter.
Feb 02, 2010 | GE Profile Spectra JGBP90 Gas Kitchen...
Gas oven is not working but broiler is working
The problem usually is the ignitor. Even if it glows it may not be pulling enough current to open the gas valve. They also are very fragile and break easily.
This tip will help you also.
Oven not Working or Oven not Heating http://ping.fm/mEg1i
Heatman101
Jan 27, 2010 | GE Ovens
The oven pilot does not light. The broiler will not work. The only thing that does is the light. GE XL44 range. The burners light and the pilots stay lit.
    If you have standing pilots, make sure the pilot for the oven/broiler is lit as well.  When you turn the thermostat up to call for heat, you should see the pilot get larger. That larger pilot flame heats a hydraulic sensor and opens the main burner valve.
    Jan 10, 2010 | GE Profile Spectra JGBP90 Gas Kitchen...
    Lower oven burner will not light.
    Hi I have a older GE that the oven won't light. It is a gas range that is electric ignited. The top burners do work but the oven will not light. Is it pricey to have this fixed?
    May 28, 2009 | GE Profile Spectra JGBP90 Gas Kitchen...
    Oven and Broiler not working
    The gas supply valve to the oven/broiler is the likely culprit. It is a separate valve from the stovetop. I've had the same problems and had to replace mine twice now. They are very expensive, (about 100 dollars) considering the cost of the whole stove. It is located
    inside the broiler drawer on the very back wall.
    Jan 01, 2009 | GE Spectra JGBP35 Gas Kitchen Range
    Whirlpool SF377PEGQ 0 ,Gas Oven not igniting...
    if you have 120 v to ignitor then ignitor is bad.
    Dec 26, 2008 | Kitchen Ranges
    GE Oven does not ignite, bute Broiler does.
    Your problem is with the oven igniter. You have the stove MODEL# so you should have no problem finding the part you need.Shop around to get your best price. Good Luck Friend.
    Oct 14, 2017 | GE JGRP20 Gas Single Oven
    GE spectra xl44 - Oven not working, broiler & stove-top burners fine
    replace the ignitor for the oven. it's the lower one and not the one on top.
    Oct 28, 2008 | GE Profile Spectra JGBP90 Gas Kitchen...
    Xl44 gas
    two things either hte clock(control ) assy not sending powerdown to the igiotr, or hte valve that the ignitor is connected to onst nay good, unplugh the unit andwitha meter try testing the 2 wire connections on the top of the safety valve( i wire goes to the ignitor nad the other is a neutral wire htt hooks downt to under the valve for the broiler, you should show continuity across those to leads, if not your valve is no good and will need replacing
    Mar 20, 2008 | GE JGRP17 Gas Single Oven
    GE Spectra JGBP35 Gas Kitchen Range Logo
    232 people viewed this question
    Top Kitchen Ranges Experts
    Dan Webster
    Dan Webster
    Ismael Rodriguez...
    Mike Carew
    Are you a Kitchen Range Expert? Answer questions, earn points and help others
