Question about Microsoft Xbox 360 Console
Component Cables not reading
I bough my system and the component cables have never read. The Xbox site is no help, as I tried two different cables and the dashboard restart (Y plus right trigger), and I am just about stuck.I have a LCD Tv, so its not like I'm asking miracles! I've tried different tv's and different cables and nothing works! Am I screwed?
    Scholar:
  • 47 Answers
I don't want this answer to sound stipid, but are you sure you changed she ntsc to component switch on the back of the cable (unit side). Have you tried the unit in the normal composite mode, yellow, red and white. (low def)? X-box 360's are quite buggy Let me know if it works in the composite mode. Then we can go from there. I sell these units and have run accross some real crazy problems with them. Scrivitron
Posted on Jun 21, 2007
How do I hook up Xbox 360 to the HDTV
Step 1:
Connect the audio/video input of the component cable into the "A/V" port located on the back of the xbox 360
Step 2:
Match the red, blue and green cables on the other end of the component cable to the corresponding component ports on your HDTV. If your HDTV has more than one set of component inputs, make note of which one you use.
Step 3:
Slide the switch on the component cable to "HDTV."
Step 4:
Turn on your HDTV. Set the video mode to the component port that will be used. HDTVs with multiple component ports will usually be labeled "Component 1," "Component 2" and so on
Step 5:
Turn on the Xbox 360. Go to "My Xbox." Select "System Settings" then "Console Settings" then "Display" and then "HDTV Settings." Choose the display setting (720p, 1080i and 1080p) that is best compatible with your HDTV. If you're not sure, try them all until you find the one that looks best.
Step 6:
Disconnect any previously connected A/V or component cables.
Step 7:
Connect the HDMI AV cable connector to the "HDMI AV" port on the Xbox 360.
Step 8:
Connect the other end to an available HDMI port on your HDTV. If your HDTV has more than one HDMI input, make note of which one you use.
Step 9:
Turn on your HDTV. Set the video mode to the HDMI port that will be used. HDTVs with multiple component ports will usually label them "HDMI 1," "HDMI 2" and so on.
Step 10:
Turn on the Xbox 360. Go to "My Xbox." Select "System Settings" then "Console Settings" then "Display" and then "HDTV Settings." Pick the display setting (720p, 1080i and 1080p) that looks best on your HDTV.
Dec 26, 2012 | Video Game Consoles & Games
When i turned my tv on to play my xbox 360 with component cables, my tv says ''not supported''?
Some after arket component cables only support high def, if your tv is standard def it won't work. I'm not sure if this is your problem, but it's worth looking into.
Mar 03, 2010 | Microsoft Xbox 360 Pro System Console
XBOX 360 composite output works fine. Component
You say the component video is no good? Well this usually happens when it is wired up incorrectly, Ensure you have the right colors in the right jacks at each end, it is real easy to get mixed up... make sure Red goes to Red, Blue to Blue and Green to green, all alongside each other, NO ALSO using Component you MUST also run 2 more cables for the Audio, they are Red & White NOT the Red from the "Other" Video input, BUT the AV Red & White jacks, beside each other on the units. So all in all there are 5 cables taking the Video, 3 R, G, B. + The Audio, R & W.
Mar 02, 2010 | Microsoft Xbox 360 Console
White stripes on tv screen
Could be either really, you are using the component cables that came with the console correct? The lines look identical on both screens? If so then you are on the right track but I would lean towards the xbox360 being the culprit. I would bring your 360 into a local video game store and nicely ask them if they could hook it up to one of their TVs (they have them to test consoles people trade in), with their component cables and see if they have the problem as well. If they do you know it's the xbox and not the cables, if they don't then it sounds like you have a cable problem.
Jun 26, 2009 | Microsoft Xbox 360 Console
Xbox 360 hdtv connection help!!!
Yes, you will need HDTV compatible AV cables.
Jun 25, 2009 | Microsoft Xbox 360 Console
Component cables on HDTV not working
have you tried hooking a different video source upto to the tv to make sure it is not the dvd player that is not giving a signal to the tv?  Like an Xbox 360 or anything else with component output.
May 13, 2009 | Samsung TX-R2678WH 26" TV
Xbox360 -after 5 minuetes of use ,no video - just sound
Red ring is not the only problem with Microsoft Xbox 360. This amazing device also has some more common problems like Audio but no video problem, disc read error etc. Microsoft is providing extended warranty only for red ring problem. Means you will have to spend some money to get this problem repaired also if you plan to send your xbox to Microsoft, you will have to wait for 3-4 weeks to get back your favourite Xbox. There is one more option in the form of DIY guide, this guide explains solving No Video problem with step by step instruction, so any novice can fix this problem
Mar 30, 2009 | Microsoft Xbox 360 Console
How I hook up an XBOX 360 to digital converter box (TV does have yellow/white/red jacks). Also have rabbit ears for antenna. Thank you.
you don,t , the xbox 360 will have component cables and posibly an hdmi output , but you can plug the component cables directly to the tv in a auxillary input and on your menu screen it will either say video1 or video2 or video 3 ,you can put the cables from your xbox into those inputs on the tv and as long as your tv is also at that input you should have a signal , hope this helps ,glenn
Mar 02, 2009 | Insignia Digital-to-Analog Converter for...
Screen randomly flashes black
First and foremost you need to change one of two things. Either your video output settings on your xbox 360, or use an hdmi cable as opposed to component cables. Component cables are only designed to output video up to 1080i, not 1080p(big difference). So if you try to run a output signal of 1080p with cables only made to send 1080i, you will have picture issues.
Nov 23, 2008 | Sharp Aquos LC-32D40U Television
Xbox in game 'blinking'
Was the system hooked up to an HDTV with component cables and then moved to a non hdtv? I had a similar problem when I changed my xbox from the hdtv to the non hdtv. I fixed it by using the RCA cables that came with the xbox and not the component cables that I bought from best buy.
Apr 11, 2007 | Microsoft Xbox Console
Microsoft Xbox 360 Console Logo
Top Microsoft Video Game Consoles & Games Experts
Stormi  Paulk
Stormi Paulk
Paul Castley
Paul Castley
Are you a Microsoft Video Game Console and Game Expert? Answer questions, earn points and help others
