Question about Whirlpool 5"x36" White Bathroom Drop-in Bathtub Spa Jet
Power switch for whirlpool tub
Is is possible to replace the old power switch/timer on our whirlpool tub with one that has a remote control? Our tub is 21 years old and the switch is on the wall across the room. If so, where would you buy it?
  • just-m Jan 21, 2009
    I have a Kohler vintage 1985with the same problem. After much reasearch I came up dry and built an override which allows me to turn on the tub when the water level is correct and keeps it on until switched off or the water level drops.
  • 125 Answers
The easiest thing (maybe) is to install an air switch kit on the side of your tub. Here is a link to the part. Basically you install an air button on the side of the tub, install the air tubing from the nipple on the underside of the air button to the nipple on the box that plugs into an outlet under the tub. The pump plugs into that same box and the air tubing from the air button pushing onto the nipple on the box. When you push the button on the tub it will turn the pump on/off. Air Switch Kit
Posted on Feb 24, 2009
    New Friend:
    Problem Solver:
  • 6 Answers
Yes because its electrical and live .. doh the air switch is similar to the button some depress to start their garbage disposal the only thing that your hand touches is a button that's not live it moves air thru a tube that actually flips the switch on so to speak cannot get shocked meets electrical code and you don't get out of whirlpool top to restart another session dee dah
Posted on Nov 09, 2014
2 Suggested Answers
  • 10865 Answers
SOURCE: I have a 21 year
The switch is located there to comply with the electrical code. I recommend that you leave it as is.
Posted on Jan 19, 2009
Whirlpool Washer model # LSN1000KQ0 overfilling
did you plug the hose back into the water level switch, double check to see if it is plugged, if it is your water level switch might be defective. trouble shoot by taking the front panel off... turn on the washer by using the timer, set water level to small...on the bottom of the tub housing there should be a nipple where the clear hose connects onto.....follow the clear hose from the switch down to the bottom of the tub.........disconnect the clear hose on the bottom of the tub.....plugg the nipple with your finger.........gently blow into the hose with your mouth.......but make sure the water level in the tub is at least at half way full...and the washer is on and filling up with water ...after you blow into the hose the washer should agitate.......if it does agitate your water level switch is defective...connect hose back........get your model number and source for the switch.........
Apr 10, 2010 | Whirlpool Washing Machines
Whirlpool calypso
this possibly a bad contact on the panel board, thats why the system malfunction by itself. better to check on the every switch contact and clean for any moisture on the board.
Oct 31, 2008 | Whirlpool Calypso GVW9959K Top Load Washer
Tip
How to service a temperature switch
This control panel switch regulates the temperature of the water in the tub. It also plays a role in controlling the fill cycle. If you suspect this switch is faulty, remove it and hook a test wire across the switch terminals. If water flows, the switch is faulty. If the switch is faulty, replace it with a new one of the same type. Connect the new switch the same way the old one was connected.
If there's a problem with both water temperature and tub filling cycles, both the temperature switch and the timer may be faulty. Test both components and replace them as necessary. Procedures for testing the timer can be found below.
on Jan 16, 2010 | Washing Machines
Washing machine stops half way through the cycle
When the cycle doesn't advance, it's probably the timer or a cold-water supply problem:
  • It's the timer, if your washing machine fills with water and begins agitating, but the timer never advances--or if the washer is in a spin cycle and the timer won't advance. Then you need to replace the timer.
  • It may be a cold-water supply problem, if the washing machine fills with water, agitates, drains, and spins, but then doesn't fill with rinse water. See There's no cold water.
Aug 30, 2009 | Whirlpool AWM6100 Front Load Washer
Kohler Whirlpool tub motor wont turn on
We had the same thing happen to our Aker brand whirlpool tub.  The fix was a replacement timer/control piece which is connected by two wires to the pump behind the tub (access wall) and plugged into the outlet; however, this cost $150 for the part and $85 for the service call (all he did was take the part out and ship me the replacement part which was easy to do).  Problem I have now is that the motor won't shut off unless I unplug it.  I am waiting for a call back from the repairman who sent me the part.
Jan 11, 2009 | Kohler 1209-LA-0 Hourglass Whirlpool with...
Whirlpool duet washer f-27 code error
hi Most washing machine timers are digital or mechanical. The timer controls most of the operations of the washer: water level, tub filling and emptying, length of cycles, and cycle setting sequences. For this reason, any repairs to the timer should be made by a professional service person. However, there are a couple of checks you can make when you suspect the timer is faulty -- you may be able to install a new timer yourself.
Step 1: Unplug the washer. To access the timer, remove the control knobs and the panel that covers the controls. This may be a front panel, or access may be through a panel at the back of the unit. Carefully examine the wires that connect the timer to the other parts of the washer. If the wires are loose or disconnected, try pushing them into position; they usually fit into their terminals like plugs. Use long-nosed pliers to avoid breaking the wire connections -- never pull a wire by hand.
Step 2: To test the timer, use a VOM set to the RX1 scale. Disconnect the power leads to the timer and clip one probe of the VOM to each lead. The VOM should read zero if the timer is working. Since the timer is a multiple switch, turn it through its cycle and test each pair of terminals in turn. The meter should read zero at all of these points. If one or more readings are above zero, the timer is faulty and should be replaced.
Step 3: To replace the timer, unscrew and disconnect the old one. Install a new timer made specifically for the washing machine. If there are many wires on the timer, have a helper hold the new timer next to the old one as you work. Disconnect the old wires one at a time, connecting each corresponding new wire as you work, to make sure the connections are properly made. Or, draw a diagram showing the connections before removing the old timer. After all the wires are connected, check the connections again for correctness and screw the timer assembly into place.
Nov 06, 2008 | Whirlpool Duet GHW9150P Front Load Washer
Whirlpool RSB21 possible power outage.
Sep 13, 2008 | Whirlpool Gold White-on-White 21.9 cu. ft....
Changing timer in whirlpool washer model number LSR7010PQ2
two phillips screws on the front bottom of the control panel will release it.......pull it forward and flip it up...........remove the knob and by pushing in and turning counterclockwise.......then remove the dial to reveal the timer screws.....remove those and disconnect the wiring harness.....replace the timer and reinstall all parts......
Jul 28, 2008 | Whirlpool Washing Machines
Good power, tub will not turn
tub, is the lid switch plugged in? If not take a jumper wire and jump out the two ends on the harness. Timer controls recirculation and spin. The motor turns both ways. The spin cycle goes through the lid switch. Catriver..post back
Feb 27, 2007 | Whirlpool LSQ8000 Top Load Washer
Whirlpool 5"x36" White Bathroom Drop-in  Bathtub Spa Jet Logo
4,927 people viewed this question
Top Whirlpool Home Experts
Donni Steen
john h
Mike
Are you a Whirlpool Home Expert? Answer questions, earn points and help others
