Question about SanDisk Sansa m230 MP3 Player
Freezing I have a Sansa m230 512mg mp3 that after a few minutes of playing will freeze up and give off a high pitch sound, none of the buttons will work and have to take the batteries out to turn it off. Is there a way to reset or something else?
  • 85 Answers
There is a reset and you can log on to sansa and they have the software you need to fix it. if not, the best thing you can do is buy a new one. sometimes you can download a corrupt file, which causes damage. connie
Posted on Jun 22, 2007
Sandisk sansa mp3 got freeze
Press and hold the Power On button and the Play button (>||) for 20 seconds
Jan 04, 2010 | SanDisk Sansa Clip MP3 Player
Screen frozen when powered on
turn it off, take out the battery, then replace it, turn it back on. see if this helps.
Mar 15, 2008 | SanDisk Sansa m240 MP3 Player
My mp3 freezes up after playing awhile
Usually freezing is resolved via a firmware upgrade - check the manufacturer's website. Sansa players are manufactured by Sandisk.
Feb 28, 2009 | SanDisk Sansa e200 MP3 Player
My sandisk sansa fuze is freezing up is that normal?
Yes, it sounds like its faulty, even if its not, why take the chance when you can just return it. Depending on where you got it, you should be able to return it for a swap. Just make sure you have your receipt. Most places will require that you have it.
Nov 18, 2008 | SanDisk Sansa Fuze MP3 Player
My Sansa e260 is freezing after few minutes of work
Sometimes holding the power button for about 30 seconds will make it reset itself. Then you can push the power button again to turn it on. It works for me so you might as well give it a try.
Oct 24, 2008 | SanDisk Sansa e260 MP3 Player
Sansa e250R - Will pwr up but only freezes on screen that says..."Sansa Rhapsody"
You can try to reset the device by pressing the power button for about 15 to 20 seconds..if that doesnt work I would recommend you to go to the sandisk site to update the firmware on your device or you can contact sandisk to they can help you with updating the firmware on your device..Please follow the link below to get the firmware
http://www.sandisk.com/Retail/Default.aspx?CatID=1376
The number for sandisk is 1-866-726-3475
Please rate accordingly
Thank you
Computerrep
Jul 28, 2008 | SanDisk Sansa e250 MP3 Player
IT TURNS ON BUT WONT PLAY MUSIC
These are the most common methods for recovering Sandisk's Sansa Mp3 Players. I have been almost universally successful in recovering Sansa players using one or a combination of these methods. These methods do not work if you are having synchronization or music format issues - they are for recovering a player that will not power up, freezes, flashes, is not recognized by the computer, and a host of other issues.
Reset the Sansa Player first. On most models, restart is done by holding the power button in for 15 seconds or longer. Check your specific manual to be sure. The manuals are available from the Sansa website if they have been misplaced.
Download the Sansa Recovery Tool from the Sansa website.
Format - Erases Everything: Connect your Sansa player to the computer and open Windows Media Player. Click on the Sync tab. Pull down the drop down menu underneath the Sync tab by moving your cursor over the Sync tab and left clicking on the little black arrow underneath the Sync tab. Highlight "Sansa 1GB" (wording may vary slightly), and then select "Format." - this should erase everything.
Firmware Upgrade- Erases Everything: Get the latest firmware upgrade from Sansa - it updates the firmware and erases every song in the player all at once. Note: this method doesn't work if already have the latest firmware. Go to this website and click "Firmware Updater" to find out: http://www.sandisk.com/DriverDownload/driverList.asp
If these fail, then:
Try this: disconnect the player from the computer, turn it off, hold in the volume + button, and reconnect the player to the computer while holding the volume + button in. Keep holding the volume + button for an additional 5-50 seconds. Windows should eventually go into recovery mode and revive the player- it will pop up a window that says Found New Hardware Wizard.
If you get the problem where MTP Device keeps popping up continuously, uninstall the “MTP Device” by going to Start à Control Panel àSystem à Hardware à Device Manager (you computer may vary slightly, depending on Windows Version).
You may have to restart your computer after each of these methods to get them to work properly. Disconnect your Sansa player BEFORE shutting down your computer.
-Tha Mp3 Doctor
May 03, 2008 | SanDisk Sansa Shaker SDMX9N-512 MP3 Player
Player frozen
Sounds like the processor inside got fried.
There is a reset button on the back, just below the label. Press that in with a paper clip and see if anything happens.
Feb 13, 2008 | Samsung YP-U2JQB MP3 Player
Player freezes randomly whenever I play any video
Sounds like it's froze and needs to be reset. -
Press to power on/off, enter menu, or hold 15
seconds to reset your Sansa.
Or-To reset the sansa = Hold down power button for20 seconds.
If that don't work let me know so i can try something Else? P.S. Please rate accordingly
Thank You
Computerrep
Feb 01, 2008 | SanDisk Sansa e260 MP3 Player
Sandisk sansa c240 mp3 player voice recording problems
Try the latest firmware upgrade from the Sansa website
Aug 03, 2007 | SanDisk Sansa c240 MP3 Player
SanDisk Sansa m230 MP3 Player Logo
41 people viewed this question
Top SanDisk Audio Players & Recorders Experts
Joe Negus
Joe Negus
Gyula Lacz
 Ben
Ben
Level 1 Expert
Are you a SanDisk Audio Player and Recorder Expert? Answer questions, earn points and help others
