Question about Ahead Software Nero Express 6.0 (NERO6OEM) for PC
Help !! no nero plugin ,can not burn dvd's
Hi i've just discovered that my version of nero 7 ultra edition has not got the nero fast burning cd/dvd plugin installed .. and when i go to modify the installation to install the plugin .. it says that it cannot find the installation files to complete the process .. is this why my dvd's wont burn any more??
any decent help would be appreciated thank you
  • 1 more comment
  • tony dove
    tony dove Jan 18, 2009
    yes man i chose the dvd burner.. i made sure of that !
    thanks for the quick response though i appreciate it .
  • tony dove
    tony dove Jan 19, 2009
    yes strippy i have reinstalled it but it wont install the plugin tho ... weird!!! and copying the files like you suggesred wont work for dvd's only cd's
  • Anonymous Feb 03, 2009
    hi my name norma i have the same program.i can not burn on my dvd burner
  • 55 Answers
Hmm, this might be a stupid sugestion, but, did you chose your DVD burner, or did you chose Write an image file?
in one step, it says you got to chose ur burner, or your image writer...
check that...
Posted on Jan 17, 2009
  • Vanja Djuric
    Vanja Djuric Jan 18, 2009
    did you try reinstalling it? or, try another burner? for example, Cyber
    link? in general nero is not that thrustfull... if you are using win XP
    you can yust copy your files to cd, and click write these files to CD,
    it goes much faster, than with nero...
  • Vanja Djuric
    Vanja Djuric Jan 19, 2009
    so now, you cant burn DVD-s at all? because, fastburning sounds kinda silly... every CD, or DVD has its own limit, or writeing speed... i dont think you should increase it, there is a large possibility that it won't write your data correctly...
2 Suggested Answers
ziraffa
  • 827 Answers
SOURCE: plugin not in nero
You should uninstall Nero, download nCleaner and install and run it.
Now click Clean System and Clean Registry. Don't change the default settings, just tick yes each time.
Now exit.
Now reinstall Nero or download ImgBurn and use that instead.
If it still doesn't burn disks, you need to either Repair your system with a system disk, or delete the lower and upper filters for the disk drive, in your Registry.
Try deleting UPPER FILTERS and LOWER FILTERS
> Click the Start button, click Run.
In the Open box, type Regedit, and then click OK.
> Click the plus sign (+) next to HKEY_LOCAL_MACHINE.
NOTE: When you click the plus sign (+) next to a folder, it will expand displaying the folders it contains in the left-hand pane of the Registry Editor. When a folder is highlighted, its contents will be displayed in the right-hand pane of the Registry Editor.
Click the plus sign (+) next to SYSTEM.
Click the plus sign (+) next to CurrentControlSet.
Click the plus sign (+) next to Control.
Click the plus sign (+) next to Class.
Click {4D36E965-E325-11CE-BFC1-08002BE10318}.
On the right hand side of the window, click UpperFilters.
Click Edit on the menu bar.
Click Delete, and then click OK.
On the right-hand side of the window, click LowerFilters.
Click File, and then click Exit.
Restart the computer normally.
Note: sometimes it does not have both the Upper and Lower filter. if you only have one of them then just delete it.
Hope this helps
Chris (ziraffa)
Posted on Jan 18, 2009
Our Nero 6 is not compatible with windows 7 so I cannot do the set up with the disk
If you want a burning software there are a lot others that work with & and are free. Just choose this one:
http://www.softpedia.com/get/CD-DVD-Tools/Data-CD-DVD-Burning/CDBurnerXP-Pro-beta.shtml
Jun 17, 2010 | Ahead Software Nero 6 Ultra Edition...
Tip
Nero 7 Ultra Advance-to-Time Index Problem Work-around
Posted under Nero 6 Ultra because there is no Nero 7 Ultra listing here on Fixya...
OK, I am going to tell you how I managed to work around this problem. I am posting this in the hopes it will save someone else the aggravation I had in stumbling around trying to find a procedure that would fix the problem. I found a work-around I can live with, so here's the problem and the solution follows. If it applies to you, I hope it makes your DVD-burning life livable again! Oh yeah, looks like Nero 8 is ready to come out soon. Just when you though it was safe.... anyway, here goes:
The Problem:
Burning DVDs using Nero 6.2 on Win ME was successful, and it allowed for advancing via time index. For example, I would burn a DVD and be able to go to any time point in the scene. However using Vista and Nero 7 Ultra, while DVDs burn successfully, the advance-by-time index is no longer available in DVDs burned under Vista with Nero 7. Details:
DVD burner: Buslink DBW1647-U2
O/S: Vista Home Basic
S/w: Nero, Ver. 7 Ultra, registered
DVD media: 16X Starlogic DVD-R
DVD player: Goldstar VM681M
The scenario is this:
1. Begin playing a chapter on the DVD
2. Click the chapter menu button on the remote.
3. Use up-down arrow keys on remote to try to get to timed index setting (ie, the one where if you select it and type "10:00" it will jump the scene to the 10:00 mark).
4. Can't select that option.
The Work-around:
1. Open Nero Vision and choose to create a DVD.
2. Access the Options by clicking More>> and make sure Nero SmartEncode is set to 'Disabled'. I think since Nero wants to convert everything to MPEG-4 that that might be a factor. Also, you may need to get some codecs, too. I am using the K-lite full pack available here: http://www.digital-digest.com/software/k-lite_codec_pack.html (Note that K-lite doesn't like other codec packs being on the same PC as it-- it nagged me to uninstall the DivX and Vista Codec Packs, and I did. I have discovered no problems so far since.)
3. Add your video files and step through the rest of the process. Settings to look out for: Automatically create chapters: NOT checked, Enable Forward/Backward Jumping: checked.
4. On the last screen, choose to Write to Disk instead of burning to the CD drive-- select a place to save the DVD-compatible files. Click "Burn" and off you go.
5. After your DVD files are written to disk (they will be in a folder called TS_VIDEO in the place you chose to save them to), fire up a copy of ImgBurn (http://www.imgburn.com/). [Maybe Nero's image burner will work too, I just haven't tried it. In any case this is known to work so I am using it here.]
6. Switch Mode to Build -- you need to build an .iso image file in order to burn it to DVD -- and select the TS_VIDEO folder holding your Nero-ed files. Indicate a name for the output file and run it. This should not take nearly as long as Nero took in creating the raw DVD files. The .iso file you created will be close to the same size as the raw DVD files are in the TS_VIDEO folder Nero created.
7. Now switch mode to Write and indicate the .iso file you built as the input and select the target DVD drive you are using, then run it. The burn process should not take long, either, compared with the other steps.
8. Test it in your DVD player-- you should be able to jump to time indexes now.
I have no idea why this works as opposed to the transcode-then-burn process that worked for me under Nero 6.2. There may well be other ways to deal with this problem, I just don't know what they are. Downside to this approach of course is that you need about 33% more disk space as compared with that required for transcode-and-burn (t-and-b: need space for the original files and Nero temp files; the .iso approach: need space for the original files, the DVD-compatible files Nero creates, and the .iso file created from that). However this is an alternate procedure, not a fix, and the only approach so far I have found.
Plenty of good DVD discs gave their lives to discover this process. I hope I can save you some misery and trips to the store for more blank DVDs by posting it here.
on Feb 22, 2008 | Ahead Software Nero 6 Ultra Edition...
No compatible device
Try to run your nero infotool utility. it will detect cd/dvd attached on your computer
Mar 27, 2009 | Ahead Software Nero Ultra Edition 6 Full...
Can't find burner for windows vista
Here's a list I found online. I personally recommend Nero but anything on that list will do.
* AnyDVD v5.3.2.1 (32 Bit)
* AnyDVD v5.9.4.1 (32 Bit)
* AnyDVD v5.9.6.3 (32 Bit)
* AnyDVD v6.0.0.4 (32 Bit)
* Ashampoo Burning Studio v5.51 (32 Bit)
* CloneDVD v2.8.4.1 (32 Bit)
* CloneDVD v3.6.0.0 (32 Bit) [NOTE: All works, but the box of Audio and subtitle selection don't show the content of DVD!]
* Daemon Tools v3.33 (32 Bit) [NOTE: Works perfectly.]
* Daemon Tools v4.0.3 (32 Bit) [NOTE: New version runs perfectly.]
* DVD Decrypter v3.5.4.0 (32 Bit) [NOTE: Displays error on close, but burns no problem.]
* DVD Shrink 3.2 (32 Bit)
* Frog ASPI v0.29.4 (32 Bit)
* ImgBurn v1.3.0.0 (32 Bit)
* InterVideo DVDCopy v3 (32 Bit)
* Gamejack v4.0.0.590 (32 Bit) [NOTE: Two virtual drives included.]
* Gamejack v5.0.3.3 (32 Bit) [NOTE: One virtual drive included.]
* Nero Burning ROM v5.5.10.5 (OEM) (32 Bit)
* Nero Burning ROM/Ultra Edition v6.6.0.14 (32 Bit) [NOTE: Nero Express crashes, but Nero Burning ROM works perfectly fine.]
* Nero Burning ROM/Ultra Edition v6.6.0.16 (32 Bit)
* Nero Burning ROM/Ultra Edition + OEM v6.6.0.80 (32 Bit)
* Nero Burning ROM/Ultra Edition v6.6.1.4 (32 Bit)
* Nero Vision Express v3.1.0.08 (32 Bit)
* PowerISO v3.2 (32 Bit)
* Roxio Easy Media Creator v7.5.0.47] (32 Bit)
* Sonic DVDit Pro v6.0 (32 Bit)
* StarPort v2.6.1 (32 Bit) [NOTE: Includes working virtual CD/DVD drive!]
* UltraISO v7.6.5.1269 (32 Bit)
* Virtual CloneDrive v5.1.3.1 (32 Bit)
* Virtual CloneDrive v5.1.4.5 (32 Bit)
Mar 20, 2009 | Computer Utilities & Maintenance
Plugin not in nero
Now exit.
Hope this helps
Chris (ziraffa)
Jan 17, 2009 | Ahead Software Nero 6 Ultra Edition...
Nero 6 Ultra Edition issue
Your problem is that the default recorder you have chosen is nero image drive.you have to change the recorder to your drive.you can change it from on of your menu (tools,recorder etc)
option will be like this in a drop down menu
Nero image drive
samsung dvd drive (whatever your burner is)
May 22, 2008 | Ahead Software Nero 6 Ultra Edition...
Nero ultra 7
hi. its hard to tell why you are having this error. but in fairness , whatyou can do is uninstall and reinstall your nero. maybe this will help.
Jan 17, 2008 | Ahead Software Nero 6 Ultra Edition...
Finding serial number
hi,i 've a nero bt d't insallation & show me that serial no has expired
Jan 17, 2008 | Computer Utilities & Maintenance
Nero burn free software not downloading
in order to gaet ner software go to this link for the free download of nero 7 http://www.nero.com/enu/support-nero7.html and to make that version full version u need to enter the product id for product id u need to pay n buy nero software id or else u can get product id for free in the above link www.coreserials.com the in search tab type the name and version of ur software like nero 7 ultra edition or like nero 7 essentials ull get the keys copy those keys and enter into ur nero registration key ur software is now made full version
Nov 22, 2007 | Ahead Software Nero 5.5 (NERO5.5) for PC
Ahead Software Nero Express 6.0 (NERO6OEM) for PC Logo
180 people viewed this question
Top Ahead Software Computer Utilities & Maintenance Experts
Gareth Cockram
Gareth Cockram
Barbat Nae
Barbat Nae
Are you an Ahead Software Computer Utility and Maintenance Expert? Answer questions, earn points and help others
