Question about Dell Inspiron 1525 Notebook
Dell 1525 keyboard problem
How do I remove the Keyboard from my laptop so that I can Clean it?Seems like there is a key stuck. When my Login Screen comes up in the password field it starts to type. Not sure which key is the one thats stuck.
Thanks for your help.
jess...
  • Dell Master
  • 998 Answers
Here's a link to the Inspiron 1525 service manual: http://support.dell.com/support/edocs/systems/ins1525/en/SM/keyboard.htm#wp1180346
If you're having trouble opening the photos you may have to install the proper version of Adobe as follows: go to www.support.dell.com and select "I'm looking for drivers and downloads". If you don't have the proper version of Adobe you will be prompted to install it. Once installed return to above link.
Your responses are intended to improve the level of service provided. Please show your appreciation by rating your experience.
Thank You.
Posted on Jan 17, 2009
  • 4 Answers
Hi
in your laptop right side conner (top) you can find there is a small hole. With the help of small screw driver you have to open it. After thet there will be 2 small screw's you should remove and remove the keyboard with very careful. in the bottom there is a small connector which is attached to mother board.
Posted on Feb 12, 2009
  • Elec_Eng Oct 31, 2010
    Remove the Battery then the 2 small screw first !!!
    To release the ribbon cable, the entry side of the connector must be lifted, it is hinged,
Plz friend i need laptop case dell 1525
Posted on Aug 24, 2012
How to remove and insert MSI PR400 Noteboo stuck keys
Watch these videos to remove and insret keyboard:
Acer Aspire 5536 7740 5251 Laptop Keyboard Installation Replacement Guide...
How to Install Zawgyi Font Keyboard for Windows Computer Myanmar Version
How to replace laptop keyboard
Dell Inspiron Laptop Keyboard Installation Replacement Guide 1525 1545...
Beware of replacing your keyboard if you don't have some experience manipulating laptops. You might end taking it in a shoubox in pieces to your repair service!.
Take a photo of each step you do,.
Oct 05, 2015 | MSI Computers & Internet
DELL INSPIRON 1525 HELP
It should be a simple fix. Start your laptop and pay attention to the screen. Press the F12 key (or F11) to enter "SETUP" then find the NUMLOC command and make sure that its DISABLED or OFF. This will turn this option off andyou will only be able to use the number's keys on the top of the keyboard. Be careful when entering SETUP. You don't want to change anything you don't have to.
Dec 26, 2011 | Dell Inspiron 1525 Notebook
My laptop is a dell latitude d610. I know i somehow lock my keyboard but I dont know how (what keystrokes) I need to unlock it. I have restarted the laptop and am stuck at login screen. Curser is there but...
have a look at ur keyboard,,,while holding the fn key press the appropriate function key,,these are the f keys across the top of ur keyboard,,look for the picture of ur keyboard or a padlock
Jul 08, 2010 | Dell Latitude D610 Notebook PC
Left click key doesn't bounce back when clicked. Seems stuck
The key is stuck you have to be very careful if you are going to attempt to repair this.Turn the computer off and remove the battery before you attempt to repair it.Try prying it up with a thin knife blade.If this pops up and is working make sure it works as good as the other side.If not you will have to replace the palmrest.
Good Luck
Mar 21, 2010 | Dell Keyboard for Inspiron 1420, 1520,...
Inspiron 1525 laptop keyboard stuck
if you think thats the cause of the problem.... then you should clean it before it will cause more damage.
clean it with water and let it dry.
Feb 15, 2010 | Dell Keyboard for Inspiron 1420, 1520,...
Stuck keys
You don't have to buy a whole new keyboard to replace few keys. Try taking off the key cap and its retainer clips (plastic pieces underneath the key cap). Repair it yourself with the help of this video:
Nov 29, 2009 | Dell Inspiron 1525 Laptop
How do i replace the keyboard on a dell inspiron 1525
How to Install a Replacement Keyboard on Dell Inspiron 1525 Laptop Computer You may need:
  • New keyboard
  • Screwdriver
---Be careful to not break off any of the plastic tabs on the keys as they are difficult to replace.---
  1. Turn the computer off and slide the tip of the screwdriver in the notch on the right side of the hinge cover (the plastic section above the keyboard). Slide the hinge cover up and remove it from the computer, exposing a series of bolts. Unscrew the bolts and remove them.
  2. Pull up on the edge of the keyboard and slide it forward toward the display. Slide the keyboard all the way out of the computer case slowly.
  3. Unhook the flex cable from the computer board to disconnect it from the computer.
  4. Slide the new keyboard into place, connecting the flex cable first.
  5. Screw down the edge of the keyboard with the 4 bolts from before and replace the key cover.
  6. Power up the computer and see how your new keyboard works!
May 01, 2009 | Dell Inspiron 1525 Notebook
I have a new key board but I don`t no how to remover the broken one its a dell inspron 1525 lap top
The link below will take you to a step by step guide for replacing the keyboard:
Good luck and please let me know how you do with the replacement.
~ Spoem
Apr 13, 2009 | Dell Inspiron 1525 Notebook
My s key on dell laptop is sticking , hard to press model 1525
If the system is still under warranty, contact Dell technical support for a replacement keyboard. If it is not, you can buy a new keyboard here:
http://cgi.ebay.com/NEW-Keyboard-for-Dell-Inspiron-1420-1520-1521-1525-1526_W0QQitemZ330252862696QQihZ014QQcategoryZ31568QQssPageNameZWDVWQQrdZ1QQcmdZViewItem
Jul 16, 2008 | Computers & Internet
Dell Inspiron 1525 Notebook Logo
2,165 people viewed this question
Alun Cox
