Question about Maytag 24 in. MDB4000 Built-in Dishwasher
Dishwasher leak My Kenmore dishwasher is leaking from around the door. Water was leaking from the bottom panel, so I pulled out the whole washer only to see water spewing forth from around the top between the box and the door (on the right side). I replaced the gasket that goes around the door and is supposed to create a seal between the washer and door. It still leaks. Now I'm at a loss because water is still coming out. The washer is about 15 years old, so I'm afraid it's ghost may have left the house and I need to replace it. i hope not.
  • 25 more comments
  • Chris Call Jun 22, 2007
    How do I clear the drain? There is water standing in the bottom of the washer, so it looks like there is a blockage somewhere. I can see underneath the machine but can't get to the hoses without spilling water everywhere. I've removed the filter and pump covers but can't figure out how to clear the drain. thanks.
  • Chris Call Jun 24, 2007
    Sorry, I didn't know I had given you a bad rating. It is a front loading machine. I pulled off the covers that you said, but I can't seem to find where the stoppage is occuring. I ran my fingers all around the pump and the drain but I can't find anything that is clogging it. I'm not sure what to do now.
  • Anonymous Mar 11, 2014
    SYSTEM ERROR 354 IN IR 1600 CANON PHOTOCOPIER
    fabric softener not emptying at the end of the cycle
    Samsung CLP 650 Page Count Reset
    Driver's seat will not respond to memory setting and will not manually advance
    the fuses are all fine the instrument panel does not work unless the dome light is on.
    reseting computer on an 08 dodge avenger
    need assembly instructions for king bed
    new magicjack instaled up grade two months ago it wand up on conputer then phone started to work.now I'm told to put my phone number in becouse my time is up I only want phone service no answering computer phone and the time I paid for alredie
    6300 restriction code
    what is the solution to this problem?
    Valves and gauges
    STOPS SHIFTING WHEN IT GETS WARM BUT IF YOU TURN THE CAR OFF AND RESTART IT, IT WILL BRGIN TO WORK AGAIN FOR A PERIOD OF TIME
    I bought a new yamaha snare drum can I use the spare drum pad and how would I connect it
    Remove ashtray on fordf150
    prints have horizontal lines and some of the text is printing smaller than it should be
    peavey fx mixer
    Were does the #1plug wire go on the distributer cap 350 chevy motor 95 g30 one ton cargo van
    what size gips for 125cc Suzuki marauder 03 reg
  • Anonymous Mar 12, 2014
    What is the firing order for a 2000 dodge stratus 2.5
    reboot zte majesty
    how do I make my mp3 player play songs in the same track order as they are on the cd's and not alphabetically
    Nvidia VGA CARD 180-P0026-0000-B 3902a585
    Idiots have put unidentifiable safety screws in the bottom, where do I get the tool ?
    my headphone is working while hearing music and all that o n my laptop but while i am talking on skype the sound not coming through headphone but in speaker
    shows error code e000000 on starting, what can i do?
  • 944 Answers
To clear the drain in a few easy steps; find where the outlet hose connects into your house drain system, disconnect it and then see if the machine will drain into a bucket/tray. Try it both by gravity (if you can get the hose below the water level)and with the machine on if not. This will tell you if the blockage is in the house drain not the machine. If the house drain is clear, see if you can disconnect the drain hose from the machine end and check it isn't blocked.if this is not removable, try poking a bit of wire or similar down it, being careful not to go past where it enters the machine (measure your bit of wire against the outside of the hose first). As Joe says, if you are sure the accessible filters and everything you can get to easily are clear, a garden hose in the hole will possibly clear the blockage if you can get a bit of pressure - often the easiest way is to hold a rag tightly around the end of the hose and the hole you are trying to get water through. (Note you will get wet - be very careful of electical sockets etc). If this doesn't seem to clear the blockage then the pump is either faulty, or not recieving instructions from the control board to work (more likely, although you would expect an error message). Hope this helps, if you wish to change Joe's rating you can just by rating the advice again. Good luck :)
Posted on Jun 25, 2007
    Novelist:
  • 114 Answers
HELLO ... CHANCES ARE YOUR DRAIN INSIDE YOUR WASHER IS PARTIALLY PLUGGED. TOP LOADER OR FRONT DOOR LOADDING MACHINE... IN EITHER CASE MOST WATER LEAKS ARE CAUSED BY DRAIN BLOCKAGE. FIND A WAY TO FLUSH THE DRAIN HOSE ON THE WASHER AND SEE IF IT CYCLES CORRECTLY. IF WATER IS GETING HIGH ENOUGH IN YOUR DISH WASHER TO SPLASH AROUND WITH THE SPRAY BAR IT IS YOUR DRAIN OR PUMP NOT CYCLING THE DIRTY WATER -OUT. ALWAYS CHECK THE MOST COMMON PROBLEMS FIRST. GOOD LUCK ... Joe_Rex
Posted on Jun 22, 2007
  • Joseph Reckinger
    Joseph Reckinger Jun 22, 2007
    I AM ASSUMING YOU HAVE A FRONT DOOR LOADING MACHINE. IF SO, REMOVE THE LOWER DISH RACK AND THE DRAIN IS USUALLY UNDER THE SPRAY BAR THAT IN MOST CASES JUST LIFTS STRAIGHT-UP AND OFF.
    THE SPRAYER BAR TURNS ON WATER PREASSURE ONLY. AND SHOULD SPIN FREELY. IF YOU HAVE STANDING WATER IN THE BOTTOM IT HAS TO BE REMOVED BVY SPONGEING IT UP.
    AFTR REMOVING ALL THE ABOVE YOU SHOULD SEE THE DRAIN INLET AT THE BOTTOM UNDER THE SPRAY-BAR ASSEMBLY (MAKE SURE YOU HAVE A STRONG FLASH-LIGHT) DO NOT USE A 110V TROUBLE LIGHT AROUND WATER.
    YOU MAY BE ABLE TO SEE THE DEBRI RIGHT AWAY AND REMOVE-IT. THEN TAKE A GARDEN HOSE AND FLUSH IT OUT. MAKE SURE YOU HAVE PLEANTY OF RAGS. IT SHOULD ONLY TAKE A GALLON OR SO OF HOSE PRESSURIZED WATER TO CLEAR YOUR DRAIN LINE.
    I REALLY HOPE THAT WORKS FOR YOU. THE PUMP WOULD BE THE ONLY OTHER CULPRIT HERE I BELIEVE.
    THIS IS OBVIOUSLY THE LEAST EXPENSIVE AND THE FIRST SUGESTION TO TRY.
    Joe_Rex
SOURCE:
Kenmore elite dishwasher leaking below washer
see this causes and use the common sense. God bless you
Dishwasher Not Leveled
This is a very common reason for a leaking dishwasher especially if this was a new installation. The framing in a dishwasher is made up of mostly thin sheet metal, so if it is not sitting flat and level things can get distorted very easily. Watch the video on leveling your dishwasher.
Door Seal
This is not very common in most dishwashers. To check this look for rips and distortion of the seal. If it is ripped or distorted you will need to replace.
Dispenser Seal
This is a more common place for a leak to develop. This is easy to check, remove the front panel and carefully inspect around the seal for water dripping or stainage. If any is found replace the dispenser gasket.
Water Inlet Valve
Usually it is the connection to the water inlet valve that ends up leaking. Check this connection ( there is usually some sort of adaptor between the valve and supply hose) for leaks. Check the connection on the back of the water inlet valve also. Ocassionaly a water inlet valve will leak around the solenoid in this case replace the water inlet valve.
Drain / Circulating Pump
Some dishwashers have separate drain and circulating pumps. Some use one pump to serve both purposes. In either case you will need to check the housings for leaks along with all the connections. Some dishwashers have a seal that leaks down into the pump . This is easy and inexpensive to replace. Follow the tutorial on replacing the pump.
Door Latch
The door latch can become loose or misalinged. Check both the striker and the latch. To adjust the latch you will need to remove the front panel and adjust switch until properly aligned.
Door Hinges
They can cause problems, but this usually only happens from opening a heavy load of dishes on the door. Occassionaly a broken spring or cable occurs. You will need to remove the toe kick and maybe the front panel to inspect.
Sep 19, 2012 | Kenmore Elite Stainless Steel 24" BuiltIn...
Kenmore model #16761691 leaking at the bottom of the door. Where is the gasket located? Or is it another problem?
does it leak all the time or did it just start?try running it with nothing in it and see if it leaks,if the dishes were racked wrong the water can get deflected and leak out through the door,also,remove the bottom rack,look at the screws going around the bottom part under the wash arm,if any of those are loose it causes a wave in the dish washer and the water leaks from under the door.if it's leaking from one of the corners the gasket could be bad
Apr 17, 2011 | Kenmore Dishwashers
Door leaks at the bottom of my ge profile dishwasher
1 has the machine been pushed into the cupboard hole,this will push the door away from the front of the machine,does it hit the trim around the opening before the closeing?pull out check under are the legs still straight,some you can remove the lower front panel to look under
Dec 02, 2009 | GE Profile PDW8400J Built-in Dishwasher
We just bought our house and the dishwasher leaked when we used i
check around the bottom of the seal on the door . It might have a build up of old soap and food this will cause a leakIf you clean it good it should take care of it.
Jul 31, 2009 | Kenmore Dishwashers
My Maytag washer leaks at the door. It doesn't
f you have nuisance water leaks around the base of your dishwasher, you may be using a detergent that is sudsing too much. Cut back on the amount of detergent you use, and see if that makes a difference.
Water that spills through the door vent is usually caused by improperly loading dishes. Leaks from the door itself may be caused by a faulty door gasket or door tightness adjustment.
Also make sure the dishwasher is sitting level (you can adjust the front feet up or down, and many units have some type of levelers at the rear).
Water under the dishwasher may be originating from a leaky hose or loose hose connection. Remove the lower front panel, and check the hoses. The pump seal may be defective, too; replacing this is a job for an appliance repairperson.
An older dishwasher may corrode at the bottom, but this is fairly uncommon. If this is the case with your dishwasher, it's time for a new one.
Rate the solution..
Jul 10, 2009 | Maytag 24 in. MDB5600A Jetclean II...
Kenmore series 70 tip loader washer is leaking
your just seeing the water that is leaking dureing the wash cycle unplug washer there will be 2 screws on the header panel 1 on each side take them outgently pull header panel to you then flipupunplug wiring harness thas to the cabnet there will be 2 clips 1 on each sideuse a flat screwdrive and pry back they will come out tip cabnet back to you the whole thig will come off look at the pump in the front it has a weep hole in it see if it has been leaking from there
Jun 27, 2009 | Kenmore 22422 Top Load Washer
Water leaking out bottom of dishwasher door onto kitchen floor.
  1. open the bottom panel 2-4 screw
  2. take a flashlight and turn the machine on
  3. see where it come from
  4. if you need take the unit out a bit from the counter
  5. check it all around to find the sorce of the leak
  6. good luck its EZ :)
Mar 02, 2009 | Kenmore 15762 Dishwasher
Kenmore Elite Front load washer leaking
You need to replace the rubber gasket around the door.
Dec 16, 2008 | Kenmore Elite 45986 Front Load Washer
KitchenAid Dishwasher Leaking from under Door
I had a similar problem with a KUDM25SHWH1 dishwasher. Rubber seal looked fine. I found an incredible tip on another fixi it site. One possible problem iss the pump cover screws may have worked loose and is squirting water directly on the door seal. Man that was it! I saw a couple of looses screws and a small portion of the pump cover gasket showing. I loosened the pump top, reset the gasket tightened it all down...no leaks! The pump I refer to is located directly below the spray arm inside the washer. Easy to get to. Another tip was to look for a split sspray arrm that may spray water directly into the door seal.
Nov 04, 2008 | KitchenAid 24 in. KUDS25 Built-in...
KHWS01PWH0 Front Loading Automatic Washer Leaking
out the bottom of door?? no through the bottom panel???. check the rubber door seal for rips or tears pull it back and look around entire circumference. smalll rip in very front of seal where door should close against will cause leak for sure
Mar 07, 2008 | KitchenAid KHWS02RMT 3.7 Cu. Ft. Ensemble...
Dishwashers Logo
186 people viewed this question
Top Maytag Dishwashers Experts
Mike
Marvin
Marvin
Vitally Alcher
Are you a Maytag Dishwasher Expert? Answer questions, earn points and help others
