Question about Craftsman 20 hp 42 in. Deck Lawn Tractor - CA Model
My lawn mower will not start
It gets good sprark and when i put gas in the carb it will start and run until the gas is burned off, but the gas does not seem to be feeding from the tank into the carb by itself.
wadembly
  • 489 Answers
SOURCE: the mower will not start unless you pour a little
it could be that the floatin carb is stuck & not filling up the fuel bowl check that & see if i can further help e-mail me wade at wadembly@aol.com
Posted on Jun 28, 2009
  • 61 Answers
SOURCE: Starts, runs good for several minutes, then underload loses power
ck for water in carb ck magneto for clean
blue spark
Posted on Sep 06, 2009
  • 784 Answers
SOURCE: my riding lawn mower won't start it has a spark
Assuming " won't start" meaning cranking but not getting fired, otherwise my suggestion won't be valid:Try to put some gas into the carb to see if gets started. It is started then died then gas is not delivered to the carb.
Posted on Oct 11, 2009
SOURCE: possible carburetor problem? Mower runs for
i have a lt 1000 2005 when i start it with cold engine it boggs for a minute then it starts to run smoothly please help me
Posted on May 08, 2010
  • 11 Answers
SOURCE: I have a Craftsman 42 in. 15.5 hp lawn tractor
check an see if the cabuerator is getting fuel and check make sure sparkplug is getting continous fire from the coil
Posted on Sep 13, 2010
Lawn mower instructions why wont it work
check for spark at plug if spark at plug then squirt some starting starting fluid in carb see if will start it should run long enough to burn out starting fluid if does check for water in gas if is drain tank and carb bowl put in fresh gas not and repeat not old gas you were using strat lawn mower if still dosnt start rebuild carb and add and additive called seafoam to the gas this is good stuff follow instrution on bottle
Sep 02, 2014 | Garden
My Briggs 675 series want start I put in a new spark plug and I took out the spark and put gas in hole and it still want start
clean the gas out of engine put plug back in get some startinfliuid and sray a little in carb until it starts
Jul 01, 2014 | Briggs & Stratton Garden
The riding mower has been used in June. Now when I try to start it I cant. I have checked the battery, gas, etc. before trying to start it. What can I do now?Thanks
put gas right into the carburetor and see what happens. if it doesn't do anything then you have a spark issue, if it runs until the gas you just put in runs out then it is a carb issue. sometimes just priming the carb with gas will get it to run again too
Sep 25, 2013 | Ariens 21 In Classic Walk Behind Push Lawn...
My bronco lawn mower doesnt run until i spray carb cleaner in carb
i have been finding a bad safety switch on the brake/clutch pedal not sending power to the solenoid on the bottom of the carb
Jul 17, 2012 | Garden
Toro recycler lawn mower
if old gas was left in the engine a good carb cleaning will need to be done
May 11, 2012 | Toro Power Lawn Mower
23hp kiwasaki cold start winds to long before starting
hello sir, mower will not start or run,runs only when primming, does it have good spark,good compression,or only runs on full choke, are you getting fuel to the engine if not try this,your fuel pump or your carb. is clogged up here is what you can do for a simple repair for the carb,you can remove the air filter and assy, empty fuel tank and clean out tank and line,remove the bowl nut and bowl careful of the gaskets,now spray carb cleaner in the small port holes in the carb steam in the middle of the carb until clean,now spray the bowl nut holes until clean there are three,after cleaning put bowl on the same way you removed it with dip towards front of float,put bow, and fresh gas,you should be good to go,hope this helps.,thank you.~~
Feb 11, 2012 | Garden
Mower only runs two min and quits
Sounds like a blocked or dirty fuel inlet.
Remove the carb bowl and work the float up and down until gas flow improves. Be gentle! Just a little light pressure from beneath and the float should swing up about a quarter inch.
The short run is due to the carb bowl not refilling fast enough to keep up with full throttle demand.
Make sure when you put the carb bowl back on there arent any fuel leaks before trying to run the mower.
Good luck and be careful!
Jul 25, 2010 | Ariens 21 In Classic Walk Behind Push Lawn...
Lawn mower starts and runs until I start pushing it, then it just dies out.
Sounds like the carburetor is gummed up. Short of taking the carb off and cleaning, some good fuel line/carburetor cleaner such as Gumout (available at any place that sells auto oil/filters, etc. Wal-mart, K-Mart, Autozone). Put a bit of fresh fuel in the gas tank and add about 2 or 3 Tablespoons of fuel line cleaner. Start mower and let it run a bit. May run rough, but should clean the carb out unless plugged bad. If this doesn't work, the carb will need to come off and be cleaned. Can be done by the homeowner, but if you are nervous about tackling this job it may be best left to the mower shop.
Nov 29, 2009 | Craftsman Garden
I have a murray centina 4.5 lawn mower and my
keep washing out the tank with water ? then try a can of starting fluid use it too keep it running until all the contamination is out of it ? if it still wont run the you must r&r carb and rebuild it also check for rust in tank?
Aug 26, 2009 | Garden
Craftsman 20 hp 42 in. Deck Lawn Tractor - CA Model Logo
114 people viewed this question
Top Craftsman Garden Experts
Wade Mobley
Wade Mobley
Dean Gruber
Roland W VanLue
Roland W VanLue
Are you a Craftsman Garden Expert? Answer questions, earn points and help others
