Question about Honeywell Programmable Thermostat Heater
Inside tem. can not reach the set tem. during the cool days
TEMP SET 26C' ONLY RISES TO 18.5C'/ .. BURNERS FIRES GOOD FULL FLAME BUT SHUT OFF ,BACK TO PILOT STAGE JUST AFTER 2 MINUTES ..THEN COMES ON AGAIN IN ABOUT 3-5 MIN...EQUIPPED W/ TWO STAGE FAN ...WHICH BLOWS LOW CONSTANTLY, HOWEVER IT DOES BLOW HIGH COOL AIR FOR A COUPLES MIN. AND THEN .. FULL FLAME AGAIN ......
  • wojow52 Feb 27, 2009
    what's "pressure switch"?...is it on the heather or the thermostat?...I have the same problem, should I go and get new programmable thermostat?
  • Honeywell Master
  • 3,077 Answers
Check the presure switch jump it out and see if it fires all the time
Posted on Jan 17, 2009
I have a 4 year old Goodman heater model GMS81155CNA that we just replaced the blower motor on, fortunately it was under warranty until April. Now it keeps trying to cycle 2 or 3 times before the burners...
i would start by checking the flame sensor mounted in the same area as the ignitor or glow stick as you called it... the flame sensor is a metal rod mounted in the direct path of the flame once lighted... it senses the flame and sends signal back to control board to keep gas valve opened and continue the operation.... if the flame sensor is dirty or faulty will start to shut system down premature... the pressure switch could be a problem as well but normally if it goes bad it will fail as soon as unit fires and continue to fail due to a bad diaphram in switch... will mimic a bad flame sensor as well unit will fire but will within seconds shut back down.... the ignitor has to be hot enough to light when gas enters chamber and can be weak but if it works sometimes then i would say it is ok....the flame sensor can be pulled and gently cleaned with light grit sand paper dont over due it but clean it up a little and try it... again it is located next to hot surface ignitor( glow stick) usually has quarter inch hex head screw holding it in place... positional to get out but will come out....
Jan 24, 2011 | Goodman GMS90703BXA Heater
How to use the remote control to set the desired temp
Indoor temperature Operation mode Target temperature
Less than 200C HEATING
(FOR HEAT PUMP TYPE)
FAN 23C
20C~26C DRY 18C
Over 26C COOLING 23C
You will get good results by applying this meter
Jan 07, 2010 | Mitsubishi Mr. Slim MXZ30TN Air...
Lennox furnace 17 yeanrs old. flame comes on and the shuts down sometimes right away some times in a few minutes. We have the furnace go down to 58 at night. It takes all day to get back to 67.
Sounds like a dirty flame sensor.
Also 9 degrees is a large swing to recover. Most specialist will advise no more than a 5 degree set back, otherwise recovery time eliminates any savings you may achieve.
Dec 05, 2009 | Dayton (3E407) Heater
Burners shut down at set temp but fan continues lowering temp
the reason he told you not to cycle the power is because some where there is a flashing light that he can decode and tell him where to start looking for the problem. Call him next it happens and don't touch the power or the stat until he gets to see the unit.
Aug 03, 2009 | Heating & Cooling
Viking oven only one burner will light
http://www.vikingrange.com/MEDIA_CustomProductCatalog/m20127_f20254.pdf
Go to this web site. It has a manual on Viking ovens.
Usually, when the set temp is reached, the flame will cycle down to what is called "Minimum Blaze". This is to put heat into the unit at the rate that it leaves the unit. It helps to hold temp rather than cycle off and on. It cycles high when temp goes below set and then cycles down when set temp is reached.
Jul 09, 2009 | Refrigerators
FURNACE CYCLING ON AND OFF ..
I would check furnace filter first. If that looks good i would check the thermostat. To check thermostat turn power off to furnace then take thermostat off the wall and connect wires labbled R & W together then turn power on and check furnace to see if it runs for more than a couple of minutes. If so install a new thermostat. If that doesn't work let me know and i can give you a couple more thing to try.
Jan 17, 2009 | Honeywell Programmable Thermostat Heater
Central heater will not heat up to set temp on thermostac
pressure port is plugged pull hose off draft motor and clean port with a paper clip
Jan 13, 2009 | Omega Trane Furnace Draft Inducer Blower...
Carrier model 58sxa080-gg series 100
the flame detector rod is dirty? try cleaning with sand paper and scraping also. there should be a small amp. reading threw wire coming from flame detector rod. in milli amp range. increases when running. some times i use a jumper to hold gas valve on once started to allow time to test amps.
Feb 19, 2008 | Carrier XHB123D X/Y Series Heat/Cool Air...
Heating & Cooling Logo
Top Honeywell Heating & Cooling Experts
Bill Long
Paul Carew
vance jones
Are you a Honeywell Heating and Cooling Expert? Answer questions, earn points and help others
