Question about Samsung RS2630WW Side by Side Refrigerator
Water is not coming out from Samsung RS2630WW Side by Side Refrigerator. I realized there was no filter. After installing filter I reseted and light when off, but water still not running
  • 700 Answers
The water resevour is proberbly frozen inside of the refrigerator. Open the door and remove the bins in the refrigerator and you will see a resevour tank. take a hair drier and heaqt up the tubing that comes out of it until the water flows again.
Posted on Feb 01, 2009
The outside center and out side corners are very hot. Everything else is working fine
Hot refrigerator I have a Samsung refrigerator RS2630SH ...
www.fixya.com/support/t322304-hot_refrigerator
Also the freezer side outside wall is very hot to touch. Ice maker does not work as well. Any suggestions appreciated, excluding the one "not to buy Samsung ...
Samsung RS2630WW Side by Side Refrigerator Divider hot ...
www.fixya.com > ... > Samsung RS2630WW Side by Side Refrigerator
Samsung RS2630WW Side by Side Refrigerator, divider hot related issues. ...Compressor/motor on mu Whirlpool frige is really hot. face of fridge/freezer ... centerdivider is hot to the touch, it means that the compressor is running hot. either your ...means there is inadequate air flow over the condenser coils outside the unit.
[PDF]SAM0059 Samsung Side-by-Side Refrigerator.pdf
applianceassistant.com/.../sam0059_samsung_side-by-side_refrigerator.p...
A newly developed SAMSUNG side by side refrigerator in 2004 has the .... Warranty service can only be performed by a SAMSUNG authorized service center. .... SUB-CONDENSER. Hot Pipe. Hot Pipe. Compressor. SIDE CLUSTER PIPE .... corner of the refrigerator. ... The CoolSelect ZoneTM thermistor is located outside.
Jan 25, 2016 | Samsung RS2556 Side by Side Refrigerator
Where is the filter on my rs2630
Removing and replacing a water filter - inside liner location
Filters situated in the interior liner of the refrigerator compartment of Samsung-built side-by-side refrigerators are relatively simple to replace. Follow these steps:
  1. Grasp the filter and make a one quarter turn to the left. There should be an indicator line located on the filter bracket cover. The install mark on the filter itself will line up with this indicator line.
  2. Pull down gently on the filter to remove it from the mounting bracket assembly. Be careful to not tip the filter, as water may spill out of it.
  3. Discard the used filter.
  4. Remove the new filter from its packaging, and remove the red plastic cap from filter cartridge.
  5. Apply the appropriate month sticker to the filter to remind yourself to change it again in six months' time.
  6. Line the install mark on the filter up with the indicator line found on the filter bracket cover. Push up on the filter. Turn the filter a quarter turn to the right to lock it in place. The remove mark on the filter should line up with the indicator line of the filter bracket cover.
Note: Replacing this type of filter is quick - there is no need to unplug your refrigerator when replacing it. Also, this filter should be replaced every six months.
Aug 19, 2011 | Samsung RS2630WW Side by Side Refrigerator
Where is the water filter located?
The filter is in the refrigerator section in the space behind the vegetable bin. Thus pull the bin out to change your filter. Then remove the cap by rotating it counter-clockwise. Remove the old filter (turn 90 degrees counter-clockwise and then pull out) and then take the protective cap off your new filter. Slide the new filter into the housing and then rotate clockwise 90 degrees. The alignment marks should indicate the filter is locked into place. Then replace the cap. Remember to run water through the dispenser for several minutes to clear the lines.
I hope this helps.
(I don't have a manual for the RS2630WW; however, the Samsung RS2630SW should have the filter in the same place.)
Oct 23, 2010 | Samsung RS2630WW Side by Side Refrigerator
How do u replace water filter on samsung refrigerator side by side model number rs2630sh
The water filter in the extra space behind the vegetable Bin.
1) As shown, the fixed cap separates from the refrigerator by rotating
it counterclockwise.
Remove the water filter from the box and put a month indicator
sticker on the filter as shown on the next page.
2) The water filter should be replaced every six months, so if the filter
was installed in March (for example), put on the "SEP" sticker
to remind you to change the filter.
3) Remove the protective cap, then position and insert the
filter as shown.
4) Slowly turn the water filter clockwise 90º to align
the indication mark on the cover, locking the filter in position.
Or go here bottom of page 24 top of 25.
http://www.azmanual.com/download/21949/5478c9cd79f4e04b6a2f6e2b4ab9f513/
Please rate 4 thumba for the free answer.
Mar 08, 2010 | Samsung RS2630WW Side by Side Refrigerator
Change filter light stays on
It is very easy to reset your filter indicator light on your Maytag refrigerator. Simply press and hold the light and lock buttons, on the dispenser, for about three (3) seconds, until the change filter light blinks.
Thanks, Sea Breeze
Feb 21, 2010 | Samsung RS2630WW Side by Side Refrigerator
FILTER NOT WORKING
Water will run through a filter until it's clogged. Check the filter by removing the end that goes into the refrigerator. If it flows, it's still open. It should be replaced after 6 years though. If water doesn't come out of the filter but still floew through the refrigerator, it's connected wrong.
Mar 04, 2009 | Samsung RS2630WW Side by Side Refrigerator
Water filter on refrigerator not working. Samsung
This link will take you to the Samsung support site. There you can find the instructions for replacing the filter....if the filter is not properly aligned, the water bypasses the filter
Jan 30, 2009 | Samsung RS2630WW Side by Side Refrigerator
Water Filter light still red after new filter installed
You have to reset the light by pressing and holding the touch pad for 3-5 seconds. It doesn't reset on its own when you replace the filter
Dec 08, 2008 | Samsung RS2630SH Side by Side Refrigerator
What happens if I don't change the water filter in fridge?
It will eventually clog up, and the water volume will become less and less untill it is a tickle, and eventually stops.
It could also cause premture failure of the valve/pump.
Dec 06, 2008 | Samsung RS2630WW Side by Side Refrigerator
Samsung RS2630WW Side by Side Refrigerator Logo
274 people viewed this question
Top Samsung Refrigerators Experts
John Tripp
John Tripp
Charles T Nevin
Charles T Nevin
Are you a Samsung Refrigerator Expert? Answer questions, earn points and help others
