Question about Dell Inspiron 1525 Laptop Jet Black
Secirity type cant connet to my wireless
  • 2 more comments
  • OrangeKitty
    OrangeKitty May 11, 2010
    We need more info to fix your problem. What is your computer telling when it won't connect?
  • aluregoldtec May 11, 2010
    what modem are you using? is your modem broadcasting a signal? (can your laptop find your modem?) if you give this and any other info you have i would be glad to help.. regards Mark
  • Project NOMAD
    Project NOMAD May 11, 2010
    What exact error are you getting ?
  • DEKR
    DEKR May 11, 2010
    were you able to connect before
    and in control panel network connections do you see your connectin
    Champion:
  • 239 Answers
Make sure the SSID is setup exatcly the same on the router and your wireless connection
Posted on Aug 29, 2009
    Problem Solver:
  • 5 Answers
Try reinstalling the wireless driver
Posted on Aug 27, 2009
I am installing a wireless printer it asks me for my secirity key, where do I fund this on my DIR-655 Wireless Router?
If you haven't changed the default security key on the router then you can enter the one which is printed at the base of the router if you have changed the password then you will need to get into the router interface and find out.
Hope this helped.
Jan 23, 2011 | D-Link Xtreme N DIR-655 Wireless Router
How do you connect internet to the wii system
u have 2 ways to connet u can go wireless or wired.... wireless is easy cuz if u got a router u can just connet to that.. if u need to connet wired then u will need to buy someting e3lse for the wire and it will go into the back of the usb port.. i think it's like 20 25 bucks... it's called a wii ethernet adapter i think,...
Sep 25, 2010 | Video Game Consoles & Games
How to turn on wireless connetion
router has a installer cd..when you install it you will be guided in how to connect your pc to the router..and also in how turning on the wireless connection...
hint: remember to put a password on your wi-fi so that it cant access easily by other persons..
Feb 06, 2010 | Toshiba Satellite R10-S802TD Tablet PC
I cant get my labtop to detect a wireless connection
Make sure your wireless it turned on at your computer.
Dec 24, 2009 | Dell Latitude D600 Notebook
Conneting
use your user and password and key for wireless access
Dec 13, 2009 | Computers & Internet
Cant remember my network key for my Belkin Wireless router. just got a new laptop and am trying to set it up. if necessary i will reset it!
First connect your router to computer with ethernet cabled.
Then you can access it with default ip
http://192.168.15.1
then type user as "admin" and password as "admin" or blank "password"
Then go to wireless secirity.
thjnen add new WEP code key it is your new password to connect.
But if you are not able to access router configuration page then you have to reset it.
for that press RESET button it in backl panel of router press it for 10 seconds.
Let me know if you need further assistamce.
Thanks.
Nov 06, 2009 | Belkin (F5D7230-4) Router (587009)
Netgear won`t connect to ps3
He needs to go to a local best buy radio shack, office depot type store and get a cat-5 ethernet cable from his ps3 to his router, this will solve all his problems since wireless gaming always has drop spots that can get worse depending on the router type. Also if their are other computers make sure there not downloading or eating up bandwidth, this will not allow it to connet. Make sure the router settings allow the ps3 to connect, does the ps3 see the router but wont connect? you need the wep key.
Apr 26, 2009 | Psyclone PS3 Wireless Controller for...
How do i secire my dlink wbr 1310 router
WPA-PSK
print.gif Step 1 Open a web browser and type the IP address of the WBR series router into the address bar (default is http://192.168.0.1).
Step 2 The default username is admin (all lower case) and the default password is blank (nothing). Click on OK.
Step 3 Click on the Setup tab at the top and then click on Wireless Settings on the lefthand side.
Step 4 Select the type of WPA encryption you would like to use with your wireless adapters from the Security Mode dropdown menu. Note: Your wireless adapters must support the form of WPA encryption you select.
Step 5 In the WPA Personal section, configure the following:
Select the Cipher Type
Select the PSK or EAP
Enter your Passphrase
Re-Enter your Passphrase
Step 6 Click the Save Settings button to save your settings.
You should also reset the admin password when you are done to something besides the default.
Click here to see how:
http://support.dlink.com/faq/view.asp?prod_id=2700&orig=1
Don't forget to rate this solution!
Feb 03, 2009 | D-Link 802.11g Wireless Router WBR-1310...
WLAN WONT CONNET
Hi, Hope this will help u..
1>connect LAN and check the WLAN light on wireless router It should be ON and solid, If not the you might need to reset the router
2>On your laptop click on start go to run (in case of XP) or go to start then search box (in case of vista)
3>type services.msc
4>For Xp check the wireless zero configuration service should be automatic and running
5>For vista WLAN service should be automatic and running
6>then go to start > run ( FOr XP) or start >
>search box(in case for vista)
7>type ncpa.cpl >click on OK
8>right click on wireless network icon and click on view available wireless networks.
9> Choose your network and click connect,
10> If it asks for WEP key , It might be written in your router.
If this doesn't work, you can contact your Internet service provider.
Dec 27, 2008 | Computers & Internet
Wireless card
Let me guess...it comes up as an unknown pcmcia controller.
I have 4 pcmcia cardbus cards and the only one that my armada M700 recognizes is a twinmos B. All others come up as unknown pcmcia controller.
Apr 13, 2008 | Compaq Armada M700 Notebook
Dell Inspiron 1525 Laptop Jet Black  Logo
Alun Cox
