Question about Kyocera FS-C5015N Laser Printer
Printing all pages as black
My Kyocera Ecosys FS-C5015N is only printing solid black pages, as I have only just changed the toner i realise this could be the problem.
This however was my last toner and I desperatley need to print off my menu's!!
Any ideas?
  • info432 Jan 17, 2009
    Thankyou so much. How can something so simple cause so much bloody trouble?
    Cheers Sam.
  • Anonymous Mar 24, 2014
    Kyocera Fs 1030D my question is despite that the toner kit is still half-full, but the printing finished product is faded in color instead of black dart, what possibly is wrong.
    Genius:
  • 2,120 Answers
Open up the left side door and push in all of the chargers to make sure they are seated.
Posted on Jan 17, 2009
  • Leroy Elliott
    Leroy Elliott Jan 17, 2009
    A dopey design Sam, thanx for the Fixya!
Ep Not supported
This could be a false detection of the "Envelope Feeder".
Apparently this optional accessory exists for the FS-C5025, not for the FS-C015.
If you run a google search for "Kyocera EF-310" and select the images section you will see how it looks and where it gets installed.
My guess is that something happened from the cleaning process, so that the printer "thinks" an envelope feeder is installed.
I hope this may help.
May 09, 2014 | Kyocera FS-C5015N Laser Printer
I have a Kyocera Ecosys FS-1118MFP. When I try to make a copy the page comes out totally black. I have tried to change the toner, but its still the same. Tried adjusting the exposure aswell but invain. Any...
This is an uncommon issue and could be one of several things
  • The formatter could be sending garbage print data to the ECU (rare)
  • The ECU is bad, this controls the laser
  • The high voltage power supply could be bad
  • The the primary charge roller is bad.
Typical laser jet process.
  1. Primary charge roller is charged to -600V and transfers this to the photosensitive drum in the toner cartridge.
  2. Th laser removes the negative charge and places a +600V charge where the image/text will go
  3. Toner is attracted to the positive charged areas on the photosensitive drum (toner is negatively charged)
  4. Transfer roller has a + charge sits under the paper, this roller attracts the toner from the photo roller to the paper
  5. The fuser melts the toner onto the paper
So if the laser is going crazy and removes all the negative charge or no negativ charge is being applied to the photosensitve drum then toner will stick everywhere to it and you get a black page.
How this helps.
Jul 13, 2012 | Kyocera FS-1118MFP Laser Printer
The printer is printing a yellow background on all pages. How do I get it to stop printing yellow?
It may be that you have extra yellow toner floating around in your printer so take all the toners out and hoover out your printer. Then print out about 10 - 20 blank pages to remove any left over toner. This should solve the problem, if not then its more than likely a faulty toner.
Sep 24, 2010 | Kyocera FS-C5015N Laser Printer
My kyocera FS-C5015N printer is printing all my pages with blue background, also get alot of paper jams
Reclean the cyan corona wire/grid with the cleaning block that comes with each toner.ensure that you leave the corona unit as far out of the machine as possible for 30 seconds to allow the grid to dry.If this does not work then you will need a technician to attend to the printer.
Jul 29, 2010 | Kyocera FS-C5015N Laser Printer
Kyocera fs-c5015n laser printer printing red instead of leaving white space on pages
So were the pages are supposed to be blank it has a red tint to it?
If this is the case sound like the developer unit for the magenta is bad you have to replace it if this is the case.
Jul 02, 2010 | Kyocera FS-C5015N Laser Printer
Kyocera laser printer toner refill
refill...uh oh probably wouldnt try it..there's is like only 1 company that does kyocera refill toners.....call KATUN... you can try to find that on the internet..you most likely willl have to buy actuall kyocera toner..
Jan 24, 2010 | Kyocera FS-C5015N Laser Printer
How do you clean dried toner from colour developer units
Kyocera toner for the FS-C5015N is dry. If you have excess toner outside the developer use the cleaning cloth that comes with the toner kit.
Do not wipe the magnetic roller at the bottom of the developer. Along with the toner, the agent is on the roller. If the agent is removed the toner will fall out of the developer. There is agent in the toner container but not enough to replenish all of it if it has been wiped away.
Nov 14, 2009 | Kyocera FS-C5015N Laser Printer
Kyocera FS-C5015N colour laser printer. -printing grey backgound
it seems very important to shake the toner before using your printer.
it is not too late
remove all toners and shake them well
you will find after a short time that the grey background goes away
Jul 09, 2009 | Kyocera Office Equipment & Supplies
Yellow line on edge of page
on a ricoh - that would be the pcm - photoconductor module on an ecosys the module should last 100,000 pages nothing ever seems to last that long send an email to http://www.pcandl.com/ or call where you bought it
Aug 07, 2007 | Kyocera Mita FS-C5016N Printer
Kyocera FS-C5015N Laser Printer Logo
1,014 people viewed this question
Top Kyocera Office Equipment & Supplies Experts
Kyocera HP Expert
Chris Schutte
Are you a Kyocera Office Equipment and Supply Expert? Answer questions, earn points and help others
