Question about Symbol LS 4007i Handheld
Symbol LS4007I Manual not Found
I have problem with the Symbol LS4007I not using Enter command after barcode scanning. I tried the Default command from another Symbol scanner but now does not work at all. I cannot locate anywhere in the internet the manual for Symbol LS4007I to reload the default commands. Please help to allocate the manual or instructions.
  • Anonymous Mar 20, 2008
    I used the scan sheets from the ls4008i manual to reset to defaults. Now it does not send the scans to the computer. It reads OK but does not send what it reads.
  • SymbolUser Mar 21, 2008
    Here is the Fix:
    down load the LS 400Xi Product Reference Guide It has a section for the 4007i USB.
    Scan Set USB Defaults
    Scan HID Keyboard Emulation
  • 432 Answers
Http://support.symbol.com/support/searchEntry.do?languages=&rwTarget=%2FrfPlayerWidget.do&searchMode=GuidedSearch&searchString=&productLine=SG_BARCODESCANNERS_1_1&product=SG_LS_4005_1_2&document=DT_PRODUCTMANUALS_1_1&cmd=search&productFamily=&contextType=gs I'll keep trying to find the right one. Ray
Posted on Jun 22, 2007
SOURCE:
After scanning a bar code I need it to enter and go to next row in excel
This can be possible, therefore it is not an Excel setting. You would need
to use the software that comes with your bar-code reader to configure this.
Try looking in your bar-code reader documentation for "Append Enter" or
"Append Carriage Return"
May 21, 2011 | Symbol LS 4000i Handheld
I'm using Symbol LS1004 with SirsiDynix Symphony 3.3.1 Workflows. How can I tab over after each scan, without having to hit <Enter>? Thanks, -john
Here is what I did to fix the problem of the bar-code scanner not going to next line after a successful scan. (Symbol ls4000i,This fix should work for other models as well)
1. Get the manual for your scanner or here is a link to the Symbol LS400i
https://docs.symbol.com/manuals/3789802a.pdf
You will want to print off few pages that have the proper bar-codes for programming.
2. I usually start with setting scanner to the Default Parameter, this should be in section 5-7,page 50 of the manual.PRINT IT
Warning! If you set scanner to default, you need to be aware of which bar-code types you use. (We use UPC-A) Also if you have it programed for other things already you may not want to set all settings to default. You can skip to step 4. If you do not wish to reset all values to default.
Now scan the Default bar-code.
3. Now program scanner to Enable your bar-code type. (For us Enable UPC-A bar-code is in section 5-22,page 66. PRINT IT
Now Scan the Enable (your bar-code type UPC-A, UPC-E,etc etc)
4.Next You need to set a Suffix Value. The scan Suffix bar-code is found in section 5-80, page 124. PRINT IT
Now Scan the Scan Suffix bar-code
This prepares the scanner for the code of the whatever Suffix you want to add.
5. The Suffix you want to add to fix this particular problem is ENTER. So that it goes to the next line. There is a prefix/suffix value chart on page 162 table A-4. The code for ENTER Is 7013. In order to enter this code you will need to print off the Numeric Bar Codes found in section 5-109,5-110,pages 153,154. PRINT IT
Now scan in 7013 one number at a time to program ENTER as the suffix.
6.Now you have to program the Scan Data Transmission Format found in section 5-81,5-82, pages 125,126 . PRINT IT
(This lets the scanner know to transmit the Suffix after the data.)
First scan the Scan Options Bar-code.
Second scan the <DATA><SUFFIX> bar-code.
Last scan the ENTER Bar-Code.
YOUR DONE !
Your scanner should be working now. Also look through the manual there are some nice functions that can be turned on and off with a simple bar code scan. Such as volume and tone of beep etc etc.
Hope this helps
Nate N7w7
Apr 06, 2011 | Symbol Spark LS 1004
After scanning it is automatically not going to the next line
Symbol barcode scanners by default do not add a return after a scan. You need to program the scanner to add a suffix.
Download the manual from Motorola/Symbol here
http://support.symbol.com/support/search.do?cmd=displayKC&docType=kc&externalId=5880807apdf&sliceId=&dialogID=219596399&stateId=1%200%20219598121
-Print Pages 224 and 225
-Scan the Barcode "Scan Options"
-Scan the Barcode " "
-Scan the Barcode "Enter"
Scan a barcode
Feb 26, 2011 | Symbol LS2208 Handheld
I would like to programm my barcode to push enter once when i scan a product model SYMBOL LS 1203
From the LS1203 Product Reference Guide scan Scan Options, Data Suffix, Enter. In the current version of the guide these barcodes are found on Adobe page 47 of 202.
Jan 06, 2011 | Zebra Symbol LS 1203 Barcode Scanner
How do I get my Symbol LS2208 to recognize EAN128. I need it to prefix [C1 when a EAN 128 is scanned.
you need to scan some of the bar codes found on the manual.
Find the product reference manual -usually found on the cd with the scanner or download from motorola site - and in chapter "symbologies" scan "ENABLE CODE128" barcode.
To have prefix when a code is scanned, scan "SCAN OPTIONS" then " then "ENTER"
Last set the preffix value by scanning "SCAN PREFFIX" then four digits that correspond to the character you want to use as preffix.
If you need more than one character for preffix then you will need the Advanced formatting manual, which ican be downloaded from motorola. In this case you need to create a "rule".
Let me know if you need further assistance
Nov 11, 2010 | Symbol LS2208
Hi, i am trying to configure my barcode scanner LS2208 to put a {TAB} in when scanning
There should have been a sheet or book of bar codes that came with your scanner. These codes will allow you to program your scanner to do most anything, including adding a tab. You simply look at the bar codes and read what they do. you simply scan the one that adds a tab and it will forever add the tab unless you re program it.
If you have lost your book/bar code page, you should be able to go to the manufacturer website and download/print a document with the programmable bar codes.
Feb 26, 2010 | Symbol LS2208 Handheld
I would like to transmit EAN-13 bar code without check digit, but closed by ENTER.
If you would like the LS2208 to transmit only the first twelve digits of an EAN-13 barcode followed by an enter you will have to write an Advanced Data Formatting rule using barcodes from the LS2208 Product Reference Guide found here: http://support.symbol.com/support/search.do?cmd=displayKC&docType=kc&externalId=5880806apdf&sliceId=&dialogID=114420371&stateId=1%200%20114410810
The barcodes you will print and scan in the order they are listed are:
Begin New Rule
EAN-13 (from the Critera pages of the ADF section)
Send Next 12 Characters
Send Enter key
Save Rule
If all other barcodes require an enter key make sure you scan Scan Options, Data Suffix, Enter (from the same manual or from the Quick Start Guide) before scanning the ADF rule above.
Jul 13, 2009 | Symbol LS2208 Handheld
I want to my m2004 to enter barcode scan after each scan automati
Print Adobe pages 128 and 129 of 302 of the M2000 Series Product Reference Guide and scan the "Scan Options" "Data Suffix" and "Enter" barcodes. The scanner will give two beeps after the first barcode, two beeps after the second and a warble after the third programming (Enter) barcode.
The manual can be downloaded from this link: http://support.symbol.com/support/search.do?cmd=displayKC&docType=kc&externalId=3969605apdf&sliceId=&dialogID=114420706&stateId=1%200%20114410949
Jul 12, 2009 | Symbol M2004 Barcode Scanner
Symbol LS 4007i Handheld Logo
666 people viewed this question
Top Symbol Computers & Internet Experts
Ekse
Vish Iyer
Vish Iyer
Thomas F. Schneider
Are you a Symbol Computer and Internet Expert? Answer questions, earn points and help others
