Question about Sewing Machines
The bottom stitches are all loose and they look like thread mess
It's a singer 242 c, I had it cleaned and oiled, the fixer changed a couple of things that needed the change and now it sews horrible, all nutty...
  • orianova Jan 17, 2009
    I adjusted the tension and pulled the thread as you said, now the machine doesn't sew at all, what happened? the movement looks ok, but no stitches are made...I'm puzzled
  • orianova Jan 19, 2009
    Thank you, I already called him, he's coming to fix it tomorrow, I suppose it's going to be chargeless but I'm not sure, I feel more embarrosed than he does...
  • 323 Answers
You need to do a tension test.
Normal 0 MicrosoftInternetExplorer4 /* Style Definitions */ table.MsoNormalTable {mso-style-name:"Table Normal"; mso-tstyle-rowband-size:0; mso-tstyle-colband-size:0; mso-style-noshow:yes; mso-style-parent:""; mso-padding-alt:0in 5.4pt 0in 5.4pt; mso-para-margin:0in; mso-para-margin-bottom:.0001pt; mso-pagination:widow-orphan; font-size:10.0pt; font-family:"Times New Roman";} Tension assembly test. To do this test. Pull the thread through the tension assembly and test it to make sure the tension is working correctly.
(To do this test, adjust your tension setting to normal or medium or 5 or something in the middle. Raise the presser foot and pull the thread through the tension. It should pull easily!! Lower the presser foot and pull the thread. It should pull noticeably harder.)
If it doesn’t work this way then you probably have a piece of thread or lint stuck inside the tension discs. To remove it, turn the tension to 0 zero and raise the presser foot.Using a small screwdriver, open the space between the discs and spray with canned or compressed air. The stuff should come out. Do the tension test again to make sure you got everything and then try sewing again.
sewman7
Posted on Jan 17, 2009
  • John Free Jan 17, 2009
    Remove the thread completely, change the needle and rethread the machine. If this doesn't solve the problem, contact the technician who repaired it and see what kind of warranty he has on his work and see if he will repair again under has warranty.
    sewman7
Bottom thread is a tangled mess. Was going great, now can't sew.
bottom thread mess is an indication that the needle thread tension is too loose
check the needle /hook timing to ensure that it hasn't altered
Jun 28, 2015 | Singer 6180 Brilliance 80-Stitch Sewing...
How do I fix my singer.
the problem most likely is thread tension possibly on the upper thread
It is not pulling the thread up from the bottom allowing the bottom thread to become tangled
Apr 30, 2015 | Singer Sewing Machines
Singer 2112
first ,re thread the upper bobbin, check the needle to match the fabric and the lower bobbin thread should be the same like the upper thread. If it dose not work, clean the discs tension for the upper thread.
Aug 15, 2014 | Singer Sewing Machines
When i am sewing the stiches on top, but its at the bottom
change the needle --make sure it's the right one for the fabric
being sewed
rethread the machine top and bobbin
make sure the bobbin is turned the right way in the bobbin case
also check the top thread tension, if the stitches under the fabric
are loose adjust the top thread tension one number or letter higher
at a time and sew on a scrap piece of fabric till the stitches look
normal
here is a free manual
http://www.singerco.com/uploads/download/696_5417c.pdf
Jan 07, 2013 | Singer 5417 Mechanical Sewing Machine
Stitch
Mine is doing the same thing. It's pulling the thread up from the bobbin and making a huge knot. Any suggestions. I've done all the above checks. Brand new needle, tension is on embroidery, threaded properly and no lint in bobbin compartment.
Jul 28, 2010 | Singer CE-200 Quantum Futura Computerized...
Thread is bunching up and pulling fabric into feed dogs. also breaking top thread. i have cleaned and oiled,adjusted stitch length,changed needle, re-threaded, and adjusted tension. i should note i am a...
If the thread bunches up on the bottom sometimes it is the bobbin tension. You can remove the bobbin housing and may notice a screw. This screw "tensions" the tab where the thread goes through, creating tension on the thread. Another thing to check if the machine is on a "loose/stretch" stitch setting, this will allow the elastic to freely expand and contract. You may need to also adjust the "speed" of the feed teeth, to compensate for the slack. Often there is "stray thread" in or around the bobbin, which can cause problems, One of these may be the solution, Im being general in my information.
Mar 21, 2010 | Singer 7442 Mechanical Sewing Machine
Bunching at the bottom
Is your bobbin clean and inserted correctly? (counter clockwise) A little fuzz can be a problem. Clean with a q-tip and oil if needed.
Oct 07, 2009 | Singer 3116 Simple
My sewing machine keeps getting jammed when sewing. the top stitch keeps getting tangled in with the bobbin thread and jamming up the machine.
Here are a couple of things to try.
* Un-thread your machine and remove your bobbin. Clean any loose thread or lint out of your
bobbin case. Re-thread your machine, reinsert and re-thread your bobbin.
* Change your bobbin
There could be a nick along the edge of your bobbin spool that’s catching your thread as you
sew.
* When you start to sew a seam, grasp the upper and bobbin thread tails. Hold them back
and out of the way as you sew your first couple of stitches. This will keep them from getting
caught in your machine.
I hope this helps.
Sep 11, 2009 | Singer 5160 Mechanical Sewing Machine
Loose stitches on bottom
FYI.. Loops on the bottom, problem is on the top..
Loops on the top, broblem is with the bobbin.
Apr 11, 2009 | Singer Sewing Machines
Topand bottom stitches are not even
Could be a tension issue.
Try this to see if it helps:
Remove top thread.
ALWAYS RAISE the presser foot and rethread from the beginning.
Start the top tension set at the midway point and then adjust.
Check that the bobbin is threaded and installed correctly.
Understanding Thread Tension Threads
Sewing Lesson 10 How to Fix Tension on Your Sewing Machine
Apr 22, 2017 | Singer 7436 - INGENUITY
Sewing Machines Logo
167 people viewed this question
Top Sewing Machines Experts
Tally Girl
Tally Girl
Are you a Sewing Machine Expert? Answer questions, earn points and help others
