Question about Campbell Hausfeld 2 1/2" Finish Nailer Kit CHN20199
When pulling trigger air blows but does not fire
I am using a Cambell Hausfeld finishing air nailer. It fired two times and now is blowing air when I pull the trigger but will not fire when pressed against a board. The nailer is brand new and has very little use. Working on baseboards.
  • Blake Whitley May 11, 2010
    what is the air pressure? you need to be at 80 -90 psi
I have the same problem and found the fix. The angled bar from the foot to roughly the trigger is not pushing the trigger release in far enough. If you push the relase in manually, it will fire. Then you can adjust it accordingly.
Posted on Feb 21, 2010
  • 25 Answers
This problem can happen because of several reasons.
Most likely the driver stuck, and not able to move.
First with the tool disconnected from the air supply check to see if there any nails jammed in the nose piece.
If the driver is stuck down, try to push it up. Will it move?
If there are no problems visible at this point you will have to open the tool up, and see if anything looks out of place.
To examine the inside of the tool, unscrew the 4 bolts on the cap of the tool. Gently remove the cap, it may be spring loaded but once the bolts are loosened, there is no reason to be afraid of the parts springing out. Be careful not to let the parts that are in the head cap fall out. Also take care not to rip the gasket. Keep in mind, the less parts inside that you disturb the better so be careful.
If the piston driver does move. Does it move freely?
Sometimes when a driver hits a very hard knot in the wood, or if a nail is hit. The thin driver may bend. If it is moving but with resistance. Use a thin object to push the driver upward from the nose. It will come out of the head cap end.
Check to see if the driver is straight and square to the piston. If it is bent, you may need to replace it. Sometimes you may be able to bend it back enough to allow the piston driver to move freely.
If this solves your problem. To reassemble:
Replace the driver in the correct position. Replace the gasket if it is loose. If parts came out of the head cap, reposition them into the cap. Replace the head cap on to the tool. Replace the bolts, stagger as you tighten them to depress spring loaded parts evenly.
Hook the tool up to your air supply check for air leaks, and fire the tool.
If the driver does not move: Examine to see what is seizing the piston and reply back.
I hope this works!
Posted on Apr 18, 2009
Bostitch just blows air when trigger is pulled
Air leaking from trigger when attempting to fire the gun is normal and should cause nailer to fire, however if the trigger pin is not depressed all the way in,the gun may not respond. Easy test. Remove the nails and remove the trigger. Connect the gun to air and quickly depress the valve pin all the way in with finger. If the gun fires, adjust the safety foot so that the trigger pin is depressed all the way in. If the gun still does not fire, then remove the head cap and pull out the headvalve. Apply plenty of white grease to orings and retest. If the gun fires, then replace the headvalve orings. When the headvalve orings are worn, air will leak from bulkhead chamber to the headvalve chamber causing the gun to not respond to the trigger. The addition of grease to worn orings will make them temporarily seal. Good luck
Jun 16, 2016 | Stanley Bostitch N66c1 114"to 212" Coil...
When my Senco SLP 20 brad nailer is connected to air hose, air will blow-by through the exhaust. After you fire a couple of pins blow-by stops
Most problems with this gun centers around the firing valve part # Bao119 . This part must not get any oil because it will swell and begin to fail as you describe. That being said, the trigger valve does need some type of lubrication or it will become sticky causing problem that you describe. If you have been using oil in the gun, most likely inner trigger parts will be lubricated and failure is firing valve. If no oil has ever enter the gun, suspect the trigger valve. It will need to be removed from the gun and lubed with white grease or silicone lube. Good luck
Dec 05, 2014 | Air Tools & Compressors
Why doesn't the trigger do anything on my NS289000 framing nailer?
Nailer not firing is caused by lack of lubrication in the headvalve (lube with white grease) or driver stuck/bent (make sure driver moves freely) or safety foot not depressing the firing pin on the trigger valve all the way in. Easy to check. Remove the trigger to expose the firing pin. With no nails in gun, connect air and depress the firing pin with finger all the way in. If the gun fires, adjust the safety foot. If the gun does not fire, lube headvalve and check driver piston stuck. Good luck
Dec 03, 2013 | Campbell Hausfeld Ns2890 Framing Nailer...
The framing nailer blows air out the exhaust,and will not fire a nail when I pull tre trigger
take of clylinder head when off there is a large button make sure its fre should work like a door bell switch grease slightly and put together again
Aug 28, 2011 | Stanley Bostitch Coil Framing Nailer
Only shoots out one nail for every 4 or 5 trigger pulls
The gun will miss fire if the driver does not return to top position allowing nails to move into position. Could be bent driver, faulty trigger, cracked lower bumper or check valve not in place. Easy to check if trigger. Remove air supply, and remove the pin holding the trigger. Fire the nailer by depressing the firing pin with your finger. If the gun works ok, single fire trigger is faulty or safety foot is out of adjustment. If still miss fire, remove head and pull out cylinder and piston. Check for bent driver, cracked lower bumper or black band (check valve) is out of place on outer part of cylinder covering a row of holes.
Aug 23, 2011 | Porter Cable Cable Factory Reconditioned...
Bostitch RN46 will not fire nail, only releases air when trigger is held and firing tip is touched to surface of material. Any ideas on what is wrong?
Gun will not fire if air is leaking past orings in head /headvalve or safety /trigger is not pushing trigger pin all the way into trigger valve. Test: Remove trigger to expose trigger valve pin. Remove nails. Place nose of gun against thick rubber mat or coiled rubber hose to absorb blow of driver. Very quickly and deliberately press trigger pin all the way in. If gun fires, safety foo or trigger is not pushing trigger pin all the way in. Make adjustments or replace worn parts. If gun still does not fire, remove head and pull out headvalve. Apply lots of silicone paste lube on the orings and the surface of the head where orings make contact. Reinstall head and test as above. If the gun fires then orings were leaking. Replace orings and sand any scratches on body of cap with very fine sand paper. Parts are at www.toolpartsdirect.com Good luck
Mar 06, 2011 | Stanley Factory Reconditioned Bostitch...
Cambell-hausfeld framer
its double firing, after firing gun pull back, what is happening is when you fire a nail your pushing the gun back onto the wood and its putting another nail in
May 08, 2009 | Campbell Hausfeld 2" 18GA Brad Nailer
Campbell Hausfeld 2 1/2" Finish Nailer Kit  CHN20199 Logo
945 people viewed this question
Top Campbell Hausfeld Air Tools & Compressors Experts
John Trevino
Joe Garcia
Joe Garcia
Are you a Campbell Hausfeld Air Tool and Compressor Expert? Answer questions, earn points and help others
