Question about Epson Stylus Multifunction Inkjet Printer/ Copier/ Scanner
Epson printer: print head not moving to replacement position
Hi, I have an Epson Stylus DX7400 printer. I want to change one of the ink cartridges and followed the instructions in the manual, which says "press stop ... and the cartridge holder will move to the replacement position". It did this when I previously changed cartridges but now it suddenly won't move when I press the stop button. The button itself works however, I held it down for three seconds to give the print head a clean and that seemed to work fine. So I am guessing there must be something wrong with the printer's software. Do you know if there is a way to fix this problem myself? Thanks Marianne
  • 2 more comments
  • Anonymous Jan 20, 2009
    I have the same problem. It is late and I need to print work for tomorrow and I cannot change the cartridge because, it is not moving to right position. Very frustrating.
  • sheilamalcol Jan 22, 2009
    print head wont stop when i want to change ink
  • mcwi Apr 23, 2009
    I have the same problem but by accident I went into the Manual and it said click on o.k.on this page and the carriage will go into the replacement position .I did this and it worked perfectly. Unfortunately tghis happened again and I cant remember how I found the relevant page
  • Anonymous May 05, 2009
    on a DX7400 the black was changed and we continued printing. now it wont print at all, however copying still works.
    so we wanted to change the color cartrdidges but the carrier wont leave its little cosey nest -.-
    now what?
    and yes the drop is blinking
Click on Epson, then Monitor status then Properties then replacement. A page will come up saying To get carriage into position click O.K. on this page. When you do that the carriage moves into position and you can take out the old cartridges and replace them
Posted on May 23, 2009
    Sergeant:
    Champion:
  • 357 Answers
Unplug the printer when the head reaches the point where you can take out the cartridge.
After you have replaced the cartridge, plug the printer back in.
Good Luck.
Posted on Feb 16, 2009
  • 31 Answers
GET YOUR SOLUTION FROM EPSON
HERE IS YOUR SOLUTION
http://www.epson.com/printer/prob676ijt65/solution
Epson printer: print head not moving to replacemen - 555f948.jpg
a6
Posted on May 22, 2009
2 Suggested Answers
SOURCE: Have epson stylus dx7400 without cd. Want to
I have an Epson stylus DX7400 for some reason when I installed the printer language is in German. My disc is broken therefore I am unable to reinstall. What can I do?
Posted on Dec 07, 2010
My printer is not recognising the replacement ink cartridge although I've used these before many times
If you have just installed a new cartridge and you still see an ink related error, the cartridge may be incorrectly installed. Follow these steps to make sure the cartridges are correctly installed:
  1. Make sure the Epson Stylus is turned on.
  2. Do one of the following:
    • If your printer indicates that an ink cartridge is expended, press OK.
    • If your printer does not indicate that any ink cartridge is expended, press Setup, select Maintenace, and press OK. Then select Change Ink Cartridge and press OK.
  3. Open the scanner.
  4. Open the cartridge cover.
    Caution:
    Never attempt to open the cartridge cover while the print head is moving; wait until the cartridges have moved to the replacement position.
    To avoid damaging the Epson Stylus, never move the print head by hand.
  5. Press down all the ink cartridges until they click into place to make sure they are properly seated.
    Note:
    If a cartridge is properly seated already, you may not hear a click.
  6. Close the cartridge cover and press it until it clicks into place.
  7. Close the scanner.
  8. Press OK to begin charging the ink. This takes about 2 minutes.
    You see a message on the display screen when ink charging is finished.
    Caution:
    Never turn off the Epson Stylus while the ink is charging or you'll waste ink.
If the issue persists, it appears to be an issue with the cartridge(s). Contact Epson for further assistance.
Sep 25, 2014 | Epson Stylus DX8400 All-In-One InkJet...
Have an epson stylus nx110 printer and have to replace ink cartridge. the cartridge holder will not go into place so that i have access
Find the NX110 in the printers section of the control panel. Then right click your printer and choose "Printing Preferences" then the "Maintenance" tab. In there you will see a button for 'Replace ink cartrige'. Select that and it will take you through it step by step and even move the print heads to the correct position so you can change the ink.
Mar 13, 2010 | Epson Stylus NX400 InkJet Printer
Changing ink cartridge
Press the Stop button. The print head moves to the position to indicate which cartridge is low or expended.
If you need more step by step instructions, follow this link...
http://files.support.epson.com/htmldocs/nx110_/nx110_ug/wwhelp/wwhimpl/js/html/wwhelp.htm
Mar 08, 2010 | Epson Stylus NX115 All-In-One InkJet...
How do i get the cartridge out
Press the fontb1.gif maintenance button. The print head moves to the black or color ink cartridge replacement position, the fontp.gif power light begins to flash, and the fontb1.gif error light begins to flash or remains on. When both cartridges are out of ink, the print head moves to the black ink cartridge replacement position first. After replacing the black cartridge, press the fontb1.gif maintenance button again to switch to the color cartridge replacement position.
Oct 20, 2009 | Epson Stylus C40UX InkJet Printer
Can not change ink for epson c 91
cannot change ink. Turn on, and just unplug power when cartridge is moving. cartridge will stop not in parking position. Just move head carriage to replacement position.
Jun 21, 2009 | Epson Stylus Photo 1400 Printer
Cant change ink cartridge on my Epson C91
cannot change ink. Turn on, and just unplug power when cartridge is moving. cartridge will stop not in parking position. Just move head by hand to replacement position.
May 02, 2009 | Epson Stylus Photo 1400 Printer
Change ink cartridge on epson stylus SX200 -printing head moves from side to side but then parks to the R and I cannot get access to change the cartridges.........
The ink cartridges are all separate so you press the cancel button (with no jobs pending) to bring the cartridge holder in to the right place open the holder remove the cartridge and then replace it, let the printer purge the cartridge then your good to go
Mar 24, 2009 | Epson Stylus Photo R320 InkJet Printer
Epson dx7400 printing green
one of your people advised me that it was most likley a bad cartridge i changed it and it worked ,thanks
Feb 04, 2009 | Epson Stylus Multifunction Inkjet Printer/...
Here is how to get the ink cartridges to move to the changing position on the R320.
1. Press the paper jam/ink button on the printer control panel.
2. A menu comes up. 1st item is ink cartridge replacement. Press
OK button.
3. Another menu with ink cartridge replacement. Press OK button.
4. Thats it, ink cartridges move to the changing position. Change your cartridge as you normally would and follow prompts on screen to finish process.
Hope this helps.
Aug 05, 2008 | Epson Stylus Photo R320 InkJet Printer
Epson Stylus Multifunction Inkjet Printer/ Copier/ Scanner Logo
3,814 people viewed this question
Top Epson Office Equipment & Supplies Experts
Alun Cox
Are you an Epson Office Equipment and Supply Expert? Answer questions, earn points and help others
