Oil light came on and I parked the car. I checked the oil level and was a little low so add to the fill line. the light went off so i went to work but when I was coming home the oil light came on and went back off. It did this all the way home so I just change the oil again and replaced the oil sending unit but light is still on.
SOURCE: Low oil pressure light goes on until car warms up. Oil level is good
The oil pressure sending unit has gone bad. I sending unit is just above the oil filter and you can get to it from the top. When you face the Engine look down towards the oil filter, the oil pressure sending unit is just above that and it looks like a cylinder with two wires coming from it. If you don't see it, it's right between the exhaust manifold and oil filter.
If you go to Auto Zone or Parts Source, they'll have the oil pressure sending unit and the step by step instructions, When installing the new sensor. Do not use teflon tape or any sealant, the sensor is tapered and need's the good ground from the engine to give you right readings.
Good luck and hope this helps.
SOURCE: Check Oil light stays on even after the oil has been changed
well, it is in the manual under engine oil. turn key to on, dont start. press gas pedel to the floor "slowly" 3 times within 5 seconds. if the change oil light flashes, its resetting. If not, repeat.. this worked for me.
SOURCE: 2001 olds intrigue
in each wheel you have a traction control sensor that feeds info to the computer. You may have pinched one of the wires. I also had the same thing happen and found that was the answer.
SOURCE: 2001 oldsmobile intrigue, won't keep a charge?
This is my second oldsmobile i have owned. Now there is two positive connections right above where the battery is make sure they are free of rust and they are tight be careful not to over tighten nuts. Oldsmobile's are terrible for those external positive posts.
SOURCE: oldsmobile aurora where is the oil sending unit
It should be on the left side of the engine(front of car) wiring runs under and around oil pan maybe wires are torn or pulled out of connector.oil sending unit is usually right in the same area of oil filter.
