Question about Acer Aspire 1640Z Notebook
Need help with new install
Reformatted file system to ntfs because we were having probs with fat32. now i cannot get wireless system to work. im doing a fresh install today to wipe system clean. is there someway to get wireless to work right?
  • watcher6342 Jan 17, 2009
    no , i have no idea. i boughtit off of a friend. they didnt have a backup disc or anything. i tried downloading drivers from acer but still could not get wireless to work.
    nothing worked. am going to try and find drivers for acer
    Genius:
  • Acer Master
  • 1,102 Answers
Check in my computer properties hardware then device
see if your connection shows under network if it does click and do a driver update
if not i can help you get your connection
do you know what your driver is
did you get any software for your wireless
Posted on Jan 17, 2009
  • DEKR
    DEKR Jan 17, 2009
    Okay
    contol panel add new hardware if your connection shows high light and click next if it does'nt show
    click next follow instructions
    when the page comes up scroll to networks click and then click to automatically search
    see if it's found there if not we'll try something else
    be back in half hour
  • DEKR
    DEKR Jan 17, 2009
    you should be able to find the proper drivers and save memory stick
    then run them and install on the pc your try to connect
How do i remove parameters from a kanguru 4 g usb flash drive?
Which format fat32 or ntfs make sure its fat32 Indeed, FAT32 only supports files up to 4 GB. I ran into the same problem when copying an ~4.5 GB file to an 8 GB flash drive. There is a quicker solution that doesn't require you to reformat or lose data on the drive, using the command-line "convert" command. Suppose the flash drive is mounted to g:\. Open up a command window (start menu -> run -> cmd), and type: convert G: /FS:NTFS. Personally, I don't need the "security descriptors" on the flash drive file system, so I use the variant: convert G: /FS:NTFS /NoSecurity. The conversion should be very quick, and of course it has the benefit of not needing to move any files off the flash drive (since you don't need to reformat it). Hope this helps.
Dec 18, 2012 | Kanguru 4GB FlashBlu II USB 2.0 Flash...
Tip
How to Convert NTFS External Hard Drive to FAT32?
My friend Michael bought an external hard drive last month, yesterday he ran to me and ask how to convert external hard drive from NTFS to FAT32 safely and easily? I was so curious about why does he want to convert NTFS to FAT32; he said NTFS partition can't be read by DOS system. Since protecting data and files, I recommend him to convert external hard drive from NTFS to FAT32 with a third-party software-AOMEI Partition Assistant, which can convert hard drive from NTFS to FAT32 without data loss.
To computer users, NTFS and FAT32 are not strange. But seldom of them can tell what the difference between them. NTFS and FAT32 to partition are what DOC and TXT to text. In text, the file with DOC format can't be read by TXT application. Similarly, in some condition, not all files in different formatted partition can be read by same application. First, you'd better know some knowledge about NTFS and FAT32.
A Brief introduction of NTFS and FAT32
About FAT32
FAT 32 is one of partition format in windows system. It has 32bit file table, which strengthen FAT32's management to partition, and break through the limitation of 2GB space in every partition. Since the production cost of hard drive decreasing, the volume capacity is increasing. After applying FAT32 partition format, a big volume hard drive can be definite as a partition but not be divided into multiple partitions. It is good for management to hard drive. Now, FAT32 is replaced by NTFS.
About NTFS
NTFS is standard file system after Windows NT, 2000, XP, server 2003, server 2008, Vista, and 7. It replaces FAT to offer file system for Microsoft. NTFS make advanced on FAT and HPFS, such as to support metadata.
The difference between NTFS and FAT
As mentioned above, NTFS and FAT both are file system. However, NTFS is produced late than FAT32, but NTFS is more advanced in technology. In summary, the specific distinction are following below:
NTFS can support up to 64GB single file and 2048GB partition. FAT32 supports up to single file with 4GB and partition with 32G.
NTFS does not need Defragment your hard disk.
NTFS support to compress partition, folders and files.
NTFS takes a little cluster, which can help to manage space of hard drive effectively, and avoid wasting space of hard drive at the most extent.
In NTFS partition, you can share sources, folders and set access permissions on files. It is more secured than FAT32 partition.
How to know which partition format is suitable for you
As mentioned above, NTFS and FAT32 have its own advantages. When we choose which file system, you should consider the factors below:
Computer is installed with single system, or multiple systems.
The number and capacity of local installed hard disk.
Whether has consideration about security or not.
If computer is installed single system, and there is security to consider, you can select FAT32. Or NTFS is not bad choice absolutely.
Why need to convert NTFS External Hard Drive to FAT32?
NTFS and FAT32 are two different types of file systems, and both of them are commonly used and contain different characters. You may make conversions between the two types, and here we got several cases that you need to convert external hard drive to FAT32:
If your external hard drive is formatted in NTFS, you would not be able to access some files from DOS mode or Windows 9X, then you need to covert external hard drive to FAT or FAT32.
NTFS can't be recognized by many devices, such as Xbox 360, PS3, etc. in that case, you have to convert the external hard drive to FAT32 so that it can work with your devices.
There are more situations in which you need to convert external hard drive to FAT32, and there are different ways which you may realize the goal.
Methods to convert NTFS External hard drive to FAT32
At present, there are two main ways that you may convert external hard drive to FAT32, one is to convert to FAT32 with Windows built-in Disk Management, and another one is to convert to FAT32 with third-party software like AOMEI Partition Assistant. Let's see the details:
Method1: Convert an External Hard Drive by reformatting
1. Open the Disk Management in Windows.
2. Right click on the external hard drive and select "Format..." in the drop-down menu.
3. Select "FAT32" in the "File system" line and then choose "Quick format".
4. Finally click "Start" to format, and this process may cost you minutes.
Note: If the drive is larger than 32GB, the "FAT 32" option would be invalid and once format, the information or data in the external hard drive will disappear. So, backup the data or partition if necessary and you need to know how to convert hard drive larger than 32GB into FAT32.
Method2: Convert an External Hard Drive without formatting
You can download the third-party software to convert external hard drive from NTFS to FAT32, what is the most advantage is that convert NTFS to FAT32 without data loss. Comparing with disk management in computer, the third-party software will save your time and money. You don't need to buy other external hard drive to store data, just for converting partition format. Of the third-party software, AOMEI Partition Assistant is good choice. The specific introduction of how to convert NTFS external hard drive to FAT32.
As a kind of advanced partition software, AOMEI Partition Assistant can easily convert an external hard drive to FAT32, and you can also convert an external hard drive larger than 32GB into FAT32. This software is running well with Windows platform including Windows 2000, XP, Vista, Windows 7 and Windows 8. Both 32-bit and 64-bit Windows editions are supported. With its help, you need no to format your external hard drive and thus you can convert NFTS to FAT32 without data loss. Now, you may download AOMEI Partition Assistant Pro Edition and have a try.
source from
on Dec 29, 2017 | Computers & Internet
I need to replace the (failed) HD with a Seagate 80GB which is currently formatted FAT32. Is this OK or do I need to reformat as NTFS? Using WinXP
I'd use NTFS but you can make up your own mind here....
http://www.microsoft.com/resources/documentation/windows/xp/all/proddocs/en-us/choosing_between_ntfs_fat_and_fat32.mspx?mfr=true
If you have old computers that need to access files on yours go FAT or FAT32. If you intend to or would like to add huge hard drives in the future (over 2 TB) go NTFS.
Regards
TickMagnet
Aug 19, 2011 | Dell Dimension 2400 PC Desktop
I convert the file system of my sansa e250 to FAT32 and now it says release 6MB space even though no songs is there to play..not sure how to resolve it or revert back it now. -Rohit
Hook it up to your pc again via the usb cable and format it again, choosing NTFS file system. If you are running Windows XP you might only have option for FAT32. If you do reformat in FAT32 and it still doesn't work, you may need to download a drive management utility that can format a removalable drive in either NTFS or FAT32. If all else fails, you may need to download and install a flashing utility from the manufacturers website to revert the player back to factory condition.
Apr 24, 2011 | SanDisk Sansa e250 MP3 Player
The parameter is incorrect
which format fat32 or ntfs
make sure its fat32
hope this helps
Mar 03, 2011 | Seagate FreeAgent Go 320 GB USB 20 Hard...
My new 500 G external hard drive seems to limit the file size under 5 G. Is there somewhere I can reset this to larger file size?
A disk may be formatted using different file systems. The ones used by Windows PCs are FAT32 (an extension of the old MS-DOS FAT) and the newer NTFS.
If the drive is formatted as FAT32, the maximum file size is 4.294 million bytes (some systems report this as 4.294 GB; it is actually 4 GB minus one byte).
If this is the case (Start -> Run Command -> DISKMGMT.MSC and look for your external drive, it will say something like 489 GB NTFS or 489 GB FAT32), my suggestion is to back it up somewhere else and reformat it as NTFS. There also are utilities to convert FAT32 into NTFS, but if anything goes wrong during the conversion, you can say goodbye to all your data.
Note that you won't be able to access a NTFS formatted external drive except from Windows PCs (and most Linux, usually read only), while FAT32 disks are readable from Mac OS X too.
Nov 03, 2009 | Acomdata HybridDrive E5 Hard Drive
Im tryin to burn a movie with dvd flick when i click create dvd i get a warning "Its recommended to put your project destination folder on a drive with the ntfs file system. older systems like fat32 cannot...
to fix this you just need a harddrive above ten gigabytes(each movie can take up ten gigabytes)and the harddrive needs to be ntfs.you can only put fat32 on a drive that is less than 30 gb.i would not recomend using fat32 its faster than ntfs but less secure.you can either get another harddrive with a ntfs files system or reimage the os and make it ntfs.fo that you need a xp installation disk
Jul 30, 2009 | Computers & Internet
Reformat my external drive to NTFS
The only risk associated with file formats is that a drive formatted with FAT32 file system will not see NTFS formatted file system, whereas, a drive formatted with NTFS file system will definitely see FAT32.
To make it clearer, this means that, if on your system, your hard drive which is having the operating system installed on it, is formatted with FAT32 file system, and you bring an external drive, or even a backup drive which is formatted with NTFS file system, and you plug it to your system, the system will detect it but it wont be able to access the full drive capacity, you will just see it in the device manager page that it is connected.
But If it is Vice-Versa, the NTFS formatted drive will detect the FAT32 drive.
Now in your own case, if your system is formatted in NTFS file system and you plug in your external drive which is NTFS formatted also, from what you have said, I suspect that you have some hidden partitions on your harddrive (the 250GB), so when you plug it, try and do this, Right-Click on my computer icon, select manage, then go to Disk Management Option.
On the Disk management option Page you should see ALL the drives installed on your system, including the hidden ones, so what you will just do is, try and locate the one representing your external drive, and right click on it. then select "Change Drive letter and Paths", and give the drive any new, unique letter (i.e alphabet) different from the ones already on your system, and click on OK.
If you see any other hidden drives there, do the same thing to it.
This should make your External Drive to be detected automatically.
Hope this helps you out.
Jul 15, 2009 | Western Digital My Book Essential Edition...
Not able to put big file on it like 4,7GB files..
Make sure its formatted in NTFS format, FAT32 can only handle files upto 2GB
To be able to formt it to NTFS you have to go to Device Manager and set the policy of the USB Stick device to "Optimize for Performance". The default is to optimize for Quick Removal, which restricts you to the FAT filesystem
Apr 21, 2009 | Computers & Internet
Need to Reformat my Western Digital 500 Gig Hardrive
Simple, you have to format it by selecting Dos Drive which supports NTFS format.  or else try other option which is to format it in PC computer be sure you will select the NTFS format not FAT32. Im sure you can use it now to both Mac and PC.
Dec 11, 2008 | Western Digital My Book Essential Edition...
Acer Aspire 1640Z Notebook Logo
29 people viewed this question
Mohammed Ebrahim M
Mohammed Ebrahim M
Alun Cox
