Question about Gem Sound SUB-650M Speaker
Klipsch sub 10 keeps blowing fuses
My sub blew a fuse about 2 weeks ago and everytime I put a new fuse in it and power it up the fuses blow
  • 56 Answers
More than likely the power supply switching transistors have fried. Also check the large caps in the primary side of the power supply. If you don't know what your are doing do not attempt to fix the power supply.. very dangerous voltages involved !!! Send it to Klipsch for repair or purchase a Bash replacement panel http://www.parts-express.com/pe/showdetl.cfm?Partnumber=300-750
Posted on Apr 13, 2009
    New Friend:
  • 60 Answers
There is a repair shop Edwards Electronics they are master's at repair. They are on web and eBay.
Posted on Jul 30, 2017
Ignition fuse switch keeps blowing
you have a short in that circuit chck your harness for wiring that might be exposed to ground or pinched
Apr 13, 2014 | 2006 Kia Sedona
Vr v8,engine fuse keeps blowing,what could be wrong? i have just replaced fuel pump
My friend had same problem so i waited till fuse blew an what i was doing when it blew the nutrel safety was getting hot replaced it now he is good to go
Oct 14, 2017 | Cars & Trucks
Gemini gvx15p powered subwoofer keeps blowing fuses
Fuses blow when there's an overload. Mostly caused by a semi-conductor device such as a transistor or IC that has become short-circuited. Transistors are easy to spot as when an Ohm-meter is placed on the terminals the ohm-meter will behave like you have touched the test probes together!
Jun 03, 2013 | Audio Players & Recorders
My klipsch ten inch subwoofer is making a high pitch whinding sound when the sub is turned on
my fuse keeps poppin everytime i put a new one when i turn it on how can i fix dat?
Aug 01, 2012 | Klipsch Synergy Sub-10 Subwoofer Speaker
2000 ford escort zx2 fuel injector fuse keeps blowing i dont know what to do replaced 4 fuses within the last 2 weeks and 2 of them were 40 amp fuses
checm fuse box for loose wire connection accelerating will cause it to push to many ampps and blow fuse make sure fuse prongs are nor loose
Jul 12, 2012 | 2002 Ford ZX2
Hi, we moved the sub woofer from its original position and now it keeps blowing fuses. I would like to repair the sub woofer, as it works well and is quite new. I live on the south coast of NSW...
Where was it sitting before it was moved? Did it have it have more ventilation and keep cooler? This sub has a powerful amplifier in it. If it got moved to an area that restricts air circulation around the sub more it is possibly overheating and causing fuses to blow. Put a fan on it and make sure it is on a hard surface or up off the carpet at least to keep the bottom side cool as well. Also when one moves a speaker it's often to put it into a more convenient area to be able to turn it up louder with less disturbance to others. This will draw more power and create more heat within the amplifier than it's previous location. If this is so keep it as cool as you can and turn it down every so often to give the amp a rest. The key here is to keep it cool as you can. One thing you never want to do is put a higher rated fuse in than the unit is rated for. Always use factory recommend fuse rating.
Mar 22, 2011 | Klipsch Synergy Sub-10 Subwoofer Speaker
Klipsch ksw subwoofer wont power on
The power supply switching transistors are likely fried. Dangerous high voltages involved. I would remove the plate and send it to Klipsch for repair.
Jan 16, 2009 | Gem Sound SUB-650M Speaker
P3001 amp may be fried
Check this out: http://www.techlore.com/article/14696/
Aug 06, 2006 | Rockford Fosgate P3001 Car Audio Amplifier
Gem Sound SUB-650M Speaker Logo
7,631 people viewed this question
Top Gem Sound Audio Players & Recorders Experts
 Grubhead
Grubhead
brian williams
Are you a Gem Sound Audio Player and Recorder Expert? Answer questions, earn points and help others
