Question about Envision EN-7100e 17" Flat Panel LCD Monitor
Flat screen monitor
When i turn the monitor on it comes on then shuts off and stays off like the backlight is out, how do i fix this problem? Mine too !!! The screen comes on for about a second, then shuts down. It does this after the screen has been shut down for several hours of non use. It will come back on , and stay on, after many, many attempts. Then it is perfect until it is not used for a couple of hours. Seems like it misses the connection from the computer. Like: The light comes on yellow, goes to green and the screen goes off. Any Help????? Or is it ready for the graveyard? THANK YOU !!
  • Neil Kepner
    Neil Kepner Jan 20, 2009
    It pointed me in the right direction. However, the cost of repair dictated the purchase of a new unit.
  • Anonymous Jan 22, 2009
    have the same problem went i boot the machine i have try different computers but the same problem i have sent and email to envision to see if they can help me if not where i can find that part to fix the monitor i am a college student any help appreciated.
    Genius:
  • 2,120 Answers
Possibly a bad inverter that turns on the fluorescent backlight or a bad bulb.
Posted on Jan 17, 2009
Hp flat panel monitor comes on shows logon and then blank screen
Ok, another words, monitor powers up for few seconds and shuts down by itself. If green LED on the front panel turns off as well or stays on?
If stays on, then inverter turns into protection mode because of old backlight lamps.
If it turns off in same time with an image on the screen, then there are some bad electrolytic capacitors in the power supply.
Sep 11, 2009 | Dell E152FP 15" Flat Panel LCD Monitor
My monitor fpd2275w gateway turns on but the screen is black
mine does it too...it seems to be that the back light is not staying on...seems to come on full brightness for about 3 seconds then goes out, there are images...but no backlight
Aug 27, 2009 | Gateway FPD2275W LCD Monitor
PLANAR Flat screen goes blank and then wil not come back on, blinks a second then dies.
Hi...there
Sure, you can fixed by replaced the backlight inverter or repaired it.
Oct 31, 2008 | Planar PL1910M (Black) 19 in. Flat Panel...
Black screen monitor
souns like the dc-dc convertor board that supplies the backlight gone faulty possible poor soldering on board
Oct 07, 2008 | Mag Innovision LT782S 17" Flat Panel LCD...
Screen going black, green LED staying on
Check to see if the image is Dimmed. Chances are the power supply on the FPD is either dead or not supplying power to the back lights.
Your problem is the power supply or the inverter on your board, you can replace it and it will be fixed.
Easy Fix REALLY EASY FIX
(inverter is what supplies power to your backlights. A lot of the times the reason a monitor goes black and the green power button is on, is because the backlights shut off. in most designs of the 1730 the inverter is embedded on the power supply. That is most often the case on this problem. Power supply/Inverter=Replace it and you will have a spanking new looking nice monitor working again. :)
Jun 19, 2008 | Gateway FPD 1730 17" Flat Panel LCD...
Monitor shuts off but green light stays on
I perhaps can. I would think inverter or ccfl's.
Jun 12, 2008 | Dell UltraSharp 2407WFP 24" LCD Monitor
Hp pavilion f1503 wont stay on
is your computer still running after the screen goes blankl
Jun 09, 2008 | HP Pavilion F1503 15" LCD Flat Panel...
Screen won't stay on
This is a common problem with LCD monitors after a few years of use. The capacitors in the power supply board start to fail and this prevents the monitor from starting up correctly. Sometimes you get a picture and then it goes black. On some units you can keep pressing the power button and after several power up cycles the monitor will work until you turn if off. These symptoms are all common with capacitor failure. The monitors are well out of warranty now so Viewsonic will not cover the repair cost. But the repair is very easy to do yourself. You just have to replace the 6 power filter capacitors on the power supply board. Here is a link to additional information on this repair.
http://www.ccl-la.com/catalog/product_info.php?cPath=21_34&products_id=218
I hope this helps, I have repaired over 30 of this model with the same issue.
Mar 28, 2008 | ViewSonic VA902b 19" Monitor
Flat screen monitor
If the backlight was out it would stay on but you would see nothing (or very very faint) ....test it on another device...laptop or PC...I'm thinking it works still but maybe your video card bit the dust or maybe computer is not getting past the post (bios boot)... Good luck
Aug 28, 2007 | ViewSonic VG700 17" Flat Panel LCD Monitor
Dell ultrasharp 15 inch flat panel lcd
It totally sounds like the backlight is toasted. If that is the case you will have to replace them. Normally if the power inverter is shot, the monitor will power up briefly at least and then shut off. If you can use a flash light and see some sort of image on the screen you know that your VGA chipset works however your backlight(s) are burnt out. If not, more than likely your power supply (power inverter chipset) is broken and needs to be replaced..
Mar 28, 2007 | Dell UltraSharp 1704FPT 17" Flat Panel LCD...
Envision EN-7100e 17" Flat Panel LCD Monitor Logo
190 people viewed this question
Top Envision Computers & Internet Experts
Cleverer2
Steve
Martin Murray
Are you an Envision Computer and Internet Expert? Answer questions, earn points and help others
