Question about Nintendo DS Lite Console
Nintendo DS Lite screen is not working properly
The Nintendo DS Lite was plugged in for a while to charge. We forgot to unplug it when it was done charging.Now the screen is like a 70's tv. A lot of colored lines and we can hear the music but no screen. Can you help?
  • lunasea808
    lunasea808 May 11, 2010
    Just to let you know just because you left in on the charger doesn't mean that was the cause if it. My daughter ds is left on the charger when not being played with no problems.
    Sounds like it might have been dropped and put back to hide that fact. I could be wrong but are you using any type of mods to your Example: R4 or iTouch ds, etc., etc....
  • 33 Answers
I leave my DS on the charger all the time with no problems. You are going to get a lot of people telling you this, so be ready.
Anyway, way the DS dropped, stepped on, or had something spilled on it? That could very well be the cause.
Another problem could be the charger. Look and see if the charger is torn, has something on it ( Juice, sticky stuff, or something that really shouldn't be there), and by something on the charger, I mean something on the head of the charger that you plug into the DS. The wire could be torn up and frayed too.
You could also get the DS refurbished. This should correct the problem. Refurbishing is cheaper than buying a new one, refurbishing a DS costs anywhere from $70 to around $90.
Hope it helps~
Posted on Jan 19, 2009
Nintendo ds lite help
Maybe the battery is defective. try to replace it.
Jun 29, 2010 | Nintendo DS Lite Console
Ds lite comes on for a sec when charger plugged in then it goes of unit does not come on or charge
Hi three things come to mind, you dropped it but usually they wont admit it (dont go mad they usually all break when you do) if it rattles the capacitor under the power switch just fell off (common you have to solder it back on) if not that you replaced the bottom screen and forgot to insulate the metal of the back of the screen against the circuit board and blew either the f1 or f2 fuses (Replace them if you did) last thing i wont go into if you havent pulled it apart if you have reply and i will tell you Good Luck
May 20, 2009 | Nintendo DS Lite - Onyx
DS lite was dropped and now it won't work.
They usually don't work properly after they've been dropped. Nintendo carries a 1 year warranty, they will replace it for free (but not if you've used cheat codes (Action Reply), etc). I wouldn't mention that you've dropped it when calling them.
Mar 28, 2009 | Nintendo DS Lite Pink Console
Nintendo DS Lite won't turn on unless game is plugged
well you could charge your ds and whil its charging you can turn it on
Mar 16, 2009 | Nintendo DS Lite Console
NINTENDO DS LITE WON'T CHARGE OR POWER ON
Each time you charge your battery, the charge capacity is decreased. After a large amount of charges, the capacity is decreased to an amount only enough to turn on a/the screen(s) for a second. Try getting a new battery.
Mar 02, 2009 | Nintendo DS Console
Nintendo dslite wont turn on.tried charging it wit 3 different charges and it still wont charge
Ensure that you are properly recharging the battery.
1. Insert the small end of the adapter into the external extension connector (labeled "5.2V=IN") on the back of the Nintendo DS Lite, just next to the SLOT 1 Game Card opening.
2. Swing the prongs on the AC adapter until they lock into place, then insert it into a standard (120 volt) outlet.
The plug should be mounted vertically or on a floor outlet (such as a power strip).
3. Once the adapter is properly inserted, the unit will begin to charge (the orange charging light will display).
4. Once the DS Lite is fully charged, the orange charge light will go off.
Check the AC Adapter for damage (such as bent prongs or split wires). If you see damage to the AC Adapter, purchase a replacement from Nintendos Online Store.
Try plugging the AC Adapter into another wall outlet. Its possible the outlet is not working properly and has not been charging the Nintendo DS Lite.
If you are unable to get power to your Nintendo DS Lite, despite trying to properly recharge the unit, then your system will need to be repaired.
Nintendo offers convenient repairs, fast turnaround times and, for all systems repaired, a new one-year manufacturer's warranty.
Jul 14, 2008 | Nintendo DS Lite Console
DS LITE
Ok, then is either that both chargers you used are faulty, or more likely there is a contact in the power charger socket on your nintendo. check it it is moving or not well in place, eventually you will need to chaeck the contacts of charger socket on board inside the DS, the contact must be near there. Until you do not fix it, connecting the charger may be dangerous for your DS .
Apr 11, 2008 | Nintendo DS Lite Console
Nintendo Ds lite not working needs to be repaired
sounds like you both have a lose connection on the circuit board, so easily done, even if one cable is slightly misaligned the ds will not turn on, do they charge o.k?? if so it is a faulty connection
Apr 02, 2008 | Nintendo DS Lite Console
TOUCH SREEN NINTENDO DS LITE
aparently fitting a new touchscreen works, i have just ordered one from ebay, cost me a tenner
Dec 31, 2007 | Nintendo DS Lite Console
My nintendo ds lite top screen isn't working properly
Top LCD's flex cable that passes through right-hand hinge into bottom part of case will be damaged or not properly seated in its connector socket.
Nov 17, 2007 | Nintendo DS Lite Console
Nintendo DS Lite Console Logo
51 people viewed this question
Top Nintendo Video Game Consoles & Games Experts
Raj Patel
Julian Wainwright
Martin Murray
Are you a Nintendo Video Game Console and Game Expert? Answer questions, earn points and help others
