Question about Avanti DG24CSS Gas Kitchen Range
Electrical ignition constantly blinking - Avanti DG24CSS Gas Kitchen Range
  • 106 Answers
The ignitor module is probably wet, or has failed, or the switch on your burner control has failed. Ignitor is usaually on back of unit, toward the top. I would concentrate on the ignitor unit.
Posted on Jun 04, 2009
Put new ignition switch in starts for two sec then dies anti theft light will sometimes blink like it should or it blink ten times then stays on the wider color for it is black white and like a tan
Ignition switch ? The key lock cylinder or the electrical part ? Did you change key ? Program key ? What make , model and year vehicle ? Wires for what ?
Dec 23, 2016 | Cars & Trucks
Dodge nitro 2010 Idid wash externlly the engine, after flushing using a water hose the engine is not "running" ease it "jumps" and an engine warning light shows an engine constantly blinking could this...
No, the problems which appear after washing the engine are usually temporary. They dissapear when the washing agent or water dry off. You can help your engine regain its funcionality by drying spark plug contacts, and Ignition module contacts.
Nov 13, 2013 | 1995 Jeep Wrangler
Light just blinks on center unit of 5701v viper
if the light dosent turn off when you turn the key on it means it is not reading the ignition wire check them. without the ignition you cant program the remote
Jun 01, 2013 | 5701 VIPER 5701 2-WAY ALARM w/REMOTE START
Check engine lights came on, es 300 lexus,1999, constantly blinking, run rough at slow speed
A constantly blinking check engine light means you have a misfiring engine that is bad enough to cause your catalytic converter to go bad! Take it to the shop... probably means ignition parts and the upper manifold has to come off... and that's no fun! Good luck.
Nov 17, 2010 | 1999 Lexus ES 300
No electrical current to ignition coil for spark plug 8 & 3
If 3-8 coil is not getting 12v(remove coil connect a test light to terminls sticking up from the module turn engine over with starter test light should blink) if light doesn't blink replaCE THE IGNITION MODULE
Aug 28, 2010 | 1999 Cadillac DeVille
My GE Profile JPG636 cooktop has an ignitor problem. It clicks constantly, and all the ignitors on all 5 burners are 'going off'. It happens every 8 or 10 seconds whether we're cooking or not. If anyone...
The most common cause for this issue is from liquid getting into the ignition system for the range. If someone has spilled water or other liquids into the burner knobs or the ignition system it will cause an electrical short in the system causing the igniters to come on constantly when the knobs are off. The fix to this is to unplug the range and wait 24 hours for the liquids to dry up. You can speed up this process with a hair dryer pointed at the burner stems(knobs removed). Once the liquids have dried up the problem should stop. I would not leave it plugged in until then because the ignition system could be damaged from the constant sparking.
Feb 23, 2010 | GE Profile JGP636 Gas Cooktop
Avanti DG24CSS Gas Kitchen Range Logo
111 people viewed this question
Top Avanti Kitchen Ranges Experts
Craig Butler
Craig Butler
ray gallant
Are you an Avanti Kitchen Range Expert? Answer questions, earn points and help others
