Ford 8n,9n,2n,  Tractor Starter With Drive Logo
Posted on Dec 28, 2012
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
2n ford tractor stalls when i let the clutch out
Tractor starts with the clutch in when i let out the clutch the tractor quits
Dennis Key
Level 3:
  • Ford Master 2,481 Answers
  • Posted on Jan 26, 2013
Dennis Key
Ford Master
Level 3:
Answers
2481
Questions
Helped
749775
Points
6126
Your clutch needs adjusted a little more. Not releasing all the way.
5 Related Answers
Anonymous
  • 246 Answers
  • Posted on May 11, 2009
SOURCE: I have a 2n ford tractor. Starts great but will
Hello
Have you Checked the Point Set Gap?
If the Point Set Gap is Not Set Correctly or the Contacts are Burnt, then you will have this Problem.
Please, Do Not Hesitate, If you Hit a Snag or this Does Not Correct the Problem, I am Here if You Require More Assistance.
Hope this Helps. Let me Know What Happens, Please. May the All Mighty Bless You and Yours. Be Safe and Be Happy. Thanks.
Good Luck
Respectfully
jbridger (John)
Anonymous
  • Posted on Aug 28, 2009
SOURCE: Ford 2n tractor. Engine turns, but very slowly. Is
you can get a replacement for that starter at most auto parts stores. there is nothing on the N series tractors you can't buy on line, even complete engine rebuild kits and fenders. look for antique tractor parts suppliers. is it a 6 volt or converted to 12 volt?
Anonymous
  • 2841 Answers
  • Posted on Sep 12, 2009
SOURCE: Firing order for 1963 FORD 2N 163 TRACTOR
As there can realistically be only 2 firing orders for a 4 cylinder engine then it will be one of these two. 1-2-4-3 1-3-4-2 I am 95% sure that on your Ford it will be 1-2-4-3. So give that a try and if it is incorrect then you know it it 1-3-4-2.
agent91
Ned White
  • 2100 Answers
  • Posted on May 08, 2010
SOURCE: Cant read the serial # on 2N ford tractor. How do I find out the
They were only made from 42 to 47, I know you can make the serial number visible using ferric chloride? It is a heavy acid, etches copper fast, and will bring out a stamp in metal. The PD uses it all the time on guns and such. If you know where the serial is, you can read it. I don't know if you can buy less than a pound of the stuff, maybe. If not , let me know, I have a lab here, all kinds of stuff. Hope this helps.
kel1guy2002
Kelly
  • 3740 Answers
  • Posted on Apr 08, 2011
SOURCE: 2N FORD Tractor Fuel will not flow from tank to
You have a clogged fuel manifold in the carb. This is usually caused by something in the float needle seating area. Remove the float bowl, remove the float and pull out the float needle. Then use carb cleaner in the float needle area to blow out the debris or dried / varish in the float needle seat and the fuel maifold. Spray carb cleaner from the manifold / hose fuel connection and make sure that you get it clean. Then with the float and float needle still removed turn on the gas and make sure you have fuel flow.
Here is a carb kit if you need parts:
http://www.8ntractors.com/carburetor_repair_kit_c545v_1035_prd1.htm (Do a net search for the kit you can get them cheaper than this one.)
I get the feeling that this tractor sat ilde for sometime and your now trying to get it going again. When a fuel system sits for a very long time with fuel the fuel in the float bowl and carb will turn into a shellac and really gum things up. Worst case you remove the carb and soak it in Chemtool B-12 overnight / couple of days then rebuild it using the kit above. (You will be glad that you did!)
You can get a new fuel cap here:
http://www.8ntractors.com/ford_2n_tractor_fuel_tank__cap_343_ctg.htm
Also there is a SCREEN in the top of the fuel sediment bowl that can be caked with gunk. This will stop all fuel flow if it is blocked.
http://www.ytmag.com/store/parts/pics/wm_2NAA916061_.jpg
I have spent hundreds of hours on one of these... doing large garden work back in the day and moving hay in several different ways. (Brings back some good memories and makes me ponder where that tractor is today...hmmm..)
Thanks for choosing FixYa,
Kelly
Testimonial: "Fuel flow problem resolved after the carb was cleaned and rebuild thanks for the quick responce."
2answers
Don't know how to read the hydraulic dipstick for a 1944 ford 2n tractor
Ford Tractor Hydraulic System - My Ford Tractors
www.myfordtractors.com/hydraulics.shtml
All N-Series Tractors - Ford-Ferguson 9N, 2N, and Ford 8N ... 6 - How long has it been since you changed the hydraulic fluid? ... If that didn't do it, read on. ... then remove the bottom bolt from the inspection plate that has the hydraulic dip-stick.
Yesterday's Tractors - Fifty Tips for Ford 9N, 2N and 8N ...
www.yesterdaystractors.com/articles/artint268.htm
I'd like to say that the reason I have an 8N Ford tractor is because that's the tractor ... The N tractors have a common sump for the rear end, hydraulic pump andtransmission. ... (Read the label.) .... Take the inspection plate with the dipstick off.
Ford 8N, 9N, 2N, NAA Tractors Information - SSB Tractor ...
www.ssbtractor.com/wwwboard/messages15/
Helpful information and resources on Ford 8N, 9N, 2N, NAA tractors from SSB Tractor, a leading provider of tractor parts, manuals, implements ... 1944 ford 2n: What type of oil to use? and whats the oil pressure should be? ...... N Series Trans/Hydro Fluid - Interesting To Read ... Ford NAA/Jubilee Hydraulic dipstick location?
My 2n will not start
I would check the points for open and closing.
1helpful
Diagrams_For ford 2N tractor starter
If you have not already found the info, I would suggest visiting the following website for some detailed help:
mytractorforum.com
No cost but will have to join to post questions. Likely all info can be had simply by searching the Ford "N" section. Good Luck!!
I have an 8N Tractor and the gear broke off of the starter shaft. How do I retrieve the broken pieces out of the tractor?
There should be a clutch inspection plate on the bottom of the bellhousing, take that off and you should be able to fish them out.
lp
2answers
Ford 4000 TraCTOR WILL NOT START AFTER QUITING DURING BRUSH HOGIN
Try jumping across the 2 large posts on the solenoid, if it cranks doing this, replace the solenoid
1helpful
Cuts out and then quits. In about 10-15 min. will start again.
I think that cooling off is doing it,I think your gas is filling you carb bowl,remove you carb and take bowl off ,I would buy a kit,I have had problem with the floats sticking or have been damaged by water freezeing,that carb is easy to rebuid you will do good and you will have the pride of fixing it ,good luck and thanks
4helpful
2answers
Hello
Good Luck
Respectfully
jbridger (John)
Top Ford Garden Experts
vince
Paul Carew
Are you a Ford Garden Expert? Answer questions, earn points and help others
