Question about Protron PLTV3250 32 in. LCD Television
Tv freezes turn on tv,light gos green,then red,then green won't let you change channels,volume won't work.have to turn tv off and on several times,then it seems to work well.....help!
I've had my tv hang a few times. I just unplug it and plug it back in and I'm good to go.
Posted on Jan 20, 2009
RCA LCD TV gets stuck on one channel
sounds like you have an intermittent defective main board. ebay rca model for replacement board.
Jan 11, 2015 | RCA Televison & Video
Why does my Logic tv keep freezing? The remote stops working, I can't turn over channels or use the volume control and sometimes get a green band across 1/2 the screen. Please Help!
Fault with main board. Damaged component/s at it. Contact any service technician; or the authorized service center. If you wish to get some details; check the site linked here. Surf the site with patience. Pull up older posts. http://electronicshelponline.blogspot.com/ . In most cases, the main board might have to be replaced.
Sep 07, 2014 | Televison & Video
Sharp Aquos LC-60E79U has flashing green power light and OPC light but won't turn on
Try to I unpluged the power, push volume and channel down, pluged power again
While it's flashing unplug your TV from the main power source for 15 seconds,Then press Valume Up and Channel Up, while holding it plug the TV back in, you should see the TV Turn on. How to Reset Your Sharp LCD TV TV Repair
Jun 15, 2013 | Televison & Video
I have sony lcd hd ready 50inch rear projector tv model number KDF-E50A12U tv comes on after couple minuets tv clicks off to stand by then red light in stand by flashs 3 times gos back to green repets
Hello
Three blinks of standby light to Sony TVs indicates that the regulated voltage output from power regulator board is above thatn normal. The problem is with its power supply regulator board. Replace all the electrolytic cpacitors on that board with new ones. Replace all of them including small and large ones, at one time. OK.
Feb 04, 2012 | Televison & Video
How do you install a sabrent vga converter?
TV-LCDHR does NOT require a computer. It only needs a working VGA monitor and a Cable TV service.
1. Connect your coaxial TV cable directly to the "Antenna" port on the back of TV-LCDHR. Plug in the power supply. You should now see a red light on TV-LCDHR.
2. Connect your VGA monitor to "VGA-Out" port on the back of TV-LCDHR.
3. Press the "Power" button on the remote to turn it on. The red light on TV-LCDHR should now turn green.
4. Turn on your VGA monitor.
5. Press "Menu" button on the remote. Go to "Search", select "Auto Scan", and choose "Normal Scan".
TV-LCDHR will now scan through all channel frequencies it may find on your Cable TV service. When it's done, use the remote to change channels and adjust volume.
Note: TV-LCDHR has a built-in mono speaker. For optimum sound quality, we recommend using a pair of amplified stereo speakers. Connect them to the "Audio-Out" port on the side of TV-LCDHR.
Aug 17, 2011 | Sabrent TV-PC85 PC to TV Converter Box
The volume of sony wega kv-sw29m61 set always to maximum when it turned on
On your remote control (with tv off)
1. press Display, channel 5, Volume Up and then Power
this brings up the service mode (you will see some green text on your screen)
2. Press channel 2 to scroll through options until you see "Micro" in the upper left of your screen
(channel 2 cycles up through the options, channel 5 cycles down)
3. Press channel 1 to scroll through suboptions until you see "DIOF" appear under "Micro"
(channel 1 cycles up through the suboptions, channel 4 cycles down)
4. Press channel six until the default value (12:60) changes to 12:40
(channel 3 increases the value, channel 6 decreases the value)
5. Once the value has been changed to 12:40, press Muting and you should see red text in the upper right hand corner that says "Write"
6. Simply turn the power off and back on for the change to take effect. Your volume problems should now be fixed.
Jan 16, 2010 | Televison & Video
Won't even feed into tv anymore....
If you are using the RF input are you sure the channel on the TV did not change? Make sure the TV is set on Channel 3 (or 4) or use the component (red-white-yellow) outputs if your TV has component inputs available.
Jul 01, 2009 | Apex Digital HT-150 System
Sony FD Trinitron WEGA TV Model Number KD27FS170 volume problem
my sony trinitron is blinking six blinks and I cannot turn it on, please help
Nov 22, 2008 | Sony FD Trinitron WEGA KV-36XBR800 36" TV
Buttons/ Remote won't operate TV
Defective tactil switch?? Remove tact switch control board.
unplug connector,use meter--check each switch.
If no problem found,leave unplugged overnight or longer.
Sony is famous for getting brain freeze!.........T.
Oct 24, 2007 | Sony FD Trinitron WEGA KV-27FS100 27" TV
Protron PLTV3250 32 in. LCD Television Logo
73 people viewed this question
Top Protron Televison & Video Experts
Jaime Hernandez
Are you a Protron Televison and Video Expert? Answer questions, earn points and help others
