Question about Berkel 827E Gravity Feed Deli Meat Slicer
Replaced blower motor in my Intertherm furnace, now blows cold
I have a mobile home that is equiped with an intertherm furnace. I replaced the blower motor with a compatible motor from cc dickson in Gaffney, SC because the original was locked up. Now it blows MUCH harder but it won't warm up. I can restrict the air flow and get it somewhat warmer but the furnace runs non stop. Can anyone help me please as I have 2 small kids that"s having to deal with this also. Thanks so much for the help. Brad
  • 82 Answers
Most blowers have a high( black wire) and low(red wire) low works much better in the heat mode
Posted on Jan 19, 2009
I have an intertherm furnace model number 901282 and it will not heat my house when i turn on the thermostat it starts but just blows out cold air pleases help
The blower should come on after ignition occurs. When the blower comes on first ignition will not be activated as the thermostat signal shows the heat is on. This happens when the blower relay is stuck in the on condition
Nov 21, 2014 | Intertherm Heating & Cooling
INTERTHERM NO HEAT OR BLOWER
This could be failure of the igniter and/or thermocouple.
Jan 27, 2014 | Intertherm 56000 Btu Gas Furnace
Intertherm feh 015ha
either the heat strips, fusible links on elements or sequencers.
Sep 21, 2013 | Intertherm E3EB010H Electric Furnac
Intertherm furnace burner comes on, but blower does not. If I turn thermostat off then back on until it clicks the fan will then come on. It does not do this all of the time, just now and then.
Furnace burner and heat element are not the same. I think the fan time delay, a sensor that turns the fan on when this sensor senses heat, is shot and needs replacing, for a furnace type heat ( gas heat)
Aug 08, 2017 | Intertherm E3EB010H Electric Furnac
No problems, would like to find out the best way to remove blower for cleaning on an intertherm gas furnace mgh 075 ina mobile home
Generally ther is two screws at the base of the blower housing which hold it in place, remove the screws and pull, slide the entire assembly out. You will have to disconnect the electrical wiring to the blower and possibly the limit switch on the side if equip.
Aug 23, 2011 | Dayton Gas Furnace Heater
When I turn on my furance or ac the blower is always on even though the fan is set to auto. When it is on heat it never gives off any hot air, so it never warms up the house. I had someone look at it and...
If this is a mobile home furnace they usually have a two stage gas valve. Generally they just have a delay in opening fully and are convertable from L.P to natural gas or vice versa. It is a possibilty that the gas valve is bad. If so it will have to be replaced. First I would have someone check your thermostat to see if that is what is causeing the blower to run . does the burner ever light? I wouldsuggest that you hire a service tech. who is knowledgable on intertherm furnaces. I don't recommend anyone who is not trained to change gas valves,because of safty concerns. I hope this helps you some. Thanks
Nov 12, 2010 | Intertherm Heating & Cooling
Intertherm furnace not getting hot after motor swap. PLEASE HELP
You already diagnosed it yourself. The motor may have been the same physical size but it operates at a higher speed and doesn't remove enough heat from the furnace. You need to have the right motor installed period.
Jan 17, 2009 | Intertherm P3RA-048K Air Conditioner
WIRING
why did the wiring burn?Id have the heat exchanger inspected before rewiring.better to be safe.
Sep 17, 2008 | Intertherm P3RA-048K Air Conditioner
Intertherm furnace problem?'s
the blower on my furnace keeps going on and off when i turn the furnace on .ichanged the snapdiscs no change changed thermocoupler and therostat still no change whats my problem
Oct 27, 2007 | Intertherm P3RA-048K Air Conditioner
Berkel 827E Gravity Feed Deli Meat Slicer Logo
486 people viewed this question
Top Berkel Kitchen Appliances - Others Experts
john raffaele
Level 1 Expert
ray gallant
Lawrence Oravetz
Are you a Berkel Kitchen Appliances - Other Expert? Answer questions, earn points and help others
