Question about Philips Magnavox 51MP392H Rear Projection Television
My philips magnivox rear projection TV has a cloudy picture..is it worth fixing
    Sergeant:
  • 171 Answers
It sounds like your light bulb is starting to burn out, this bulbs usually last 2-3 years and they are around $100dls here is a link to a online store I hope this helps
www.discount-merchant.com
please rate this solution !!!!!!!!
Posted on Aug 10, 2010
  • 60 Answers
Yes, I used to work in Best Buy and one of the key things about rear projection TVs and the reason they push those service plans on you is that the tubes/colors need to be calibrated each year. You can do this yourself by checking out the following website:
http://lgknowledgebase.com/kb/index.php?View=entry&EntryID=3229
If you are not able to adjust the convergence using the remote you will need to replace the convergence chips.
Typical Symptoms
1) Convergence menu does not work for one or more colors.
Such as: Red moves up,down, but left or right fails.
2) Screen is bowed looking.
If you have one or more of the problems above you need to replace the convergence chips. You can get a kit and instructions from www.TvRepairKits.com
Hope this helps :)
Posted on Sep 17, 2009
4 Suggested Answers
Ecollier2012
  • 3459 Answers
SOURCE: I have a 2002 philips 64" rear projection tv
Easy DIY Fix...See below.
Your TV most likely has one or more possible problems.
Problem #1: Convergence Chip Failure ( common problem )
Here are some of the most common symptoms and example photos of a convergence problem
  • Screen looks 3D
  • Colors don't line up
  • One or more colors can't be adjusted when using the convergence menu.
  • Screen is bowed or warped.
Here is a quick test....
Using your original remote go-to the tv settings then goto the convergence section.
Try to adjust the red and then the blue convergence.
You should be able to move them up, down, left, and right.
If you can't move them in all directions your convergence chips are bad and should be replaced. This is a common problem.
2c07611.pngSolution #1
You need to replace the convergence chips and convergence resistors. Check the site www.TvRepairKits.com. They have put together a kits for most models. If you don't see a kit for your set send them a quick note and they will put one together for you. Their kits include a photo instruction guide, original OEM Sanyo STK chips, convergence resistors, pico fuses, etc.
Problem #2 CRT Fluid is Cloudy
Projection TV tubes have a liquid coolant that is used to keep them from overheating. After many years the coolant in the blue and green tubes will become cloudy and cause the screen to look dull, red/orange, etc. You may even see halos around images.
Picture of a set that needs the fluid changed.
TV set after fluid change
2c07611.pngSolution #2
What you will need to do is replace the coolant and clean the crt. You can get a repair kit from www.TvRepairKits.com that includes replacement coolant, photos. instructions, etc.
Posted on Apr 08, 2009
  • 1738 Answers
SOURCE: cloudy picture on rear projection tv
Your picture guns and mirror is dusty. You can try cleaning yourself if you know what your doing, but I would let a qualify tech to do it.
Posted on Nov 20, 2009
  • 11 Answers
SOURCE: Cloudy picture on Philips Rear Projection TV
There is clear fluid in the 3 color tubes to keep them cool. The fluid is simular to antifreeze. Try an ebay search for "TV COOLANT". You have to make sure not to spil ANY on your board or you will be very upset. This is oil based and will ruin the board "CAN NOT BE REMOVED". What clouds these TVS up is bacteria growth. Normally it can not survive under the red lamps. Blue is the main one to cause this. To check for growth, you have to look in the lens when it is on. You will see small spots. Once open you have to wipe and clean the spots off before adding new fluid. Fluid is very cheap. A shop will charge a couple hundred to change each tube. Use 100% silicone around both sides of gasket before resealing. Also lay a plastic garbage bag under the lamp for a few days with a towel on top of that. IF you have a leak, this will keep it off your boards. A trick to doing this easily is lean the Tv foward so the lamps are level and use a turkey baster to **** ALL the old fluid out. You can also use any type of suction tubes.
Posted on Dec 12, 2009
Dark picture and can't adjust from remote
This is a very common failure on these projection sets and a fairly simple DIY fix. All projection sets including Samsung, RCA, Sony, Philip Magnavox, Panasonic, Pioneer, Akai, GE, JVC, Toshiba, and others at some point will have the same problem.
Common Symptoms include....
  • Screen looks 3D
  • TV shuts off after powering on. Power light will blink. TV may also make a chirping noise.
Here are some pics of convergence problems.
69189a5.pngSOLUTION #1
For more more examples and find a fix using this link on Fixya http://www.fixya.com/support/r2861467-solution_video_looking_whiteish_dull
Common Problem #2) CRT Fluid is Cloudy
69189a5.pngSOLUTION
You can see some more examples and find a fix using this link on Fixya http://www.fixya.com/support/r2861467-solution_video_looking_whiteish_dull
Apr 18, 2011 | Philips 50P8341 50" Rear Projection...
I have a Philips Magnavox 9P6034C 60 in. Rear Projection Television the whit bulb is gone out where do i get another one
  • Screen looks 3D
69189a5.pngSOLUTION
Mar 27, 2011 | Philips Magnavox 9P6034C 60" Rear...
My TV has gradualy developed a blurred picture over the last month and now is unwatchable, is it worth fixing. It is 8 years old
guessing this is a rear projection tv. You did not provide a model number. Check the CRT fluid to be sure it is clear and not cloudy. Since you mentioned the problem was gradual over time, I'm guessing it is the fluid. This would be more obvious if you were seeing like a frosted look to the picture or dark areas and bright areas, which are caused as the fluid clouds up.
Your alternative is to try adjusting the focus of each bulb on the focus block of the tv. I think with an older Philips the focus block is in the back of the tv.
Feb 20, 2011 | Philips Televison & Video
Cloudy picture on rear projection tv
Nov 20, 2009 | Philips Televison & Video
DOUBLE PICTURE WITH DIFFERENT COLOR
this is a convergence problem,
well worth fixing
I would have a TV repairman take a look at it.
Regards,
daniel.
Jan 12, 2009 | Philips Magnavox 51MP392H Rear Projection...
Philips 50P8341 50 in. Rear... Problem:
You CRT coolant needs to be replaced, its a very common problem with the phillips and magnavox projection TVs. If you need more info on the Coolant Change let me know.
Jul 14, 2008 | Philips 55P8341 55" Rear Projection...
you need to change the coolant in the CRTs ( picture Tubes) and the set will get its color and clarity back.
Jul 07, 2008 | Philips 50P8341 50" Rear Projection...
Philips 55 inch hdtv rear projector
May 21, 2008 | Philips 60PP9363 60" Rear Projection...
Cloudy Picture
can you psot a pic of what the picture looks like. I should be able to diagnose it if I can see the image and what its doing.
Apr 04, 2008 | Philips 9P5034C 50" Rear Projection...
I have a philips 60p8341 tv
Hi, the fluid in the tube has to be replaced, big & dirty job, set has to go to the shop to do this, be advised that this happens to all Philips rear projection tv`s eventually, problem is (besides being expensive to do) if the green fluid is getting cloudy the blue tube is not far behind. This can be confirmed by removing back bottom cover and looking directly into the lenses, you`ll see they are cloudy compared to the red one that almost never becomes cloudy, sorry to be the bearer of bad news, if you have more questions ask away, BMW Rider
Dec 10, 2007 | Philips 60P8341 60" Rear Projection...
Philips Magnavox 51MP392H Rear Projection Television Logo
88 people viewed this question
Top Philips Televison & Video Experts
matt martin
matt martin
Are you a Philips Televison and Video Expert? Answer questions, earn points and help others
