Question about Microsoft Xbox 360 Console
Ip address keeps failing
When i try to connect to xbox live from ny pc the network adapter passes but my ip address keeps failing
    Guru:
  • 829 Answers
Hi , Do you have static IP in place , i mean in network neighborhood type your IP and make it as the permanent, then log in , you will be able to access.If you dont know how then surf the net to manually type static IP.
Posted on Jan 17, 2009
Xbox live IP address and gateway dont seem to work
Make sure you are using the xbox networking adapter. Some networking adapters may work on it but if you encountered any problems, xbox tech support won't be able to assist you with some troubleshooting since they don't support any product other than the xbox networking adapter.
  • To test the connection, go to the system area on your xbox live dashboard then go to network settings and select test xbox live connection.
  • If you pass on all test down to NAT then it means you are connected already and you can now enjoy playing online.
  • If you fail on the first part of the test which is Network Adapter or if it says not connected on Wireless Network then you need to perform some steps.
  • Get back to the network setting's area by pressing B on your controller and select restore to factory defaults. Doing this will restore the xbox live settings to default and you need run another test again which may allow you now to pass.
  • If you still fail on wireless network then it means that you need to set your console to wireless mode by going back to Network Settings and selecting the Edit Settings option.
Jul 15, 2014 | Microsoft Xbox Video Game Consoles & Games
Failed Ip adress for xbox live
First i want to know how is your xbox 360 connected to the internet? For example ( Modem Connection?, Router Connection?, Or Wireless Connection?
Here are some steps that you need to try:
1. Turn off your cosole wait for 20 seconds and then turn it back on, then test your xbox live connection
2. Go to your network settings
3. Select restore to factory defaults and test your xbox live connection
Apr 03, 2009 | Microsoft Xbox 360 Console
My adapter is Wired but my IP address Fails :(
I am not sure how to fix it through multi-wired interned but the best way to get connected to the Xbox Live is to give it a direct access to the internet.
Try to look into your manual you got with your Xbox and find how to connect it through other means than direct access.
In the meantime, before you find a way - your best bet is to just take your internet cable that is connected directly to the modem and connect it to the Xbox.
Dec 31, 2008 | Microsoft Xbox 360 Console
Xbox live
update your firmware of the router.
the only viable solution.
Dec 19, 2008 | Microsoft Xbox 360 Console
Can't connect to Xbox Live
mtu is not working cant hook up xbox live
Nov 25, 2008 | Microsoft Xbox 360 Console
Ip address failed
I think you need to ring your internet provider and they will enable xbox live from their side. Its fairly simple and they will know what your talking about.
Oct 20, 2008 | Microsoft Xbox 360 Console
Network adaptor
try doing automatic ip instead of a static ip
Jun 21, 2008 | Microsoft Wireless Network Adapter Xbox...
Xbox live
ok, this is what i have to do whith normal computers.
(the xbox is the same)
(make sure youve got a crossover cable (red one))
1.turn on ur xbox
2.goto the system tab
3.goto Network settings
4.edit settings
5.ip settings
6.change it to manual
7.ip address
8.type in 192.168.1.2
9.Subnet mask
10. type in 255.0.0.0
11.default gateway
12.Type in 192.168.1.1
On your computer
(vista)
1.start
2.control pannel
3.Network and Sharing Center
4.manage network connections (on side Bar)
5. right click on Local Area Connection
6. go propertys
7. doble click on tcp/ip v4
8. click use the following ip addess
9. ip address
10. 192.168.1.1
11. subnet
12. 255.0.0.0
13. default gateway
14. 192.168.1.2
15. click ok
16. click ok
17. right click wireless network
18. goto propertys
19. got the sharing tab
20. tick the only box you can
21. press ok
22. your done!
phew that was a long one.
hope this helps.
Maxicube.
Feb 09, 2008 | Microsoft Xbox 360 Console
IP address Problem when connecting to xbox 360 live
i had the same problem buddy. The problem might be that you hacve another system on the wireless network that uses that same IP address. This can cause a conflict that will prevent the xbox from logging on. Try deactivating other systems on the network to see if thats the problem
Sep 26, 2007 | Microsoft Xbox 360 Console
Microsoft Xbox 360 Console Logo
79 people viewed this question
Top Microsoft Video Game Consoles & Games Experts
Tre Elkins
Martin Murray
Stu Morris K
Are you a Microsoft Video Game Console and Game Expert? Answer questions, earn points and help others
