Officejet 4500. Changed print cartridges. Tried to aline, but alinement page does not print correctly. Prints blue squares, but the only red is an arrow and there is no black. What now?
  • 21 more comments
  • gopherwjs Jan 17, 2009
    cartridges are hp brand. removed and cleaned cartridges, but still cannot print alignment page correctly. in effect, no change.
    did it. no change.
    still does not print alignment page correctly.
    blue boxes print, no black, red arrows only.
    printer is less than one month old and cartridges are new hp.
    tried # and 9 simultaneously. no change. still cannot get alignment page to print correctly.
    still no change.
    as stated earlier, the printer and the cartridge are new. the vcartridge was still in the package. guess I just got a lemon printer. WHAT A MESS.
    protective strip was removed. if this is an hp problem, guess i just got screwed.
    cleaning produces 6 boxes of various colors, but no black. i could not find a setting for deep cleaning, just cartridge cleaning.
    how long is a while? held OK and cancel 5 minutes and the printer never turned off.
    what now?
    yes. see earlier messages.
    tried all of this already see earlier messages. this is silly for a printer less than a month old.
    still uninstalling software. i just have a 5 year old lap top and it doesn't set speed records. the new cartridges were in sealed hp packages.
    black cartridge did not bleed, but color did. must be a bad cartridge. can't do anything today. will have to get another set of cartridges on monday and try again.
  • gopherwjs Jan 22, 2009
    OPPered, received and installed fresh ink cartridges from HP. Printer now operates correctly as a copier, but cannot connect to the computer. Uninstalled and installed software disk, and followed instructions as best I understand them. Software runs to the point where it says to connect the printer to the computer. When the USB cable was connected, nothing happened. Followed help
    instructions, but no help. Could be a bad cable, but itr is the same cable that worked before this mess started.
    What now?
    Ordered, received and installed fresh ink cartridges from HP. Printer now operates correctly as a copier, but cannot connect to the computer.
    Uninstalled software and attempted to reinstall from the original disk. Works up to the point where it says to connect cable. Did so but nothing happened. same cable as before.
    Installed fresh cartridges received directly from HP. Uninstalled software, and attempted to reinstall. Works up to the point where it says to reconnect USB cable. Did so, but nothing happened. Same cable which worked before the problem happened.
    What now?
    still cannot connect printer to computer. please see prior comments.
    this has nothing to do with my problem. printer works as a copier. problem is connecting printer to computer
    once again, problem is connecting computer to printer. computer works as a computer and printer works as a copier. the interface is the problem.
  • gopherwjs Jan 23, 2009
    this is nonsense. the printer/computer combination worked fine before i changed ink cartridges. apparently fix-ya people do not read past comments and solutions. ripoff, for sure
    did this long ago. see prior solutions/comments. is anybody reading priors?
    test print works on copy. problem is the interface between the printer and computer.
    this is a rip off!!!!
    "Expert" solutions are not responsive to the problem. Experts do not read prior solutions and comments.
    Fix-ya is a waste of time and money.
  • 19,396 Answers
Well, sorry about that, did you try cleaning the metal contact (the plate that makes contact with cartridge) inside the ink carriage using isopropyl alcohol and cotton.
That is one of the first thing to do when you get this kind of problem.
Posted on Jan 23, 2009
  • 8,197 Answers
Ok read your hole post. You say you can not get past hooking up the cadle from the printer from the CD. I would try to dounload the software from HP and See if that will get the printer runing again. Here is a link for the site right at the download part.
http://h20180.www2.hp.com/apps/Lookup?h_lang=en&h_cc=us&cc=us&h_page=hpcom&lang=en&h_client=S-A-R163-1&h_pagetype=s-002&h_query=officejet+4500&submit=Go+%BB
If that does not work I would call HP at.
http://welcome.hp.com/country/us/en/contact/phone_assist.html#section1
Good Luck and hope it works out for you.
  • 685 Answers
Try to unplug it this will most of the time reset the printer.then plug it back in and try your test print again
Posted on Jan 22, 2009
  • 4,472 Answers
Definitely is defective printer. Being that it is under a month I would return it to the store you purchased it from. If that is not an option you will have to have it serviced by hp under warranty.
http://h20465.www2.hp.com/GPL/search.aspx?language_code=en&country_code=us&SearchType=SSP
You can follow this link to locate the nearest authorized service center and contact them about warranty service. If you need further assistance please let me know, also please take a moment to accept and rate my solution accordingly.
Thank you,
Lee
    President:
  • 1,214 Answers
If you go tthrough the complete printer install, following directions, and the printer still will not print a test page, go to Start|Settings|Printers, and check that the 4500 is listed there. If it is, check that there is a check mark next to it. If not, right click the icon, and slect properties, select Make Default Printer.
Right click again , and select properties, then select "Print Test Page". Once you know this is setup correctly, then go to the HP software and test. I might caution, sometimes when having these kinds of problems, it's a good idea to reboot.
  • Mark Egan Jan 22, 2009
    Does your router see the printer (is the printer visible on the network)? Log into your router and check.
    I think you've said, but be sure you've loaded all the drivers on the computer you are trying to print the test page from.
    The manual is extensive in setting this unit up on the network, so take a look for info there. Let me now what you find on the above, and I'll also try to give you more direction.
    Find the manual at
    http://bizsupport2.austin.hp.com/bc/docs...
  • 11,896 Answers
Being that i dont know whatoperating system you use, if it iswindows, go to the control panel, then printers and fax icon, rightclick your printer then select properties. this is where it will be upto you to look around for things like printing test page, which willallow you to adjust the allignment, and maintaince, this is differentfor different operating systems and printers, so hope i atleast gave you some help.
Other suggestions:
  1. Load plain paper.
  2. Press the Menu button, and scroll to Align Cartridges.
  3. Press Select. An alignment page prints. Once this page prints, your automatic alignment is complete.
  • Load plain paper.
  • Open the Officejet 4500 Series Utility.
  • From the Cartridges tab, click Align Cartridges... . The Cartridge Alignment dialog appears.
  • Click Continue to print the alignment page.
  • On the Alignment Status dialog, click OK if automatic alignment is successful. If automatic alignment is not successful, clicking OK will return you to Utility Main Window.
  • Here is a link for you to copy and paste in your browser if you need more info.
    http://h10025.www1.hp.com/ewfrf/wc/document?docname=bpu00657&cc=us&lc=en&dlc=en&product=59273
    Posted on Jan 17, 2009
    • Nate Stansfield
      Nate Stansfield Jan 23, 2009
      sorry to hear your troubles. I've just read everything and believe I can help.
      To install a usb printer, usually you have to install the
      software/driver first, then rebbot, and then connect the printer to
      your pc and power it on, windows should recognize the added printer and
      loads its driver automatically.
      to check your status go to CONTROL PANEL, HARDWARE AND SOUND, and find PRNTER. Make sure your printer is set as default. You can check all printer settings and connections from here. You may also right-click on printer and go to properties to view full info
      Sergeant:
      Scholar:
    • 199 Answers
    This is a problem of white colour cable which moves with the carriage of the cartridge where u install the cartridge.there r two cables 1 for colour and 1 for black,the 1 which is for black is having cut in between or got loose from the main board so it needs to be made proper otherwise it will not work.if its cut in between then rep[lace the cable.u can get the cable from local hardware shop at the rate of $2 or $3
    • 106 Answers
    Try unpluging it. take the cartidge out .. clean it of and put it back in and plug in back in...
    see what that does good luck ray
      Genius:
    • 2,120 Answers
    When all else fails, replace BOTH CARTRIDGES WITH GENUINE HP cartridges.
    If the printer is only 1 month old, why don't you take it back to the store for a replacement printer?
    • Leroy Elliott
      Leroy Elliott Jan 22, 2009
      Go to www.hp.com and let the website auto-detect your printer and download the drivers automatically. Be sure to delete the printer in control panel and remove the software before going to the website.
      Genius:
    • 1,665 Answers
    Hi! I think you have to uninstall and try from begining all the installation procedure to make it aligned..
    • Kleanthis Mavropoulos
      Kleanthis Mavropoulos Jan 22, 2009
      So you have to inspect cable sockets, cable to be well fitted, and finally if no result try a new cable.
      Sergeant:
      Champion:
    • 334 Answers
    Sit the black cartridge in real hot water, Not to deep just enough to cover the tip probably about 1/2 in will do. Watch and see if the black begins to bleed out. Let it soak for a while then wipe off and try again. You can do the color cartridge the same way it doesn't hurt the cartridge
    • Greg Wilkins
      Greg Wilkins Jan 23, 2009
      I had the same problem. After i had installed the printer software once and uninstalled it it would not download software again. I have changed printers since then but i think when this happens something is left on the computer for it to think that the software is already installed. If you use a program like ashampoo win optimizer you can modify registry entries easily. You can delete any entries to that printer that are left there after uninstall. When it happen to me it was like it was overlooking the printer software. Hope this helps God Bless
      Genius:
    • 2,920 Answers
    Did you remove the plastic from the ink cartridges? sometimes people over look those
      Guru:
    • 731 Answers
    Hi
    As im a HP staff i will recommend you to hard reset the printer, follow my step to hard reset the OJ 4500 printer
    POWER DRAIN:-Turn off the printer, Unplug the power cable from printer and from the wall outlet.Press and hold ON buton for 30-60 seconds.
    PARTIAL RESET:-Unplug the printer power cable while its ON, press and hold # and 3 button and connect the Power cord while holding.Wait untill the ON light flashes, then release the buttons.
    ----(for below reset cartridges must be removed out)---------
    SEMI_FULL RESET:-Remove the ink cartridges, Unplug the printer power cable while its ON, press and hold # and 6 button and connect the Power cord while holding.Wait untill the ON light flashes,or wait for 20 seconds,hen release the button.If the printer goes off dont worry release the button and Push the ON button.
    FULL NVM RESET:-Take the Ink Cartridges out, Unplug the printer power cable while its ON, press and hold OK and CANCEL button and connect the Power cord while holding the buttons.keep Holding the buttons until the printer goes off ,release the button and Push the ON button.
    (Notes - resets will take a while)
    Thanks
    Riz
    • 837 Answers
    Have you tried the printers cleaning utility yet .. be sure to do the "deep" cleaning
      President:
    • 1,990 Answers
    Welcome to Fixya! Unplugg all of the Cables from the Printer. Uninstall and Reinstall your Software. Plug cables Back in. Restet your Computer. Run the Software for the Computer and Run an Alignment Test.
    • 2 more comments
    • Travis Humphries
      Travis Humphries Jan 17, 2009
      Have you tried my Solution Yet????
    • Travis Humphries
      If you try My Solution it works 99% of the Time on HP Printers!
    • Travis Humphries
      If the Plastic Strip was gone from the Cartridge, You have a Bad Cartridge. It is REALLY Common for Customers to take the Old one in the Store with them and Remove a New one from the Box then Insert their old one and Walk out!
    • Travis Humphries
      Travis Humphries Jan 22, 2009
      Sound Like at this Point you might want to get a New Printer.
    • 64 Answers
    Make sure the contacts on the bottom of the cartridge and inside the printer are clean, and free from any possible debris.
    I've had my share of defective HP cartridges. It's not that crazy to think you might have a couple that are bad.
    This question isn't assumng you would do this, but it's a basic question just in case. You removed all of the protective strip from the cartridges, right? It happens.
      Sergeant:
    • 378 Answers
    Its quite possible that the black cartridge is gone empty or dry needs replacement.just replace and check out properly it will work.
      Sergeant:
    • 221 Answers
    The blue squares and red in arrow is proper it prints that way only.but as u said no black this is the problem.just remove the black cartridge and give it a brisk in your hand **** it 3-4 times and check whether the ink is coming from the nozzle of the cartridge.it can also be possible that the cartridge not installed properly or the new cartridge is totally dried up can be company fault.or the internall problem in the circuit of the black cartridge that needs to be checked and repaired.
      President:
    • 2,110 Answers
    Use the keys # and 9 simualtenusly. to reset..
    • 1,879 Answers
    Your problem is with the cartridges not the alignment.
    remove cartridges, clean the contacts on both carts and printer.
    re-install carts
    same issue with a specific color ? replace it.
    • 916 Answers
    Take some of the paper out of the paper tray then pull out the cartridge wipe off the contact points and reinstall the cartridge. And try to realign the printer again once done.
    • machadojr_fe Jan 17, 2009
      Look into the paper output tray of the unit as the alignment page is
      printing; a blue light should be visible periodically. If this light is
      not present, the unit will not be able to align and will require
      service.
      If this is a new ink cartridge, verify
      that the blue tape covering the nozzles has been removed. Do not remove
      the copper flexible circuit with the electrical contact points. If no
      tape is present, try reinserting the original cartridge and performing
      the alignment process before trying the new cartridge again.
      If the unit still will not print, remove and reinsert both ink
      cartridges. Verify that the cartridges are the correct part numbers for
      this model.
      Clean the ink cartridge. The ink cartridge nozzles may be clogged, or
      the electrical contacts may have something on them that interferes with
      the electrical connection. If the ink nozzles are clogged, the print
      may be faded or have white lines. Use the following steps to clean the
      ink cartridge:
      Clean the cartridge with a cotton swab or clean cloth slightly dampened
      with distilled, filtered, or bottled water. Unfiltered water may
      contain contaminants that can damage the print cartridges
      Remove
      any ink or dirt from the bottom of the ink cartridge. Do not touch the
      nozzle plate with anything other than the cotton swab.
      The ink cartridge may be defective; replace the ink cartridge.
      If the issue is still unresolved, replace the ink cartridge that was not previously replaced and try again.
    • 13,433 Answers
    Remove and clean the cartridges, connect them again and aling again.
    New brand cartridges? or cheap copys?
    • Ekse Jan 18, 2009
      The issue is most likely in the printer, the cartridges are probably fine. did you clean the contacts? how old is the printer?
    HP 4500 prints blank pages
    what does the copiers window show.. take the cartridges out and reinstall them..try again..
    Aug 03, 2014 | HP Officejet 4500 G510G Inkjet...
    Hp officejet j4580 flashing "incompatible
    hello
    you must purchase original ink cartridges -- not all compatible cartridges are built the same..
    i would suggest buying authentica , from HP dealer or reseller
    go to www.compluscominc.com, they will help you for sure and let you kno what to buy and how much
    CC653AN icon_x.gif Contact Reseller
    HP 901 Black Officejet Ink Cartridge - Prints approximately 200 pages (North America)
    RoHS: Modified
    CC654AN icon_x.gif Contact Reseller
    HP 901XL Black Officejet Ink Cartridge - Prints approximately 700 pages (North America)
    RoHS: Modified
    CC656-30001 icon_x.gif Contact Reseller
    HP 901 Tri-Color Officejet Ink Cartridge - Prints approximately 360 pages
    RoHS: Modified
    please send me 4 thumbs up
    Aug 12, 2011 | Office Equipment & Supplies
    Every time I turn off the printer, when I turn it back on it prints a test page. How do I stop this?
    This problem is caused by not adjusting the printer after replaceing the ink cartridge. You will have to aline the cartridge by printing out a scan page then putting it in the scanner and selecting the lines that line up best for the printer. Once you have done the alinement process it will no longer do this. Every HP I have owned has done this. here is the page to go to to set it up to stop this problem. Hope this helps and thanks for using Fix-ya. Let me know if this helped.
    http://h10025.www1.hp.com/ewfrf/wc/document?docname=c01336348&cc=us&lc=en&dlc=en&product=428800&tmp_track_link=ot_search
    Oct 06, 2010 | HP PSC 1510 All-In-One InkJet Printer
    Prints test page every time i switch on
    you have to print test page then alin the page up withthe bars and letters, you have to do this each time you put in a new cartridge, use he menu key to aline the keys.
    Jan 13, 2010 | HP PSC 1510 All-In-One InkJet Printer
    Keeps asking to aline print cartridges yet a printer test page prints okay.
    This is normal when replacing the ink cartridges. You should be able to just do the aligment procedure to get rid of this message.
    Oct 18, 2009 | HP PSC 2210 All-In-One InkJet Printer
    Recived faxes only print out blank pages
    Someone sent you fax upside down. If your machine prints and copys OK, it's not your machine.
    Aug 19, 2009 | HP OfficeJet 7310 All-In-One InkJet...
    Will not print blue
    Try this I triedi in my printer cartridge which was stuck for a while and only prints in red other colors dont. First you remove the cartridges get a clean dry tissue / towel paper and smudge the cartridge printing heads to the tissue it should give all the colors if not the ones that dont may have hardened. Get warm water (Clean) in a bowel and submerge the printing heads on the water not the entire cartridge to dissolve any deposits then try them again. Hope it works it worked on mine.
    May 30, 2008 | HP Officejet Pro L7580 All-In-One InkJet...
    HP880c missing colors
    you need to go to preferences and adjust the new cartridges, aline, clean, etc.
    Jan 06, 2008 | Office Equipment & Supplies
    78 people viewed this question
    jasbo
    jasbo
