Question about Xerox Phaser 8400 Laser Printer
The printer is producing distorted, sort-of smeared documents.
The printer is producing a distorted, sort-
of smeared document tht cannot be read. Help I just spent $600.00 on ink!!!
    President:
  • 2,072 Answers
If you remove the right side cover, locate the drum shaft about midway back and midway up.
There is an encoder on the end of that shaft. Remove it and clean it with some alcohol. Don't be afraid to flush it a few times. Let it dry and reinstall it. It get's contaminated with the silicon oil from the maintenance kit and causes a very blurry print because the drum runs the wrong speed.
That may need replaced, but the vast majority of the time, cleaning the encoder resolves that problem.
Posted on Jan 18, 2009
Printer producing dirty copies
it could be that the roller needs cleaning, how you do that, I don't know, but that's my guess. try printing blank white pages and see if they come out dirty
Nov 26, 2013 | Xerox WorkCentre Pro 555 Plain Paper Laser...
The document printed from samsung scx 4200 printer has smudges and dots.
When you say smudges, can you wipe the toner from the page with your fingers; or is it just smearing when it prints; but, the toner is affixed to the paper?
1) If you can smear it with your fingers; replace the fuser. It's not heating the toner properly
2) If it is smearing, but sticking; replace the DRUM.
Nov 07, 2010 | Samsung SCX 4200 All-In-One Laser Printer
Can I scan a document to PDF?
any scanner, indeed any document, picture format can be saved as pdf. i would suggest first scanning the document as text (for example to words, or openoffice or indeed whatever you use as your document management program) and then port it (sort of print operation) to any free available "translator" program which allow you to save file as pdf. alternatively you can scan your document as jpeg and then save it as pdf, but this tend to produce very messy outlook and results are usually horrible.
Jul 27, 2010 | Brother MFC 8440 All-In-One Laser Printer
Automaticly deletes documents before
Check the settings of the printer. In the mean time, copy all the printable files to a new folder for safety reasons. Copy them and NOT move them. meaning you have a backup till you sort the problem out.
Aug 07, 2009 | Zebra Eltron TLP 2844 Thermal Label...
HP OfficeJet 6400 sorts pages automatically when scanning.
When you go to print make sure you have the print settings to "collate".
May 27, 2009 | HP OfficeJet 6210 All-In-One InkJet...
Copies run through feeder distorted
Document feeder Paper feed rollers should be cleaned with alcohol, blow out the document feed area with compressed air (computer duster), check feeder for bits of paper, post it notes, and signature flags. Clean glass, check for sticky areas on the glass.
Hope this is of some help.
Ed
May 12, 2009 | Toshiba E-Studio 3511 Color Copier
C-7250 HP all in one appears to have a stopped up printer head?
Try placing sheet of black text on copy board, and run many copies black only. I ran 25x12 times still no black. Run head clean after about each 50 sheets. Persevered and finally BLACK ink OK Inkypete
Apr 23, 2009 | HP Photosmart C7250 All-In-One Thermal...
Documents come out wrinkled
problem with fusing assy. replace fuser.
Jan 15, 2009 | OKI OL 400e Led Printer
F380 All-in-one Deskjet
What sort of document are you trying to print (Word document, Excel spreadsheet, something else)? Also, what kind of paper are you using? Certain types of paper can stop progressing through the printer for a variety of reasons, regardless of the document type.
Thanks.
Sep 25, 2008 | HP DeskJet F380 All-In-One Printer
Cannot edit scanned document
its like this, the OCR or the SOftware installed in your computer is limited. If you're trying to scan a document which has a picture or with text that uses different fonts like monotype, or those that are not usually being use for normal documents, usually it wouldnt detect and it become distorted. Anyways, here are the steps that i want you to follow.
1. Open solution center. (click start, go to all programs, go to HP, then click on SOLUTION CENTER). or you can see SOlution Center on your Desktop.
2. Click on Scan Documents, then the Scan documents setting will open. Change the settings to these.
* SCAN TO: Microsoft Word.
3. Then, hit scan.
4. After scanning, the folder My Scans will open automatically, just go ahead and open the scanned document.
5. From there, you can start editing the text.
..remember, the scan a document is limited, it will not read all types of fonts. if the document is using a "times new roman" or "arial" the scanned document appears to be almost the same with the original. But, if the scanned document contains pictures or stylish fonts, that would make the document distorted.
Please let me know if you still have clarifications.
Thank you.
adonscott
May 01, 2008 | HP Officejet 5610 All-In-One InkJet...
Xerox Phaser 8400 Laser Printer Logo
209 people viewed this question
Top Xerox Office Equipment & Supplies Experts
Michel
Xeroxrep
Level 1 Expert
Philip Hughes
Are you a Xerox Office Equipment and Supply Expert? Answer questions, earn points and help others
