Sharp AL-1661CS All-In-One Laser Printer
Problem for Sharp AL-1661CS All-In-One Laser Printer
HP officejet 7310 - paper jam, but no paper jam
By jenn_watt on Jan 17, 2009
After I turn the printer on it says paper jam. There is no paper jammed anywhere, checked all locations. Did a partial reset a couple of times. Rollers are clean. What else can I do other than try to find someone to service it?
Best Solution
posted on Jan 19, 2009
Very Helpful)
yooperbud
Rank: Wiz
Rating: 82%, 2034 votes
Normal 0 I suggest you get a sheet of Card Stock (Heavy paper) and place it in the feed way. Then press the print button applying a slight amount of pressure on the Card Stock so it will feed through the printer. The reason for this, is in some cases I have been able to clear the paper track of debris that was deposited there over time.
Worth a try, as I have fixed a number of printers this way, saving costly repairs.
Hope this helps. Bud
Was this helpful?
Yes
No
1 person thought this was helpful
Popular Solutions for Sharp AL-1661CS All-In-One
Questions and Unsolved Problems for Sharp AL-1661CS All-In-One
Do you recommend Sharp AL-1661CS All-In-One Laser Printer?
Answer
Answer
tried clear exposure clear, but cant get into the simulation mode to reset a fuser code...
Answer
Hi we have an extened warranty on out Sharp 16661 all in one. We moved office's and now we can get... (More)
Answer
I have reviewed a previous solution you gave regarding reseting the drum counter on my printer. Your... (More)
Answer
I have replaced the drum but do not know how to reset the counter I don't understand the interrupt,... (More)
Describe your problem:
Select a Category:
Ask our Experts
Solve Your Problem Now!
Chat Live with an Expert
Chat Now
Browse popular Problems
More Common Problems
Most Common Problems for:
For Sharp AL-1661CS All-In-One...:
Top Printer Experts
Rank: Guru Guru
Solutions: 727
Experience: 30 Years of professional repair and design.
Ask Me
Find more Printer Experts
Top Printer Repair
(800) 836-9287
Celebrating 14 Years Of Outstanding Printer Repair...
Laser Repair 911
(972) 907-9771
Printronix, IBM, Tally, Genicom, TallyGenicom,...
Sinca Printers, Parts & Repair
Chat Now
X
Continue
When the original poster rates a solution that was given to his own problem, that rating is locked!
X
Are you sure the solution content is Inappropriate?
Tech buddies can communicate directly to answer questions. Become a Tech Buddy and have direct access to your favorite expert for FREE!
Insert Link
Insert Image
Insert You-Tube clip
Insert List
Insert List
Spell Check
What is this?
Select
