Question about Hitachi 50UX57B 50" Rear Projection Television
50UX58B won't turn on -no led's on-nothing
Saw your reply seems like your the man i need to talk too. My tv won't do nothing at all. Help Please. 50ux58B hitachi
MY TV DOES NOT TURN ON?
WHAT IS THE DIGNOSIS BESIDE CHECKING THE POWER TO THE TV AND REMOTE BATTERIES?
Posted on Jan 21, 2009
Off and Ten Red Blinks?
ALL MY TVS ARE SONY.4 YEARS AGO I HAD SIMILLAR PROBLEM AND I JUST CALLED THE SONY CENTER HERE IN GREECE!I TOLD THEM THE FLASHES AND TOLD ME TO DO 3 THINGS.FORTUNATELLY THE 2ND WORKED AND RUNNING SMOOTH SINCE THEN.SO JUST MAKE THE CALL TO SONY NO OTHER REPAIR MEN!U NEVER KNOW!!
May 19, 2014 | Sony Televison & Video
Cord won't pull more than a few inches on new mower. Seems locked up. I've only ran it once.
Ensure the cable for the dead man switch is not kinked. Follow the cable from the handle to the engine. There are 2 bolts that mount the dead mans switch to the engine , remove bolts, remove dead mans switch from engine, let hang, try starting. If starting, clean dead man contacts and reinstall. You may have to remove recoil rope assembly and engine cove to get to dead mans switch.
Jul 04, 2012 | Troy Bilt 5.5hp Self Propelled Mower
Where is the capacitor and pico fuse located on a hitache 50ux58b tv
The capacitor is located just to the right of the horizontal output transistor...and the fuse is located right near the 120V B+ led208a291.jpg381bd58.jpg0b0a02d.jpg0f62099.jpg
Oct 04, 2010 | Hitachi 50UX58B 50" Rear Projection...
Hitachi tv model 50ux58b starts to come then goes off
If you have Hitachi model number 50UX58B, 60UX58B, 50UX58K, 60UX58K, 50SBX78B or 60SBX78B and you have the following symptoms you may want to grab a repair kit from www.TvRepairKits.com. They have put together a kit that includes the parts and instructions to fix these models. This is a fairly common problem with the above model numbers. It is typically caused by a blown capacitor and pico fuse. Again, you can get a kit from the above address.
Here are the symptoms...
Primary Symptom: No Audio or Video. Power light will come on briefly then shut off.
Other Possible Symptoms : The green LEDs on the circuit board light up for a few seconds then turn off.
Hope this helps,
Nov 07, 2008 | Hitachi 50UX58B 50" Rear Projection...
Tv won't turn on.
Hope this helps,
Oct 07, 2008 | Hitachi 60SBX78B 60" Rear Projection...
Hitachi 50UX58B
hello . rember me .? I told you to replace the hole board.!!! and we will go from there.!!! WELL you did not get back to me.!!! and you rated me as just helpful. !!! well tell me did it not fix's your set .& make it work now. !!! Right.!!! so if you think about it . YOU DID RATE ME RIGHT.!!! YOU SHOULD OF RATED ME AS FIXYA. . BEOUSE IT DID FIX YOU AND YOUR SET WORK NOW.!!! AND IT DID NOT BEFORE. YOU NEED TO CHANGE MY RATING TO FIXED YA,. ANFD THEN WE WILL GO FROM THER AND WILL LET YOU KNOW HOW TO FIX YOUR OTHER PROBLEM'S YOU HAVE NOW. THANK YOU "GOOD LUCK"
Oct 01, 2008 | Hitachi 50UX58B 50" Rear Projection...
Hitachi 50ux58b 50"
hello. it sound like a power supply problem to me .!!! it could be a bad solder joint.!!! or a bad fly back transformer.? "good luck"
Jul 27, 2008 | Hitachi 50UX58B 50" Rear Projection...
Tv dead
hello. the loud pop you heard was .maybe a fuse.? u need to uplug .!!! the set !!!. and take off the back and see if fuse is bown.? ok let me know.!! ok
Jun 02, 2008 | Hitachi 50UX58B 50" Rear Projection...
Won't power up
Hope this helps,
Sep 17, 2007 | Hitachi 60UX58K 61 in. Rear Projection...
Hitachi 50ux58b
Hope this helps,
Jan 02, 2007 | Hitachi 50UX58B 50" Rear Projection...
Hitachi 50UX57B 50" Rear Projection Television Logo
121 people viewed this question
Top Hitachi Televison & Video Experts
Jaime Hernandez
Are you a Hitachi Televison and Video Expert? Answer questions, earn points and help others
