Question about Indesit 23 in. DV62 IX Built-in Dishwasher
Indesit dishwasher DV62
I have an error the first two lights are flashing and the water inthe machine is not draining
  • Anonymous Aug 11, 2008
    i have the very same problem, i will see if i can fix it myself. fingers crossed.
  • 27 Answers
You have a blockage in your drain pump. Remove all filters and scoop out as much water as you can from the unit. Check in the bottom for any objects stuck there. Some models have a cover on the bottom inside the unit, which once removed, will expose the drain pump impeller. If yours does, remove the cover(usually 1 screw only) and free the drain pump impeller. NB: DO NOT REMOVE THE SCREWS WHICH HOLD THE BASE TUB IN PLACE! These are the screws on the edge of the white plastic "bowl" inside the unit. The drain pump cover will be INSIDE this bowl and will be quite small, no more than 5cm dia.... If this does not work, you will have to remove the drain pump from the bottom or front of the unit to get the blockage out. Oshie
Posted on Jun 26, 2007
SOURCE:
No water entering the dishwasher
Here is a tip that will help you to find out why water will not come into thedishwasher...
Dishwasher Trouble No Water entering Dishwasher
heatman101
Oct 28, 2010 | Indesit 23 in. DV62 IX Built-in Dishwasher
Indesit DV 620 Dishwasher: Reaches the end of it cycle then sits for ever with the DRYING light flashing. Cannot reset it or start a new cycle. However, intermittantly it will reset.
Hi I had the same problem with the ID620. Just fixed it last week. With the ID620 flashing 4 means tha t there is a problem with the heating circuit. Either the element, the stat or the control board. Mine was a problem with the control Board. I took the board out and after some debug found a faulty zener diode. Replaced with new one from Radionics (1 euro) and machine now 100%.
Sep 29, 2010 | Indesit 23 in. DV62 IX Built-in Dishwasher
Indesit DI 620 which won't drain water
this appliance is a built in dishwasher and may have somthing jamming the pump,this can only be acessed from the bottom and may require the appliance being removed,also check that there is not a blockage at he sink.
Apr 19, 2009 | Indesit 23 in. DV62 IX Built-in Dishwasher
DV62 WH UK
pay me 9.99 dollars and you can have the info cheers.
Nov 19, 2008 | Indesit 23 in. DV62 IX Built-in Dishwasher
Indesit DV620
check your manual it should tell you what this code means and wether you can deal with it yourself
Nov 22, 2007 | Indesit 23 in. DV62 IX Built-in Dishwasher
Indesit di260
if its the latch tongue remove the top panel...if its the door remove the console
Aug 17, 2007 | Indesit 23 in. DV62 IX Built-in Dishwasher
Indesit DV620 Dishwasher
You have a internal leak in the dishwasher...there is a safety float system in the base (below where you put the dishes in!) of the unit, which in the event of water in the base will stop the cycle and activate the drain pump continiously.... You will have to open the unit and find the leak. Don't know these models, but usually you have to remove side panels and front panel, drain water from the base and re-start....then check with flashlight where the leak is. Oshie
Jun 21, 2007 | Indesit 23 in. DV62 IX Built-in Dishwasher
Flashing lights
You have a heat problem, using a test meter check the heater element, then check the thermostat if niether of these you have a PCB fault Regards Engineer
Mar 15, 2007 | Indesit 23 in. DV62 IX Built-in Dishwasher
Open Questions:
See all Indesit 23 in. DV62 IX Built-in Dishwasher Questions
Indesit 23 in. DV62 IX Built-in Dishwasher Logo
501 people viewed this question
Top Indesit Dishwashers Experts
Eric Taylor
Marvin
Marvin
Paul Bade
Are you an Indesit Dishwasher Expert? Answer questions, earn points and help others
