Question about Kirby Ultimate G Bagged Upright Vacuum
My kirby ulitimate G series will not turn on
I was vacuuming yesterday and have not had any problems and then i shut it off for a few minutes and it won't start up again.
  • 2 more comments
  • bobstreib Jan 22, 2009
    I have the same problem with a 5 year old Ultimate G. I can usually get it to come on by loosening the belt with the lever on the front under the light cover. It seems to be getting worse though and takes longer to get it to come on.
  • njbuttise Jan 26, 2009
    I have the same problem and I thought that it might be the on/off switch, but now I have doubts.
    Jim
  • Rocky
    Rocky May 11, 2010
    That sometimes happens to vacuums that have thermal switch (usually soldiered onto the motor field) but Kirby does not have such switch so I would blame one of 3 things:
    1 - cord. Even though it may look good it may have wires broken inside.
    2 - OUTER bag is not installed right or is a bit worn and is loose. It does not press the safety switch well at all times.
    3 - faulty power switch. There is only 1 switch inside of the Kirby with few levers. It is a bit more complicated to replace it though (I have instructions with pictures if anyone cares to see them)
    Would LOVE to know if there is something else that causes it.
  • Anonymous Jun 24, 2017
    It was number 2 for me. After reconnecting the bag after shampooing, I didn't engage the safety switch. Thanks!
  • 357 Answers
HELLO,
PLEASE SEE MY TROUBLESHOOTING GUIDE...
http://reviews.ebay.com/COMMON-PROBLEMS-WITH-THE-KIRBY-VACUUM-TROUBLESHOOTING_W0QQugidZ10000000003800312
MANY OTHERS HAVE HAD SUCCESS WITH DIAGNOSING AND FIXING THEIR OWN KIRBY USING MY GUIDE. I HOPE THAT YOU ARE ONE OF THEM... :0)
MARCI
Posted on Jan 29, 2009
SOURCE:
My Kirby G3 diamond series won't turn on
Hi There, The most common problem by far is that the cord is faulty. This is a pretty easy repair to do at home. If your machine was randomly cutting out before it stopped altogether then the cord is likely the culprit. If however it stopped all of a sudden with no warning then it is possibly a switch or motor issue which is a much harder repair to achieve for a novice.
The kirby cords are not terribly expensive (and I have linked a how to video showing how its done) so if you need a new one I would say DIY is the go, otherwise spend the $25 get a pro to take a look.
May 22, 2012 | Kirby Generation 3 Bagged Upright Vacuum
Tip
IS YOUR KIRBY BROKEN?****FIX IT YOURSELF WITH MY GUIDES!!!!
I have written a troubleshooting guide for diagnosing and fixing your G series Kirby. I hope you find it helpful!!! Click the link to view...
HAPPY VACUUMING!!! :0)
Marci
on Feb 06, 2008 | Kirby G5 Bagged Upright Vacuum
Smells like burning rubber when I turn on my G6 Kirby vacuum.
You must take of the plastic ends from the wood beater bar and make sure the metal axels are not wound up with hair. I did this monthly with 4daughters
Feb 15, 2010 | Kirby G4 Bagged Upright Vacuum
My Kirby vacuum cleaner will only run for a few
could be caused by bad bearings in the motor or bad carbon brushes and a worn commotator on the armature. check the cord where it connects to the top of the handle on the swivelling strain relief. usually the cord fails there .
Jan 03, 2010 | Vacuums
Burning rubber smell when the vacuum is on.
it sounds like the belt may be burning like the roller bar is stuck maybe or the belt is stretched and is burning itself off
Jan 11, 2009 | Kirby Ultimate G Bagged Upright Vacuum
Kirby Ultimate Diamond Edition G Series, upright. Problem: I lost my manual. How do I use my vacuum on hard wood floors? How do I use attachments, where do they attach?
http://www.geeksquad.fixya.com/ThreadView.aspx?prdid=0&thid=576029
Generic problem for all Vacuums
Posted by jlutsi on May 06, 2008
I would advise you to ALWAYS to FIRST UNPLUG YOUR VACUUM before beginning any service procedure.
You can cal the Kirby factory to request a new owner’s manual and they will describe how to use the vacuum on hardwood floors. There is a felt piece as wide as the brushroll area that will clip on to the bottom of the revolving brush area so that you hard wood floors don’t get scratched. The Kirby head will dial off and the Kirby head will come off and the attachment hose will connect to the front of the Kirby and that is how you use the attachments. Also contact your local Kirby vac dealer. So if you need further assistance, please feel free to contact your local vacuum cleaner dealer in your area or in the yellow pages, or contact the factory phone number or website to further assist you with your questions.
http://kirby.com Contact Us by Phone
United States and Canada 1-800-494-8586
Between the hours of 8:00 am to 5:00 pm EST
Monday thru Friday
Don – The Vac Man
Go Ahead. Use Us.
May 06, 2008 | Vacuums
Help on kirby G4D
here is a link to taking the fan off of the kirby...all the Generation Series Kirbys are the same :)
http://reviews.ebay.com/KIRBY-VACUUM-REPAIR-HOW-TO-REPLACE-THE-FAN-IMPELLER_W0QQugidZ10000000003711302?ssPageName=BUYGD:CAT:-1:LISTINGS:3
Hope that helps!!!
Apr 05, 2008 | Kirby G4 Bagged Upright Vacuum
Gear lever
here are a few links to repair proceedures for the kirby (pictures included)
Transmission:
http://www.greatvacs.com/Kirby%20Transmission%20Adj.shtml
On/Off switch
http://www.greatvacs.com/Kirby%20Powerswitch.shtml
Hope that helps!
Jan 02, 2008 | Kirby G6 Bagged Upright Vacuum
Kirby Ultimate G Bagged Upright Vacuum Logo
6,642 people viewed this question
Top Kirby Vacuums Experts
JoeVacs
Gerry Harvey
Gerry Harvey
Are you a Kirby Vacuum Expert? Answer questions, earn points and help others
