Question about Datacard SP35 Printer
Datacard hello have you a soluzio for datacard sp55, upgrade to monocolor in to color? I have 2 printer, and is a very problem. thanks Roberto rdiodoro@yahoo.it
  • 36 Answers
To convert you would have to change system board, and buy new print head, it would be cheaper to trade in for discount on new printer.
tulsabiz.net for more info
Posted on Mar 19, 2010
Hi ... I would like to see if I can help with this
datacard has manuals on line and also you can use the troubleshooter on your computer to see if it can detect any isues
Oct 17, 2013 | Datacard SP55 Printer
Datacard error PR 01739
Upgrade the printer firmware (Go Green firmware update) as you are likely using the newer eco friendly ribbons. The older firmware versions do not recognize this ribbon, which leads to the PR01739 error.
Download firmware here: https://www.datacard.com/id-card-printer-support-and-drivers/sp55-plus-card-printer
Dec 02, 2012 | Datacard SP55 Plus Printer
I have a SP55 Simplex Datacard printer that has the capability to be upgraded to duplex and I have install the program on a windows 7 64 bit system. The test card comes out perfect but when I do a 2 sided...
A simplex printer can print 2 sided cards you need a duplex upgrade kit. Its is a mechanical "card flipper" that is to be installed in the printer.
Contact TulsaBiz.net for more info and upgrade pricing, Also a firmware update.
Aug 05, 2011 | Datacard SP55 Printer
THe datacard sp55 color card printer is printing monochrome(black and white). I have done lots of setting changes but still couldn't manage tro print the right color. And the duplex module is not on the...
The printer needs to be serviced, The Monochrome issue could be related to a problum with the RFID chip in the take up wheal of the ribbon, but the duplex offset can only be adjusted by an authorized service provider using a special password and diagnostic tool.
www.TulsaBiz.net offers a depot service.
Aug 26, 2010 | Datacard SP55 Plus Printer
Datacard sp55 printer won't recognize ribbon
PR-01726 Ribbon Out
Out of print ribbon.
Possible Cause 1 : The print ribbon Cartridge is empty.
Solution 1 : Reload the print cartridge. Change the cleaning sleeve and replace the cartridge in the printer. Run a cleaning card as soon as printing is completed.
Possible Cause 2 : The printer ribbon is not loaded correctly.
Soultion 2 :Load the printer ribbon correctly and then close the cover.
Possible Cause 3 : This ribbon has been completely used.
Solution 3 : Use a new roll of ribbon.
Tips for Success
* When this message appears, replace the old ribbon with the new ribbon of the same type. The printer has already prepared the card data for this ribbon type. You can change the colors of monochrome ribbon (such as from dark blue to gold).
* If you must change the type of ribbon (such as (YMCKT to KT) when this message appears, install the new ribbon, cancel any cards waiting to print, and change the ribbon type settings. Finally, return to the card creation program to send the card data to print.
* If the ribbon was repaired, the wrong take-up spool was used. Repair the ribbon again, using the correct take-up spool.
If you cannot fix the problem contact your service provider for assistance.
FTB
Nov 23, 2009 | Datacard Group SP55 Card Printer
I cant find driver for windows xp 64 bit. the driver that are in datacard page not functioning in xp 64 bit
Try this link:
http://support.securitworld.com/pub/Drivers/ID_Card_Printers/Datacard-ID_Card_Printer_Drivers/
Apr 22, 2009 | Datacard SP55 Printer
SP55 Datacard
The printer does not know the the model of the ribbon installed and thinks it is a monochrome (single color) Print ribbon. You can verify this in the Driver toolbox under the supply tab, or in the advanced printing options.
The Datacard SP series printers use an RFID Radio freq. tag in the take up spool end of the ribbon. This identify s the ribbon model and supply use settings for the printer.
Make sure you have the most recent driver and firmware from Datacard, There is a firmware Update Available to help reading "weak" RFID tag's
Next try removing the RFID tag from another (old) ribbon and see if it that fixes the problem)
Aside from that you:
May have a counterfeit (non-Datacard) ribbon
A bad RFID tag
Someone removed your RFID tag
You need a firmware update (weak RFID tag)
A bad RFID reviver in the printer, which is a fairly cheap repair.
Basically try a new print ribbon if that does not correct the issue, have the printer serviced.
www.TulsaBiz.net
Apr 07, 2009 | Datacard SP55 Plus Printer
DATACARD
As I recall, the difference between the mono and color is the main logic board and RFID reader. To convert a machine you may be looking at $800 in parts alone.
Dec 20, 2008 | Datacard SP55 Plus Printer
Datacard SP35 Printer Logo
141 people viewed this question
Top Datacard Office Equipment & Supplies Experts
Safe-Card ID...
jason
Don  Farrell
Don Farrell
Are you a Datacard Office Equipment and Supply Expert? Answer questions, earn points and help others
