Question about Cobra CPI 1000 DC to AC Power Inverter
I bought a cobra cpi 1575 about two weeks ago and installed in my truck. (replaced an old one that had quit working) it worked great until the last time i used it it went into error mode (loud continuis beep) and the display said olp. i unpluged everything from it as this is suposed to indicate an overload on the inverter, turned the inverter off and waited (now two days) but when i turn it back on it still says olp and beeps with no power output even with nothing pluged in? i have disconected it and powered on to drain it then reconected it and no change.
Got a cobra cpi 480 inverter it keeps beeping everything runs but produces no power
Posted on Mar 28, 2013
2 Suggested Answers
messstat
  • 365 Answers
SOURCE: power invertor weill beep a few times then shut
insufficient ground...check your connections and try again...do NOT continue to use the unit if the problem persists.
Good Luck
Posted on Jun 15, 2009
Need Help with burned resistors value. Please.
have you repaired the component that burned these resistors out? if not then you cannot replace them as they will just cook again.
Nov 06, 2015 | Cobra CPI 1575 1500 Watt 12 Volt DC to 120...
Cobra CPI 1575 comes on 3 red letters flash. Makes a annoying beeping sound for like 10 mins then goes out. Please explain what i need to do. Its Brand New in a Brand New Rig Thanks!
plug it in
the letters are the voltage / no ?
the beeping is that its not sensing ac source saying its on battery
or its an error code
May 03, 2015 | Video Game Consoles & Games
M/n cpi 1575 I've had my inverter installed in my
it indicates an overload situation
not enough information provided as to voltage supplied to the inverter and the voltage of the grinder
examples are for 110 volts ac with a current draw of 4.2 amps the wattage is 462 watts or for 240 v ac with 4.2 amps the wattage is 1008 watts assuming that it is 240 volts and the inverter has a maximum ate of 1000 watts then it is overloaded and circuit protection is cutting in
check the wattage of the inverter and the wattage of the ac units you use and if there is not a 25% difference in favour of the inverter then it is an overload situation
Jul 27, 2017 | Cobra ® Power Inverters
Every time I try to log in to messenger a window pops up which says......application failed to initialze properly {Oxc0150002] WHAT CAN i DO? WAS WORKING JUST FINE A WEEK AGO
لاتقاطعوا ولاتدابروا ولاتحاسدوا وكونوا عباد الله إخوانا
Dec 26, 2009 | Yahoo YHT-630 System
Rough idle and acceleration on 1998 Chevrolet Silverado 5.0
Bad EGR valve comes to mind here. Assuming the plugs are good, the EGR valve woiuld be what I'd look at.
Jul 26, 2009 | 1998 Chevrolet Blazer
Need fuse size for cobra cpi-850
80a fuse should work fine thats the size i have it installed with i used 4 ga. wire
Jan 08, 2009 | Cobra CPI-850 Car Audio Amplifier
Died and will NOT start.
I experienced a similar problem with mine and I replace the little plastic tube that is immersed into the fuel. It had some stuff in it and preventing fuel from getting to the engine. It was only about 1.50 to replace.
Jan 05, 2009 | Craftsman 4 Cycle Blower/Vac
My Mouse died
Did you check the batteries to see if they are good. Some individuals are having to replace the batteries sooner then they should have to. Good place to start. Hope this helps. Bud
Jun 11, 2008 | NexxTech NWOMMI Mouse
CARTRIDGE WONT ALIGN
The following error message appears on the LCD panel1.gif on top of the printer after you insert a cartridge: Press enter to align cartridges . You press Enter , but the error message does not go away. The printer will not print. Solution To bypass the cartridge alignment, do the following:
  1. Press and hold the Setup button.
  2. Press the Options button. The printer should be ready to print.
If the print quality is unacceptable after bypassing alignment, follow the steps below until the error is corrected.
Feb 13, 2008 | HP PSC 2210 All-In-One InkJet Printer
Monitor will not start up!!
It may be a corrupt backup you are trying to install, but if there is a corrupt file you will need to borrow a genuine XP disc off a friend to repair it. You can use your own license number for the copy so your friend shouldnt be concerned with piracy. You may get the pc running by locating on the motherboard either the 3 pin JBAT1 terminal and put jumper from pins 1-2 to pins 2-3 then back to 1-2, or short both pins if you have a 'CLRCMOS', 'CLRRTC' or 'RTC' 2 pin terminals with a jumper cap. Restart pc and it should make you press F1 to set the cmos time and date and hopefully boot into windows, but if not the first paragraph will be the solution to the problem.
Apr 25, 2007 | Acer Aspire T310 PC Desktop
Cobra CPI 1000 DC to AC Power Inverter Logo
1,147 people viewed this question
Top Cobra Electronics - Others Experts
Gil Shultz
cwradio73
Bill Boyd
Are you a Cobra Electronics - Other Expert? Answer questions, earn points and help others
