Question about Bosch Evolution 300 SHE43M05UC Stainless Steel Built-in Dishwasher
Dishwasher won't drain -it's only 3 months old
Sears already came out (that's where we bought the machine) to look at the machine - it still won't drain. All areas were cleaned. Does this product have a problem history of not draining?
  • 30 Answers
Yes they do have a drainage problem! I worked for a Sear install team. You need to have the installer come back out, if they did the install correctly and you still have problems then sears needs to send a service tech out. If they can't fix it or tell you it is a install error then be persistent and tell them you want a BOSH TECH out. You more than likely need a stronger pump as Bosh DW work off a gravity type pump system. Keep in mind Sears installers guarantee there install for 1 year and all products come with a 1yr MF warranty. If you purchased a warranty or PA agreement the you will be entitled to a new unit if that one is not fixable. If you have a garbage disposer, they work best when routed into one.
Posted on May 04, 2009
Heavy and smart auto light blinking? Over follow error
Hello Cathryn;
My name is Peter. I am a retired field service appliance technician.
The flashing of those two buttons means; "Over-Level Water Error".
This could mean you just need a good internal cleaning:
1.) You are not completely draining, afterwards your dishwasher goes into the fill and you have too much water in the dishwasher, you are plugged up.
2.) The drain hose from the dishwasher to the garbage disposal may be plugged up. Remove and clean until you can see light through the hose. If not replace.
3.) The connection on the garbage disposal may be plugged up. With a tooth brush, scrub the inside of this connection.
4.) The drain pump may be plugged up. This requires disassembly of the pump.
5.) The cutter in your dishwasher bottom drain may be plugged up.
If I were still working as a full time appliance technician; I would charge your $100.00 just to show up at your door, $180.00 to fix the problem and if parts are involved, it would be the part sale price X 2.
I always hated meeting nice people and charging them so much.
So, what do you do.
1.) If your dishwasher is under 5 years old. The date of manufacture should be on the same label that your model number is on.
a.) Go into the Sears home Services Website and purchase a; "Smart Agreement". Not the Master Protection Agreement which is expensive. The "Smart Agreement", will cover you for up to $500.00 per service call.
b.) Wait about 3 months and schedule a service call. You will be covered.
2.) Your dishwasher is over 5 years old. You can go into the Sears Home Services website and print out a coupon for 10% off the service call.
3.) Or, If you do not want to pay $300.00 or $350.00 for a service call, then go into the internet and search; "Sears Outlet Stores". This is a scratch and dent store where you can save several hundred dollars. You also receive a 1 year warrantee. I have made a rare few service calls on these appliances because you are covered.
Go into the following website. Put in your model number. You will get diagrams, part numbers and cost.
Water Filters Lawn Garden Appliance Parts
Mar 23, 2016 | Samsung 24 In. Stainless Steel Dishwasher...
Frigidiare galarie dishwisher
This sounds like a question already answered by another expert, where he mentioned that if the dishwasher is only 9 months old, that you should contact the seller, lest you void the warranty by trying to fix it yourself. That being said, I would recommend that you check the end of the drain hose where it goes into the garbage disposal, and make sure it is not plugged or clogged there. Also make sure that port in your garbage disposal is clear. If you just bought a new garbage disposal, be aware that they come with a molded-in plastic plug at the end of that dishwasher port, and you have to knock it out with a nutdriver (or some similar tool) and a hammer.
Mar 21, 2015 | Dishwashers
Battery keeps draining already put in a brand new alletantor and brattery still draining and battery lights comes on and truck won't start
You would have checked the charging system before replacing the alternator, so I will assume the charging system is good.
If the battery is being discharged overnight or over a few days, you would need to disconnect it and check every circuit on the truck to find the drain.
Oct 10, 2012 | 1990 Ford F150
My kenmore diswasher model 665 15772 - lock button is flashing - dishwasher will not start. Can you help me?
6/3 I bought a Kenmore Ultra Wash dishwasher, Model 665. As many others have posted, my dishwasher also do does not automatically drain, leaving about 3" of water in the bottom of the machine. The only way to pump the water from the machine is to use the Drain/Cancel button, which cancels the cycle, and the dry option, leaving the dishes wet and spotty.
I just contacted a tech rep with Sears Repair and was told this is a Factory Defect with this model. Whirlpool (manufacturer) is aware of the problem and working on a resolution. Meanwhile, Whirlpool (via Sears and K-Mart) offers a free service call to install the "retrofit kit" that should solve the problem.
Even though Sears is aware of this problem, you will be expected to jump through their hoops - did you install a disposal at the same time and knock out the plug (FYI - if the plug is not knocked out, the Drain/Cancel option will not work and the machine will not drain at all). They will also ask if there is anything blocking the drain (FYI - if there is a foreign material block of any kind, the Drain/Cancel option will not work and the machine will not drain.
If this dishwasher (Model 665) does not drain automatically, THIS IS A FACTORY DEFECT. A retrofit kit is available to correct. In the DC Metro area, the wait time for an in home service call is three weeks.
If you have this problem, call Sears 1-800-4MY HOME and schedule a FREE retrofit kit installation
ALSO, call your sales person, and the appliance dept manager, at the store where you purchased the appliance to let them know this product is defective.
Jun 26, 2010 | Kenmore Dishwashers
Kenmore 655.13222 k601 bought 5 months ago after
Call sears and they can tell you normal cycle times according to your model. 1888.536.6673. Maybe argue with them to replace this unit since so many issues within 5 months.
Mar 26, 2017 | Kenmore 24 in. 17032 Built-in Dishwasher
Kenmore 13114 Start Button Fell Off After 3 months
Sears will definitely come fix that under the warranty. I was in that line of work for years, and we would come fix any problem on a machine under warranty.
Mar 14, 2009 | Dishwashers
E-5 error code and no draining or rinse cycle machine less than 3 months old
E5 is a drain error - machine is not draining - check drain hoses - pull out machine if needed - check air gap. hope this helps. jimmy.
Sep 26, 2008 | Hobart 24 in. LXIH-3 Built-in Dishwasher
9 month old GE GLD4460nss
Order a Non-Wood Countertop Kit GPF65Check electrical connection to dishwasher. All that moving around may have contributed to a poor connection. Test wire nut connections where the household wire connects to the dishwasher by holding wire nuts and tugging each wire to make sure they are firmly attached. Inspect incomming wire to make sure it has not been damaged.
Aug 27, 2008 | GE GLD4460NSS Stainless Steel Dishwasher
Bosch Evolution 300 SHE43M05UC Stainless Steel Built-in Dishwasher Logo
202 people viewed this question
Top Bosch Dishwashers Experts
Gerry Harvey
Gerry Harvey
Are you a Bosch Dishwasher Expert? Answer questions, earn points and help others
