Question about Rival 38651-C 6-Quart
Water coming into refrigerator
Water is coming into my refrigerator and ice is in the freezer.
  • 3 Answers
When it rains is the key to your problem!
its not a plumbing problem it's a foundation problem. When it comes in at the base of the wall, where it meets the floor it needs to be fixed by releasing the water pressure build up under the floor. Needed is a under the floor sump pump and or a under the floor drain line installed, by removing the floor in that area and then after work is done re cementing floor back together.
plumbing will not fix it!
Posted on Jan 20, 2015
    Problem Solver:
  • 5 Answers
Evelyn,
More than likely (I can't be sure from here!), your icemaker "motor module" has failed. This module controls the amount of water that goes into the ice tray. If the timer fails, the water valve can stay open. Also, if this is a new unit, or a used refrigerator you just installed, all you may need is to reset the timer on the motor module. The icemaker must be removed to do that. The tray fill time varies with the local water pressure. If your water pressure increases for some reason, the time must be shortened to avoid overfilling the tray.
Posted on Jan 18, 2009
I have a crockpot which has picture symbols for cooking im not sure which is highor low
1-IN THE CROCK POT YOU CAN PUT INSIDE A FEW CUBES OF ICE AND TOUCH ONE PICTURE AND LOOK AT THE ICE SEE HOW LONG IT TAKES FOR THE ICE TO MELT.AND YOU WRITE DOWN HOW MANY MINUTES.YOU DO THIS WITH ALL PICTURES THIS WAY YOU'LL FIND OUT WICH PICTURE IS THE HOTES.
Feb 06, 2018 | Crock Pots & Slow Cookers
Can a pressure cooker's 'ceramic insert' be frozen / thawed?
Why not use a freezer bag for the spare food to store it in. Probably won't do any harm if thawed thoroughly before re cooking but I wouldn't do it.
Dec 05, 2017 | Crock Pots & Slow Cookers
Is it still good?
No. Pork must be refrigerated. I recommend that you toss it.
Apr 07, 2016 | Crock Pots & Slow Cookers
Can I use my cook essentials pc400 programmatic pressure cooker for canning green beans?
Yes you can. The idea of pressure canning is to raise the temperature to above 100'C, 212'F. The higher temperature kills food borne organisms and bacteria.
Personally, as a chef, I would not can green beans as you will lose all the colour and any vitamins that were present by the long cooking at high temperatures. I would blanch them in boiling salted water and then drop them into ice water to set the colour and arrest cooking. The shake of the water and freeze them on a tray. Then put them in a freezer bag.
Jul 07, 2015 | Crock Pots & Slow Cookers
Why is steam and water coming out of the safety valve of the Russel Hobbs preasure cooker
When a pressure cooker is working normally, some steam and a little water is supposed to come out of the valve, that's how you know it's up to pressure.
Aug 29, 2014 | Crock Pots & Slow Cookers
It seems that my Rival crock pot is cooking too slow even on high setting. It has not been used excessively. A smaller one I used years ago cooked whatever in the stated amount of time per high/low...
Hello, Calexander58 -
The heating element for your crock pot may have failed.
You can test it to determine if it comes up the to the proper heat.
Follow these steps:
* Make sure you have the kind of cooking thermometer which can be used to take the temperature of liquids, like one for candy making. If you do not have one, you may be able to borrow one from a relative or friend. Otherwise, you will have to purchase one.
* Fill your slow cooker with water halfway to the top
* Turn it on to the lowest setting and cover for 8 hours
* Do not remove the lid during the full 8 hours
* Remove the lid and immediately take the water temperature
The water temperature should be 185 degrees Farhenheit.
Information source:
How To Test Your Slow Cooker
https://www.spendwithpennies.com/how-to-test-your-slow-cooker/
If the water temperature is less than 185 degrees F, it is time to replace the slow cooker, if it is no longer covered by the manufacturer's warranty.
Jan 13, 2018 | Rival Crock Pots & Slow Cookers
I can not get the crock out of the base. Any suggestions? I cooked with it once and it stuck but I was able to get it out. I cleaned the inside of the metal base really well as well as the crock itself....
Try filling the crock with ice or ice-cold water - the reasoning is that the ice should cause the crock to shrink just enough to get it out. If that does not work, switch it on to heat he base; which should cause it to expand and when it is warm, pour cold water into the crock to shrink it
Feb 03, 2018 | Hamilton Beach 33163 Stay or Go 6-Quart...
Water Coming in basement
check out side where the water is going into the basement, aside from the gutter down spout, you going to need pack some earth so that the water will running towards the yard. If it is where the gutter down spout is, then you need to get a gutter extension direct the water some where else.
DO not paint the basement wall, you will have mod. however, you can waterproof the wall when the weather gets to be above 55 degree.
Jan 09, 2009 | Rival 38651-C 6-Quart
Rival automatic steamer rice cooker 4450 guide needed
Here's all the info I've been able to find:
The older Rival rice cooker steamer should have a base, a lid, steamer basket, and rice bowl.
To cook rice, fill center basin of base with water. Place the rice bowl on basin. Add rice and water as follows. For white rice add water in a 1:1 ratio to rice plus 1/2 cup. For brown rice add water in a 1:1 ratio to rice plus 3/4 cup. Examples: 1 cup white rice, 1-1/2 cup water; 2 cups brown rice, 2-3/4 cups water. Put lid on and plug in and in about 50 minutes you should have delicious rice.
Timing is Everything
Whether using the Rival Steamer for a main dish or for a side dish, cooking is easy. But not Fast. Rice and steamed vegetables actually take twice as long to cook in this steamer. The simplicity comes since you add your rice or vegetables in one step. No waiting for one thing to happen before you can do the next. Put water and fruits, vegetables, fish, poultry or rice in the basket or bowl that come with the unit, cover, plug in and wait for the light to go off per the timing chart.
1/4 cup water takes 6 -7 minutes
1/2 cup water takes 10-12 minutes
3/4 cup water takes 16-17 minutes
1 cup water takes 19-22 minutes
1.25 cups water takes 24-26 minutes
1.5 cups water takes 26-30 minutes
2 cups water takes 38-39 minutes
2.5 cups water takes 43-44 minutes
3 cups water (max fill) takes 45-50 minutes.
Steamed Chocolate Pudding (From the Rival Steamer Guide)
3/4 cup flour
3/4 teaspoon baking powder
1/4 teaspoon salt
1/3 cup butter
1 teaspoon vanilla
1/2 cup sugar
1 egg, beaten
1.5 ounces unsweetened chocolate, melted
1/2 cup milk
1/4 cup chopped nuts
Sift together flour, baking powder and salt; set aside. Cream butter and vanilla until fluffy. Gradually add sugar, beat well. Add egg and melted chocolate; blend well. Add milk alternately with dry ingredients and beat until smooth. Fold nuts into batter. Pour into greased 8"x4" loaf pan. Cover pan with aluminum foil. Place pan in steamer basket. Cover and steam until wooden pick inserted near center comes out clean. Serve warm with **Marshmallow Cream Sauce. Water: 1 cup. Time: 19-22 min.
**Marshmallow Cream Sauce:
16 large marshmallows
1/3 cup cream
In a small saucepan, combine ingredients and melt over low heat. Serve over Steamed Chocolate Pudding.
Feb 23, 2008 | Rival Automatic Steamer/Rice Cooker 4450...
Water comes out
I would suggust that you take your crock pot to your nearest service center. To see if they can correct the problem with your crock pot.
Okay. Spurs21
Nov 19, 2007 | Rival 3060 6-Quart
Rival 38651-C 6-Quart Logo
121 people viewed this question
Top Rival Crock Pots & Slow Cookers Experts
Jerry Greenberg
Jerry Greenberg
tsalagi152
charles
Are you a Rival Crock Pot and Slow Cooker Expert? Answer questions, earn points and help others
