Question about Toro Lawn Mower With Toro Power Tools
MOTOR FREEZE UP - SINFLE STAGE BRIGGS AND STRATION SNOW THROWER
I HAVE A 2 1/2 YEAR OLD TORO WHICH THE MOTOR FROZE UP ( BRIGGS AND STRATTON) SINGLE STAGE. THEY TOLD ME THAT I DID NOT FOLLOW THE INSTRUCTIONS AS TO HOW MUCH OILD TO GAS RATIO IS TO BE USED. i DID FOLLLOW THE INSTRUCTIONS AND HAVE NO WAY OF PROVING IT. HAVE ANY OF YOU HAD THE SAME EXPERIENCE?
  • THOMAS KNOX Jan 30, 2009
    Excellent solution.
bbreton
  • 437 Answers
SOURCE: Can't start my Toro CCCR 2000 Snow blower.
You may have had no Fuel in the tank, But there may have been residual fuel left in the carburetor. It will need to be cleaned out.
Hope you get it done before the first snow fall.
Good Day.
Posted on Oct 07, 2009
  • 44 Answers
SOURCE: Toro Max 1028LXE Snow Thrower will not travel.
thank you for the reply. with the belt drive take a ruler and push the belt down you can use your finger as a referance point if you can push it past the half inch mark the belt needs to be tightend you can do that by adjusting the belt tensioner thats done by losening the bolt that holds it in place then moving it so there is no more then half an inch of play in the belt and retightning the bolt. and if the tensioner is at its stops then the belt needs replacement.
Posted on Dec 21, 2009
  • 506 Answers
SOURCE: Craftsman single-stage snow thrower hard to push
You can adjust the guides on the side of the blower so that it rides on those. If they are set to low you will see the problem you have now. If they sit to low for a long period of time you can wear out the blade on the bottom.
Posted on Dec 23, 2009
SOURCE: My toro 1128 OE snow blower wont throw snow the
I have a toro 98 cc powerlite snowblower model 38182 it was running fine one day then bog down and died after that i cant get it to start it has a good fire on the plug plug isnt very wet it pops threw carb once in a while help
Posted on Dec 27, 2009
  • 430 Answers
SOURCE: Snowthrower. Won't even fire. Can I just clean carburetor?
See my tip on diagnosing small engines. It works for 2-stroke or 4-stroke engines.
It is best not to use starter fluid. Aerosol carb cleaner is what I use.
Posted on Jan 02, 2010
I JUST PURCHASED A SINGLE STAGE SNOW THROWER FROM LOWES. WHAT IS THE DIFFERENCE BETWEEN A SINGLE STAGE VS A DUAL OR MULTI STAGE SNOW THROWER THANKS DON DMH8@AOL.COM
a single is just that a single auger that scoops snow and shoots it out chute their a smaller unit --a dual front auger scoops snow into another auger which shoots the snow through the chute the duals are bigger and they move more and heavier snow
Nov 26, 2016 | Garden
Snow keeps getting stuck & doesn't shoot out, even if the snow isn't heavy, after several
View Comment - MovingSnow.com
movingsnow.com/.../craftsman-88395-30?-277-cc-two-stage-snow-blow...
Oct 14, 2015 - 28 In 277cc* Dual-Stage Snowblower w/ EZ Steer at $1049 (minus ... If you do get something stuck in the front end - yes it will slip the belt.
Cheap 2 stage Snow Blowers - There are a few good ones ...
movingsnow.com > ... > 24 in Craftsman 88172 179 cc
Nov 7, 2014 - Sears carries other brands besides Craftsman but they are all not as good of ... Briggs and Stratton 1696610 Dual-Stage Snow Thrower with 208cc ...Subscribe to our mailing list and get interesting stuff and updates to your email inbox...... up to the 28 inch 28 In 277cc* Dual-Stage Snowblower w/ EZ Steer.
Dec 29, 2015 | Craftsman 28 In 277cc* Dual-Stage...
Chute on Troy Bilt single stage snow thrower won't turn
CHECK TO SEE IF THE ICE FROZE I THE CHUTE YOU MAY HAVE TO PULL THE COVER OFF THE TOP THIS SOUNDS LIKE THERE MIGHT BE ICE BUILD UP ALSO AFTER THE COVER IS PULLED OFF CHECK THE GEAR THAT TURNS THE CHUTE BY TURNING THE HANDLE
Feb 26, 2015 | Troy-Bilt Squall 2100 208 cc 21-in...
Procedure to start single stage electic start toro snow thrower
plug in Electric start. Push Choke to 'ON'. press Primer Bulb about 2 times. Turn Key to 'ON' Press Starter.
If you didn't run it completely dry of Gas last season I bet the Ethanol gas messed up your carburetor
Dec 15, 2014 | Toro Power Clear 621 ZE 21 163cc Single...
Snow blower will not throw snow far
I take it that you have a 2-stage snow blower, that is is has the auger blades and then the 2-stage impeller. The impeller blade is damaged <<OR>> the motor is to small to through the snow far. If you have a 5-horse engine and throwing heavy snow, the snow may not go as far as the light fluffy stuff.
A single stage snow thrower is not designed to throw snow far, just move it over a bit.
Oct 10, 2014 | Garden
Toro 621 snow thrower won't start
could be a number of things , spark , bad gas oil mix clean plug close choke when starting open after start , umber one problem clean the tank out
Dec 15, 2013 | Toro Power Clear 621 ZR 21 163cc Single...
Simplicity Sno Away Snow Thrower Briggs 6hp engine No Spark
Check engine oil.
Remove wire from low oil sensor and the start.
Replace low oil sensor.
Hope this tip help solve your problem.
r/David
Dec 28, 2009 | Briggs & Stratton Ignition Kit 2-8 HP...
Dec 22, 2009 | Toro Blowers Rake and Vac - Electric...
Toro Lawn Mower With Toro Power Tools Logo
433 people viewed this question
Top Toro Garden Experts
Joseph Mueller
Joseph Mueller
lnbn1975
Mike Squire
Are you a Toro Garden Expert? Answer questions, earn points and help others
