Question about Coolmax CPU Fans CPU Fan
Looking for cpu fan or combo heatsink for a foxconn mother board
Fan bad trying to find one to replac it
  • 2,692 Answers
CPU heatsink/fans are usually sold as a unit at, as well as al other computer supply places. Fan and heatsink are specific and  must match CPU and socket.
Posted on Jan 17, 2009
Custom computer build, foxconn motherboard, computer wont start
Not trying to be condesending but start simple and work your way up.
1. strip dow board to;
a. known good older processor
b. known good single memory stick
c. known good power supply
move memory one slot over
Move memory over one slot
move memory to last slot
You have tested the variables if still not working you have a bad mother board.
contact foxconn for replacement.
Feb 28, 2012 | AMD Computers & Internet
Computer would not boot up
Seems like you have an overheating problem. Try clean/grease the CPU fan and the heatsink under it.
(Do it without removing the heatsink itself, otherwise you'll have to put it again using thermal compound between it and the CPU itself!)
If that doesn't solve the heat issue, try replacing the whole heatsink/fan kit with a better one. Furthermore, a computer case with an "air-tunnel" always helps cooling up your computer.
Mar 10, 2010 | Computers & Internet
How do i quiet this fan down? 478
What do you mean by Quiet it down? If the fan is running at an excessive speed, try to look in the Bios (Hardware monitor) settings to set the CPU fan to auto. This will provide a balance between fan speed and cooling.
If the fan itself is mechanically noisy, then you are probably looking at a shot bearing, causing it to run noisily. For the cost of a new heatsink and fan (about £20.00), its worth considering replacing it
Feb 10, 2010 | Foxconn (CMIP31S) CPU Fan
System is saying that CPU fan has failed and shuts system down. I just replaced the fan and heat sync it is still saying this.
Thermal paste is applied between the heatsink and the cpu heat spreader or die. If you removed the heatsink to replace the fan you should have applied new thermal paste to the cpu or you may have burned it up. Try clearing the bios like dageezer said. Look for a jumper pin near the onboard battery to clear the cmos.
Sep 15, 2009 | HP Pavilion Media Center a1330n - AMD...
HP 873N CPU fan error
Yes, It is possible to be a board problem much more likely to be a dust /dirt problem. I have not found anywhere to purchase the CPU fans by themselves.Would obve to be wrong on this one; seems that they are sold along with the heatsinks. My favorate is : Newegg. com  but another is:
All you will need to know is your CPU  socket number. You can look that up in tghe manual:
I provided a link to the HP manual for you computer below. I beleive,once opened , you wil see the dust and dirt which may have caused a failer of the CPU fan. Filters are available for the same websites as the fan/heatsinks.〈=en&cc=us
Feb 12, 2009 | HP Media Center PC 873n (P9875A#ABA) PC...
No beep,No Display on my monitor,only CPU heatsink fan is moving
have you thought about changing the battery on the motherboard, also checking that the fan on the cpu is seated properly with enough heatsink paste as both these issues will stop the pc from booting
Oct 29, 2008 | Asrock K7S41GX Motherboard
Vista 64 shuts down while playing games
Check for overheating problems
Check all fans including power supply one
Then remove fan from heatsink and clean out all fluff and dust
Vacuum out case all vent holes ans case fans
When playing games either CPU or Video card getting hot and closing down to protect system
Asus 945 motherboard is in stand by mode. When I power on , the LED of mother board is glow The cpu fan just jurking and stop. And the LED of motherboard is still now glow.
Hi kausik, that green led you see on the motherboard is just letting you know there is power to the board. (This is normal).
You'r CPU fan jerking & stopping is a bad thing & has nothing to do with standby mode. Your CPU fan needs to be replaced.
There are a bunch of Asus 945 boards, just click the link to see.
If you are able to remove the fan from the heatsink than you may be able to buy a fan from here.
Most people replace both heat sink & fan.
Have more questions, feel free to ask.
Good Luck!
Apr 18, 2008 | Intel Motherboard
Trouble shooting
OC failure = over clocking failure. Make sure the CPU fan is clean, free from dirt & dust. Check CPU fan plug is connected correctly. If the CPU fan still stops after a few seconds replace the CPU fan.
It's harder to find just a fan to fit your heatsink, which sits on your CPU. It is easier to find a new heatsink \ fan combo for your Intel. Use your manual to find what Intel chip is on your board. Use that information & search google for a heatsink & fan combo. Pay close attention to how your current heatsink is mounted to the Gigabyte board.
Mar 24, 2008 | Computers & Internet
Coolmax CPU Fans CPU Fan Logo
311 people viewed this question
Top Coolmax Computers & Internet Experts
Paul Bade
Chippy Skippy
Chippy Skippy
Lawrence Oravetz
Are you a Coolmax Computer and Internet Expert? Answer questions, earn points and help others
